Spiking Temps on Intel 10700 Stock Cooler - Overclock.net - An Overclocking Community
post #1 of 12 (permalink) Old 07-13-2020, 01:36 PM - Thread Starter
Rep: 0
Recently upgraded by local shop, and some reason my temps spike to not so good levels, seen 95-100C even just running a simple Windows Defender scan. I know i need to get the CPU cooler upgraded to better one when i can afford it, meanwhile is there anything i can do to keep the temps around 80-85C and not go into the 90's anymore?
Motherboard is
Gigabyte B460M-DS3H
Shop installed it, so i assume thermal paste was applied, not good at dealing with coolers, or that stuff myself, so i hope they put enough on, and keeps working fine
Thank you all in advance
P.S. I don't plan to really overclock, but occasionaly use a little Turbo boost if possible
bikemanI7 is offline
post #2 of 12 (permalink) Old 07-13-2020, 02:19 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1449 (Unique: 731)
well it's good that you don't plan to OC since you can't with that board or that CPU, lol.
lower the voltage in the BIOS and/or set a more aggressive fan curve.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
XPG SX8200 Pro NVMe 2TB
HP EX950 NVMe 2TB
2x Samsung 860 1TB RAID 0
WD Blue 4TB SSD
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MK730 (MX Blue)
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston DDR4 2400 16GB
Mushkin Pilot NVMe 1TB
SanDisk Ultra II 480GB
Operating System
Windows 10 Professional
Keyboard
Dierya DK63 60% (Outemu Blue)
Mouse
Logitech G603
The Pook is offline
post #3 of 12 (permalink) Old 07-13-2020, 02:39 PM - Thread Starter
Rep: 0
Ok will look into setting a more aggressive fan curve, not too experienced with that aspect of things, but i'm sure can figure it out, just will take some reading and time to get it done, Motherboard is Gigabyte B460M-DS3H, with Intel 10700 Stock Cooler LGA 1200
post #4 of 12 (permalink) Old 07-13-2020, 02:48 PM
Princess Garnet's Avatar
Rep: 206 (Unique: 178)
What upgrades were done by the shop? What was changed (motherboard and CPU, just CPU, more?), what did you have before, and did you have warm temperatures with what you had before?
There's a lot to consider, including case, cooling (fan and airflow) arrangement, as well as ambient temperatures (if you're where it is currently Summer, is room temperature high?).
That being said, a stock cooler on a Core i7 10700 (non-K) might not keep it super cool and quiet, but it shouldn't be nearing 100C running a virus/malware scan either (unless I'm vastly misunderstanding how demanding that may be or something, but when I run Security Essentials I didn't even notice it performance-wise or noise-wise on my old Core i5 2500K so I don't think that should be putting such a demand on a higher core CPU?).
"The heart has it's reasons that reason knows nothing of."
Princess Garnet is offline
post #5 of 12 (permalink) Old 07-13-2020, 03:04 PM - Thread Starter
Rep: 0
Well I picked out a new case, Thermaltake V200, New Motherboard/CPU--Gigabyte B460M & Intel I7 10700, room temp is about 65-70F i think, it varies though depending on local conditions, A/C is on when it's hotter, right now in one non demanding game at 49C, just got concerned when i ran the first scan with Defender after a clean install, that it got to 100C, on a few cores.
**Not Sure if i ever removed the plastic covering the Glas side cover on inside the case of my side panel window---not sure if that would affect cooling or not--first time ever had a case with a Window myself here**
Previous board was OEM Asus G11CD-K, Intel I7 7700, with 1 Rear 92 Mm exhaust fan in that old case
Maybe nothing to worry on, or i worry too much lol. 3 Front Intake fans on Case(unknown how well they intake air, 1 rear 120MM Exhaust, room for top of case for 2 120, or 140mm fans as well, ((adding soon as i can))
post #6 of 12 (permalink) Old 07-13-2020, 03:30 PM
9 Cans of Ravioli
The Pook's Avatar
10700 stock boosts to 100mhz higher than a 9900K and it's being cooled by this:
your 2500K might be a similar TDP but TDP isn't power consumption. a 2600K stock pulls 106 watts from the wall, a 10700 with turbo enabled draws 254 watts. OP could be running on an open test bench with a dozen 3000 RPM industrial Noctuas pointed straight at it and his temps would be poor, lol.
lower the voltage. stock/auto voltage gives my 9900K ~1.35v when it needs less than 1.25v. My H115i struggles to cool my 9900K at 1.25v let alone 1.35v.
2 OP pls nerf
(24 items)
NUC U
(9 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
WD Blue 4TB SSD
Corsair H115i Pro
Operating System
LG 24UD58 24" 4K
Keyboard
Mouse
Glorious Model D
Mousepad
X-Ray 27" x 14"
Audio
Klipsch PowerGate
Audio
Schiit Hel
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Operating System
Keyboard
Mouse
Logitech G603
The Pook is offline
post #7 of 12 (permalink) Old 07-13-2020, 03:42 PM
The reason for asking for everything that changed was to try and minimize causes. If, say, you changed only the CPU or CPU plus motherboard, and the prior stuff ran well below what you have now, you could (nearly) rule out things like local conditions, case airflow, etc.
If you changed case, then a lot of airflow things change as a result. What happens if you test other games? Benchmarks? Programs/uses that load many cores highly? You're going to need to test out a lot of other games and programs to try and get a more accurate picture; one game and virus/malware program isn't enough. You need to find out if this warrants contacting the shop about it, and the sooner, the better.
Usually when I do a quick scan with Security Essentials, they are, well... quick and I don't notice any performance impact, so I never thought much of them. I just started a full scan to see how heavy it is (I do have a game, largely a single threaded one, going too). Though, unless we're comparing the same program, I guess this is a pointless comparison, but in my case, it does load my CPU about as much as a game would. My ambient/room temperature is a bit warmer than yours too.
So I'd do more checking to see what the overall landscape is like. You need to establish if the game you tried with half the temperature result was a light outlier, or if the scan was. If you're getting 10C (or more) lower in most other cases and the 90C+ is rare, I'd say it's probably not cause for concern on a stock cooler that isn't that close to throttling, but if you're closer to throttling, you might have airflow or cooling issues somewhere.
post #8 of 12 (permalink) Old 07-13-2020, 03:45 PM
Hm, seems I'm just underestimating how warm Intel's recent CPUs run, then. I thought the standard Core i7 10700 (non-K) shouldn't run quite as warm. I also figured the supplied standard cooler, while it might not keep it very cool and quiet, should at least be preventing it from near throttling?
post #9 of 12 (permalink) Old 07-13-2020, 03:46 PM
To The Game
Chargeit's Avatar
Rep: 292 (Unique: 198)
Be a pretty good cooler for a raspberry pi 4.
Benchmarking FX-6300 + GTX 950 @ 1080p & 1440p
980 ti vs 1080 ti @ 3440x1440
$270 pc 1080p benchmark!!!!
10900k
H115i
msi z490 ace
GTX 1080 ti
G.SKILL TridentZ RGB Series 32GB @ 3600
Samsung 960 evo 500gb m.2
Samsung 850 evo 500GB
860 evo 1tb
Seasonic FOCUS GX-1000
Fractal Design Define R5 Blackout with Window
Operating System
Win 10 pro
Acer Predator X34 (34" 21:9 Gsync)
Keyboard
Corsair K70 RGB MK.2
Mouse
Logitech G502 LIGHTSPEED
Audio
Bose Companion 2 Series III
Chargeit is offline
post #10 of 12 (permalink) Old 07-13-2020, 03:59 PM
Vandelay Industries
maltamonk's Avatar
Rep: 85 (Unique: 63)
Why not get a new cooler? $20 and boom problem solved!
maltamonk is offline
