8086K | CPU-Z misleading Vcore HELP! - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 05-31-2020, 06:43 PM - Thread Starter
LT_WaTchd0g's Avatar
Rep: 0
Hey, first off, I run an 8086K on an MSI Z370 GAMING M5
So after almost one whole day of me trying to figure out WHY CPU-Z is showing Core VID a lot higher than my UEFI Vcore manual setting, after finding out about LLC and researching the hell out of it for hours (actually at least I learned a bit of it too so cheers for this), after trying to figure out what am I missing although I did not modify many other settings in the UEFI, and trying to make out my OC steps backwards (because I saw the Core VID a lot higher than the UEFI a lot later in my OC) I somehow remembered where have I seen the actual "correct" readings, and that was in CPU-Z 1.90. At some point I updated to the latest which is 1.92. So I redownloaded the 1.90, and in it I now see again the "correct" Vcore which is the same as in my UEFI, 1.280 for 5.0 GHz all cores OC. After I saw this I quicky checked with HWMonitor, and there is reads 1.310-1.365v as in CPU-Z 1.92, so now i'm thinking that this is the correct value now, and the CPU-Z 1.90 and 1.91 readings were incorrect. But what I still don't understand is why is the Vcore a lot higher than my UEFI manual setting at 1.280v? After googleing, I saw that 5.0 GHz on an 8086K should have Vcore between 1.225-1.350v, so I thought I was safe at 1.280v based on CPU-Z 1.90 as I kept monitoring it (but now I think that the Vcore was a lot higher based on CPU-Z 1.92 and HWMonitor actual readings). As I learned from researching LLC is that for example I should have seen readings of 1.280v in CPU-Z only in idle and lower readings in load, but my problem is that the Vcore readings are higher than that... I tested with LLC Mode 8 at 1.350v and the readings were the same! 1.310-1.365v. So there was a bug in Vcore readings on older CPU-Z versions? I checked the changelogs and there was nothing specified about it. WHAT AM I MISSING HERE PLEASE?! In the screenshot you can see both CPU-Z 1.91 and 1.92 COre VID readings.
EDIT: Now I see that CPU-Z 1.91 didn't have bad readings at all... 1.90, 1.91 are showing the Core Voltage while 1.92 is showing the Core VID, they changed the sensor reading in that sensor space.
Other UEFI settings:
Ring 4700
All Turbo settings disabled
Fixed frequency
All eco settings disabled (EIST etc)
MSI Z370 GAMING M5 latest BIOS 1.90
Corsair H60i AIO Water Cooler
LT_WaTchd0g is offline
post #2 of 23 (permalink) Old 05-31-2020, 06:47 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1434 (Unique: 726)
stop using CPU-Z and HWMonitor to monitor vCore, lol.
use HWInfo, and look at VR VOUT if you have it.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is online now
post #3 of 23 (permalink) Old 05-31-2020, 07:48 PM
iunlock's Avatar
Rep: 13 (Unique: 6)
^ I agree. Uninstall hwmonitor completely and use hwinfo64 instead.
Also I run my 8086K 50x all cores @ 1.22v for reference. The higher voltage mentioned in the OP of ~1.3# is way too high for the 8086K... Those readings of 1.3# seems like VID readings which are not true / actual vcore readings.
Custom Optimus Water Cooled Beast: =Project 42= Z390 Master ┊ 9900KS @ 5.5GHz (1.35v) Ambient ┊ EVGA 2080Ti FTW3 Ultra ┊ 32GB G.Skill RoyalZ RGB @ 4600MHz* ┊ 2TB Samsung 970 EVO Plus m.2 ┊
☆ FS [35745] | TS [17707] | CB R15 [8787cb] | CB R20 [19880cb]
Test Bench: EVGA X299: 7980XE @ 5.4GHz https://valid.x86.fr/sb92qz ☆ Z390 Dark: 9900KS @ 5.5GHz https://valid.x86.fr/g3ibif ☆ Zenith II Extreme TRX40 - 3970x @ 4.6GHz [All Core] https://valid.x86.fr/kxzfzs
iunlock is offline
post #4 of 23 (permalink) Old 05-31-2020, 07:57 PM
OLDFATSHEEP's Avatar
Rep: 38 (Unique: 8)
1.3x die sense VCore is not high at all if you delid.
OLDFATSHEEP's 10gen
(11 items)
Intel i9 10900K
ROG Maximus XII APEX
Geforce RTX 2080 FE
Micron Ballistix Max 4000
970 PRO
970 EVO PLUS
Asus Thor 850W
Corsair H150i pro
Dell UP2716D
Keyboard
Razer Huntsman Elite
Mouse
Razer Viper Ultimate Wireless
i9 9900k
i7 8086K
Asus Maximus XI GENE
Geforce RTX 2080 FE
F4-4133C17D-16GTZR
970 PRO
SM961
EVGA 1000W G+
Corsair H150i pro
NEC PA271W
Audio
GRADO RS2e
OLDFATSHEEP is offline
post #5 of 23 (permalink) Old 05-31-2020, 08:29 PM
iunlock's Avatar
Rep: 13 (Unique: 6)
Not from my experience with multiple 8086K's and 8700K's.... If you need more than 1.30v to run 50x on an 8086K then you've been doomed...
iunlock is offline
post #6 of 23 (permalink) Old 05-31-2020, 09:01 PM
Rep: 38 (Unique: 8)
Sorry I didn't notice you were talking about 50x. OFC 8086K should need around 1.2V socket sense voltage for 50x.
OLDFATSHEEP's 10gen
(11 items)
Intel i9 10900K
Geforce RTX 2080 FE
970 PRO
970 EVO PLUS
Asus Thor 850W
Corsair H150i pro
Dell UP2716D
Keyboard
Mouse
i9 9900k
i7 8086K
Geforce RTX 2080 FE
F4-4133C17D-16GTZR
970 PRO
SM961
EVGA 1000W G+
Corsair H150i pro
NEC PA271W
Audio
GRADO RS2e
post #7 of 23 (permalink) Old 05-31-2020, 09:17 PM
iunlock's Avatar
Rep: 13 (Unique: 6)
All good. Yea all of my 8086K's have done well in the low 1.2#v's...
iunlock is offline
post #8 of 23 (permalink) Old 06-01-2020, 02:29 AM - Thread Starter
Rep: 0
Ok so now you had me googleing for CORE VID vs Vcore, I found out that "VID is the voltage the CPU uses at any particular moment while Core Voltage (UEFI) is the limit of the voltage the CPU can use" but in my case it's the whole way around... HWiNFO reads VID at 1.310v and in the MSI Z370 tab the Vcore states 1.280v as I have set in UEFI. But nontheless, it's too much. 1.280v is pretty stable in my benchmarks, while 1.275v gives BSOD... why are my VID readings in Windows showing 1.310-1.365v (way more than the 1.280v Core Voltage)? I'm at 40C in idle, room temp at 23C. I have just started OC-in it a week ago, after having it on 4.0 GHZ all cores fixed OC from the moment I bought it a year ago.
PS: Now I see that CPU-Z 1.91 didn't have bad readings at all... 1.90, 1.91 are showing the Core Voltage while 1.92 is showing the Core VID, they changed the reading in that sensor space, you can see this in the screenshot I posted.
EDIT 1: "VID is the voltage requested by the processor. Vcore is the voltage actually supplied by the motherboard to the processor. This is the number you should be looking at." (reddit)
Ok so after reading this then I should not be worried? As I understand, the Core Voltage is what i should be looking at, so 1.280v is correct. But what about the VID reading? Is the CPU saying it needs 1.310-1.365v?
EDIT 2: Ok so what i'm trying to find out now is, if my Vcore is 1.280, am I safe with VID at 1.310-1.365v? Should I not mind at all about the VID and just work out with the Vcore? Is VID important when you OC or just care solely about the Vcore?
post #9 of 23 (permalink) Old 06-02-2020, 03:28 AM
bp7178's Avatar
Rep: 7 (Unique: 7)
Think of it as VID is the voltage the CPU thinks it needs, or the voltage Intel wrote on a table per a given load/frequency the CPU would request.
At 800mhz (idle) my 9900KS has a 0.665v VID while the actual VCORE is about 0.648v. At 5,300mhz with OCCT large/AVX2 the vid is 1.514v but the VCORE is 1.394v at LLC5 on my Asus Gene motherboard.
What matters is the actual voltage when at load.
bp7178 is offline
post #10 of 23 (permalink) Old 06-02-2020, 03:35 AM - Thread Starter
Rep: 0
Yeah now it adds up. When I was at 1.280vCore the VID was 1.310-1.365v, but after trying to get 3 runs of Asus ROG RealBench it always crashed in the first 2 runs, so I slightly added Core Voltage and now I'm stable at 5.0GHz - 1.340v after 6 runs (3 runs x 2 times) so just in between what VID read in the first place.
