9900K Overclock/Temps help - Page 4 - Overclock.net - An Overclocking Community
post #31 of 41 (permalink) Old 05-22-2020, 09:17 PM
Facepalm
Falkentyne's Avatar
Rep: 440 (Unique: 306)
Seems okay.
[email protected] ghz, RX Vega 64, 32GB DDR4, Gigabyte Aorus Master, Seasonic Platinum 1000W, Corsair 760T
Alt: MSI GT73VR Throttlebook with 7820HK @ 4.7 ghz, GTX 1070 MXM TDP mod to 230W, 32 GB RAM
Quote: Originally Posted by sakete View Post
Well, I want you to know I have an academic degree in speculation.
Falkentyne is offline
post #32 of 41 (permalink) Old 05-23-2020, 07:05 AM - Thread Starter
Rep: 0
Will run an extensive tests over the weekend, but preliminary results are pretty good;
1. Was able to lower the voltage by 0.020V and still remain the stability in both 4.7 and 5.0 profiles.
2. the gap between coolest and hottest core narrowed considerably -
After 10 min OCCT Small FFT NO AVX at 5.0
Before direct die
hottest 83, coolest 76, VRVOUT 1.252V, [email protected]
After direct die:
hottest 77, coolest core 74. VRVOUT 1.234, [email protected]
Considering my ambient is 2C higher than during the initial test, the direct die yields an 8C temperature drop and a reduction of 4C per core delta.
Name:	d-die 5.0 OCCT no AVX.png
Vivid Violet
(14 items)
9900k
Gigabyte Aorus Master z390
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK Velocity CPU block
EK XE 360
EK PE 360
O11D Distro Plate
DDC 3.1 PWM (impeller from 3.25)
LianLi O11 Dynamic XL
LG GN 750B
Audio
AudioTechnica ATH-M50
Hawkjoss is offline
post #33 of 41 (permalink) Old 05-23-2020, 09:03 AM
criskoe's Avatar
Rep: 5 (Unique: 4)
Quote: Originally Posted by Shawnb99 View Post
You may receive better results with other blocks, I only used Heatkiller IV Pro and Optimus Signature for direct Die. Also should depend on the direct die mounting kit. RockCool's kit isn't the same as D8auser or whatever the name is.
Generally you can get away with removing the washers for a good contact.
Hey Shawnb99. Mind sharing a quick pic of your Optimus block on your apex board with delid? Particularly on the left side of socket. I want to see how close you are to the row of caps on the left side of the socket. Does the sig v2 sit on top of them? If you could see if you can get a pic showing closely the clearance that would be amazing man. Thanks.
Current
9900KS
Asus Maximus XI Extreme
Nvidia 1080Ti FE
Corsair Dominator Platinum RGB
Samsung 970 EVO
Evga 1200 P2
Ek Magnitude
EK D5 Kinetic D5 TBE
2X EK 360 PE
EK 1080ti Full Cover Block
AC High Flow USB
10X Corsair 120mm ML Pro Fans
Lian Li 011 Dynamic XL
criskoe is offline
post #34 of 41 (permalink) Old 05-23-2020, 01:40 PM
Just hangin' out
Arctucas's Avatar
Rep: 36 (Unique: 35)
Before direct die
After direct die:
Nice results.
OCCT 557?
What were your ambients again?
In no way should it be misconstrued that I do not disagree.
https://valid.x86.fr/52sqs5
PC
(15 items)
9900K
eVGA Z390 DARK
eVGA RTX2080 FTW3 ULTRA
GSKILL F4-4500C19D-16GTZKKE
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
LIANG D5, XSPC DUAL BAY RESERVOIR, HEATKILLER IV PRO NICKEL, THERMOCHILL PA140.3, AEROCOOL 140MM SHARK FANS
THERMALTAKE XASER VI
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Auzentech X-Meridian 7.1 2G
Audio
Z-5500
Arctucas is offline
post #35 of 41 (permalink) Old 05-23-2020, 02:08 PM - Thread Starter
Rep: 0
Quote: Originally Posted by Arctucas View Post
Nice results.
OCCT 557?
Yes, 5.5.7
Before delid tests were conducted at 23-23.5C ( had AC on)
Delidded at 25.5C, but at that time i had AC turned off so after the tests ended up with ambient of 27C
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #36 of 41 (permalink) Old 05-24-2020, 05:10 AM
Just hangin' out
Arctucas's Avatar
Yes, 5.5.7
Right in line with mine.
I believe direct die really is the way to go with this processor.
Name:	occt557 5-24-20.jpg
PC
(15 items)
9900K
eVGA Z390 DARK
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Audio
Z-5500
Arctucas is offline
post #37 of 41 (permalink) Old 05-25-2020, 08:15 AM
Shawnb99's Avatar
Rep: 55 (Unique: 36)
Next tear down I will. I still have to switch over to the springless mounts as well as remove the O-ring. I keep putting it off but I'll get to it soon and will take some pics. But just looking at it off hand it seems I'm a few mm away from the caps. That's with it mounted normally, whereas with the Heatkiller blocks I had to use the goofy mount due to it hitting the caps.
The Sign2 should clear all the caps on the Apex just fine. I know mine did.
My Baby
(23 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Optimus Signature V2
2x Swiftech MCP35X2 with MCP35X2 Heat Sink w/ 2x NB-BlackSilent Pro's
2x Hardware Labs Black Ice Nemesis 560GTX w/ 8x Arctic P14 PST PWM's
2x Hardware Labs Black Ice Nemesis 480GTX w/ 16x Noctua NF-A12x25 PWM
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
Hardware Labs Black Ice Nemesis 360GTS w/ 6 Arctic P12 PST PWM's
Case Labs Magnum TH10A with Pedestal
Asus PG278Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Light Harmonic Oscar XXI
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #38 of 41 (permalink) Old 05-25-2020, 09:28 AM
criskoe's Avatar
Rep: 5 (Unique: 4)
When you say a few mm away. Do you mean a few mm to the side? or few mm below? I really want to go direct die but unfortunately I have a magnitude block and its fat and the frame sits just over the inner row of caps. Theres is about 1mm of clearance under the frame and caps currently and if i try direct die im sure it will contact.
I dont really want to buy a whole new block just for this but I keep seeing these 10-15c drops in temps reported. LOL. I wanted to see what options would work and then gauge if I wana do it.
Wondering if I should just grab a All Black acetal copper Optimus foundation. PPCS has 10% off optimus plus their memorial day sale which you can combine right now. Ends up only being 88 bucks.
Current
9900KS
Nvidia 1080Ti FE
Samsung 970 EVO
Evga 1200 P2
Ek Magnitude
2X EK 360 PE
AC High Flow USB
criskoe is offline
post #39 of 41 (permalink) Old 05-25-2020, 10:10 AM - Thread Starter
Rep: 0
It looks like my bottleneck was cache ratio and VCCSA/VCCIO voltages. I changed ring to 46 and VCCSA/VCCIO to 1.25V/1.2V respectively. It allowed me to drop another 0.020 on the core ( -0.040V compared to non-delid)
Current settings
Core: 50x
Ring: 46x
AVX offset 1
Voltage: Normal ( adaptive ), -0.140 offset
LLC: Low
AC/DC Loadline: auto
PWM switch rate: 300 MHZ
All C states, power limits, and power saving features are disabled
XMP Ram - [email protected], 1.35V, VCCIO - 1.2V, VCCSA - 1.25V
Pump at 1GPM, fans start at 500RPM and go up to 1000RPM based on coolant T.
Ambient at the start - 24C, after the tests - 25.5C
Prime 95 29.8 AVX:
hottest 79C, coolest 74C, VRVOUT 1.178V ( i would insta BSOD at that V before delid); [email protected] Ambient at the start - 24C, after the tests - 25.5C
OCCT 5.5.7 non AVX:
hottest 76C, coolest 72C; VRVOUT 1.221V; [email protected] Ambient at the start - 25C, after the test - 25.5C
RealBench 2.56
hottest 76C, coolest 72C; no whea errors. Ambient - 26.5C
did some gaming and found interesting observations:
Played Metro Exodus - back to back 1 hr sessions at "stock undervolt" and "5.0/4.9". the average temps are EXACTLY the same - 42C-45C. the only difference are peak temps, and they are within 5C stock/OC.
I believe I am limited by my GPU here - it is not connected to the loop and spitting all the heat out inside the case, thus soaking the rads. I think once I get GPU connected to the loop, I will still have lower temps despite it throwing all the heat into the water.
Name:	5.0 P95 29.8 AVX small FFT delid.png
Name:	OCCT 557 small fft no AVX delid.png
Vivid Violet
(14 items)
9900k
Asus GTX 1070 Strix
Gskill TridentZ Neo
Samsung 970 Evo+
EVGA G2
EK XE 360
EK PE 360
O11D Distro Plate
LG GN 750B
Audio
Hawkjoss is offline
post #40 of 41 (permalink) Old 05-25-2020, 03:35 PM
Facepalm
Falkentyne's Avatar
Current settings
Core: 50x
Ring: 46x
AVX offset 1
LLC: Low
Prime 95 29.8 AVX:
OCCT 5.5.7 non AVX:
RealBench 2.56
Nice results.
I'm confused about something.
Were you crashing with the lower VCCSA and VCCIO (and I assume 47 cache? But the screenshot way above this one still shows 46 cache, but 1.13v IO...(SA is hidden).
