35W Uncore on 15W 0.13Ghz 5200u. CPU Problem - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 06-29-2020, 09:42 AM - Thread Starter
Rep: 0
Hello guys, I found an old laptop in my house which I stopped using a long time ago bc it became very slow. I though it was bc of its hard drive but I was wrong. When I checked Task Manager the CPU is stuck at 0.13 or 0.48 Ghz depending on the restart. I read a lot of things online but nothing helped so I need your help. I think the problem is that the CPU thinks that its uncore is using 35W and its power throttling itself. I`ve updated to the newest Bios and the newest drivers. The laptop is Lenovo G50-80 with 4gb or Ram, i5-5200u and R5 M330 video card. The problem persists on battery and plugged-in. The parameters I have taken pictures of dont change.Thank you!
NapsterEps is offline
post #2 of 4 (permalink) Old 06-30-2020, 08:16 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1432 (Unique: 725)
are you using Windows 8.1?
I had a similar problem with the i3 8109U in my NUC when I was running Windows 8.1 Embedded Industry Pro, 8.1 gets tripped up over U series SKUs sometimes.
If you are, you can fix it by turning off fast-boot and then restart, if it fixes the problem you can turn it back on but there's a 50/50 (ish) chance on boot it'll start having the problem again.
if not, then 130 mhz is impossible unless your BCLK is dropping to 32.5 since the minimum multiplier is 4x on the U series SKUs. Don't use Task Manager to read clock speed, use CPU-Z (or HWInfo). still reading low there?
You said it feels slow but being able to quantify "slow" is more useful than a seat of the pants report. try to run Super Pi 1M, the test should finish in under 30 seconds even with a pretty crappy kit of RAM and a bloated OS install, and really it should finish under 20 seconds.
https://www.techpowerup.com/download/super-pi/
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #3 of 4 (permalink) Old 07-01-2020, 01:54 PM - Thread Starter
Rep: 0
I found the problem, its the BIOS. I have Lenovo G50-80, model name 80E5 with Core i5-5200u. I am searching for BIOS B0CN40WW. I upgraded the bios version from B0CN40WW to B0CNA0WW and my CPU stuck to 0.13Ghz and the CPU thinks that Uncore is using around 40W and its power throttling itself. I tried out few older version of BIOS, B0CN95WW - 0.13GHZ, B0CN75WW and B0CN79WW - 0.48Ghz. In versions B0CN75WW and B0CN79WW the CPU thinks that Uncore is using 30W so its throttling itself a bit less, still not at all how it must be. I am searching for my original BIOS version so I can get rid of this problem. I am using the original Ram but I also tried a different one, I tried reinstalling Windows, I tried Windows 7 and Windows 10 and nothing changes.
post #4 of 4 (permalink) Old 07-03-2020, 12:03 AM - Thread Starter
Rep: 0
Idk how but the problem fixed itself so you can delete the topic.
