9900K Overclock/Temps help - Page 3 - Overclock.net - An Overclocking Community
post #21 of 36 (permalink) Old 05-19-2020, 02:30 PM
Imprezzion's Avatar
Rep: 106 (Unique: 93)
I run basically the exact same OC on mine. 5.0/4.7 on 1.196v VR VOut LLC 4. Lapped but not delidded cooled with a EK Phoenix 280 in push pull. Small FFT ABX enabled sees 79-81c hottest core after a long run. If I bump it up to 5.1/4.8 on 1.256v VR VOut I get 88-91c. Temps your getting are maybe a tad higher then I expected but not all CPU's are the same and mines lapped which saved me like 8-10c as it was concave as heck lol.
Cars:
-Crashed: (not my fault ) '94 Nissan 100NX GA16DE (a.k.a. NX1600). Renault Laguna Phase I facelift '99 1.6 K4M. (Broke a strut and smacked a tree).
-Sold: '00 Nissan Primera P11-144 QG18DE, '97 Honda Prelude F20A4, 03 Ignis Sport.
-Current daily: '07 Ford Focus 1.6 Futura.
-Current funcars: '03 Peugeot 206CC 2.0 RFN fully riced and tuned (Turbo coming soon)
Looking for: Gen 4 or 5 Honda Prelude, >92 Toyota Celica or >90 MR2.
Full-On Rainbowbarf
(16 items)
P45 power!
(9 items)
i9 9900K @ 5.1Ghz 1.248v (VR VOut)
MSI MEG Z390 ACE
RTX 2080 Ti Phoenix GS + G12 & Kraken X52 @ 2130/8100 1.093v (EVGA FTW3 BIOS)
Corsair Vengeance RGB B-Die @ 4200 16-17-17-34-320-2T 1.54v
Samsung 850 EVO 500GB x2
Samsung 970 Evo 1TB
Seasonic Prime Ultra Gold 1000w
EK MLC-Phoenix 280 Kit
Phanteks Enthoo Evolv X
Operating System
Windows 10 Pro X64
Samsung S27B350H @ 1080p 75Hz OC
Iiyama GB2788HS @ 144Hz
Keyboard
Logitech G710+
Mouse
Trust GXT31
Mousepad
Corsair MM300 Large
Audio
Steelseries Siberia V2
Intel Core 2 Quad Q6600 G0 @ 3Ghz (333x9)
MSI P45 Neo2-FR
MSI GTX760 Gaming X
6GB completely random 1 and 2GB sticks. All 4 different ones.
A-Data 120GB SSD
AOpen 350w
Some huge aluminum Xeon heatsink
Cartboard box.
Operating System
W10 Pro x64
Intel Xeon E3-1270v1 @ 3.8Ghz
ASUS P8H61-i R2.0
Sapphire R9 280X Vapor-X @ 1230Mhz core.
16GB Kingston HyperX Savage 2400CL11 @ 1333CL6
Kingston 240GB SSD
Corsair CX600
Corsair H110i GTX
Custom open test bench made from a cut-up CM690 v1
Operating System
W10 Pro X64
Samsung 23" cheap thing
Keyboard
Cheapest one Aldi had
Mouse
Mousepad
The desk...
Imprezzion is offline
post #22 of 36 (permalink) Old 05-19-2020, 03:17 PM
Just hangin' out
Arctucas's Avatar
Rep: 36 (Unique: 35)
Half hour run. 1.225VCore override.
Significant difference.
Name:	p95 266 override 5-19-20.jpg
In no way should it be misconstrued that I do not disagree.
https://valid.x86.fr/52sqs5
PC
(15 items)
9900K
eVGA Z390 DARK
eVGA RTX2080 FTW3 ULTRA
GSKILL F4-4500C19D-16GTZKKE
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
LIANG D5, XSPC DUAL BAY RESERVOIR, HEATKILLER IV PRO NICKEL, THERMOCHILL PA140.3, AEROCOOL 140MM SHARK FANS
THERMALTAKE XASER VI
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Auzentech X-Meridian 7.1 2G
Audio
Z-5500
Arctucas is offline
post #23 of 36 (permalink) Old 05-19-2020, 06:37 PM - Thread Starter
Rep: 0
Not sure how you are getting those low VId guys =( mine is way higher. i think GB board is messing up something.
I tried to re-flash it with new bios - same thing. I just can't get why would it send 1.26V with auto settings to the stock CPU, and 1.4+ volts when the multiplier is set to 50. I'l try to set Ac and Dc at advanced Vr setting to 1 and see what my default CPU vid is
`EDIT`
well, run it for 4.7 and 5.0 - screenshots attached.
Name:	4.7 default vid.png
Vivid Violet
(14 items)
9900k
Gigabyte Aorus Master z390
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK Velocity CPU block
EK XE 360
EK PE 360
O11D Distro Plate
DDC 3.1 PWM (impeller from 3.25)
LianLi O11 Dynamic XL
LG GN 750B
Audio
AudioTechnica ATH-M50
Hawkjoss is offline
post #24 of 36 (permalink) Old 05-19-2020, 09:51 PM
Facepalm
Falkentyne's Avatar
Rep: 440 (Unique: 306)
`EDIT`
Wow that's a pretty high VID (1.245v) for 5 ghz at ambient.
You don't have your VR VOUT showing. How much VR OUT do you need to be stable at 5 ghz @ full load?
Also your board has an IR 35217? Must be a new revision...
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is offline
post #25 of 36 (permalink) Old 05-20-2020, 05:12 AM - Thread Starter
Rep: 0
Also, your board has an IR 35217? Must be a new revision...
Hi Falkentyne!
During the test above i just slapped 1.35V with turbo LLC to be stable at load.
At my regular OC profile, I use an adaptive voltage and below is the data for OCCT NO AVX Small Data set ( pretty much the same as P95 26.6 small data )
83 max temp, VRVOUT 1.252V, @152A - this is the lowest I can go in voltage for 5.0/4.7 non AVX loads. If I lower the voltage to meet 1.24V at load, i get L0 errors within 20-30 min of test
Name:	5.0 OCCT sFTT no AVX.png
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #26 of 36 (permalink) Old 05-20-2020, 05:20 AM
Facepalm
Falkentyne's Avatar
Hi Falkentyne!
Yeah I see. That's about 40mv higher than my chip needs. High default VID=needs higher vcore.
But may run cooler than a low VID chip if BOTH are run at the exact same vcore.
post #27 of 36 (permalink) Old 05-20-2020, 05:31 AM - Thread Starter
Rep: 0
Some my chip is pretty much a dud?
Could you please share your opinion on the 1st post in this thread? I listed all my specs and testing results
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #28 of 36 (permalink) Old 05-20-2020, 10:30 AM - Thread Starter
Rep: 0
Updated bios to F11h.
below settings used for the test:
CPU ratio: 50
uncore:47
AVX offset 0
VCCSA: 1.2
VCCIO: 1.15
Vcore: 1.3V (reads as 1.308V in bios, 1.278V-1.291 at VRVOUT in windows at idle )
LLC: turbo
AC/DC: auto
MCE disabled
C-states, power savings - disabled. turbo boost - disabled.
ran P95 small fft no AVX - VRVOUT 1.238-1.24V, temps 82 max(24C amb). No L0 errors for 20 min.
decided to run P95 with AVX enabled - BSOD in a second (watchdog_timeout)
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #29 of 36 (permalink) Old 05-21-2020, 02:01 PM - Thread Starter
Rep: 0
Quote: Originally Posted by Shawnb99 View Post
Welcome to world where 60 degrees is seen as amazing temps.
Some chips run hotter then others. I was seeing the same thing with mine. Delidding and going direct die helped a lot. Plus I got lazy and just used one of the 5ghz OC profiles so likely running lower then I can
Well, rockit delid kit/direct die frame is on the way, should have by the weekend. (thanks for the tip,Shawnb99)
IF direct die will not help much with temps, it is definitely the CPU block causing high temps.
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #30 of 36 (permalink) Old 05-22-2020, 09:01 PM - Thread Starter
Rep: 0
Update
Delidding kit came in a bit earlier than expected. Thank you RockiT!
quickly went to pick up a Conductonaut in local micro center and was ready to get this hot stone "stripped".
The whole procedure went surprisingly smooth and quick - easier then I expected.
After all this procedure I got a few questions and it would be great if experienced people can help me figure those out:
1. Could you please comment on the thermal paste spread from the photos below? it seems like a gap in the middle of the ihs and cpu block - is it normal? I used the spreading method with an applicator which comes with Cryonaut.
2. As this is my first LM application, did I apply enough?
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
