Help OC 3770k+DDR3-2133 - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 07-19-2020, 02:56 AM - Thread Starter
Rep: 0
Hi people
I want to stay with my PC one or 2 years more (until Zen4 maybe) I have tried to squeeze my computer but with no success. I have red ansd tried a lot but only I have achieved 4.3 Ghz of OC. Dunno!
CPU 3770k
RAM RipjawsX DDR3-2133MHz CL11-13-13-31 1.50V 16GB (2x8GB) - F3-2133C11D-16GXL
MB ASUS P8Z68-M PRO
COOLER Noctua NH-L12
CASE Corsair Air Carbide 240
PSU HX850i
As I said I reached 4.3Ghz (with all basically in auto) and with this Prime95 gets 80-84º, in games only 76º C top. The RAM I stick on 1600 because I have tried XMP Profile or put on 2133 but Windows doesnt boot.
Mi idea was to get 4.5 Ghz at least and RAM on 2133 or if there is no performance on that speed of DDR3 let it in 1600 but with lower timings!
Any tips, or step by steps guides will be helpfull
Cheers!!!
maeggor is offline
post #2 of 3 (permalink) Old 07-19-2020, 05:55 AM
Retired Staff
Farih's Avatar
Rep: 112 (Unique: 92)
The board you are using is pretty **** tbh and might be the reason why i doesnt want to run 2133mhz RAM XMP.
You could try setting the RAM somewhere between 1600-1866mhz and try tightening the timings (manually set RAM voltage to 1.5V before you do so instead of auto)
On that board i would limit my Vcore coltage to 1.28-1.3V and not use the highest LLC setting (you want some droop on Vcore) and see how high you can get it.
With that voltage you should be able to get between 4.2-4.4ghz
Often 4.5ghz on a 3770K requires around 1.32-1.35V (with some droop) but you might get lucky.
Anyways, dont go all out with that board.
Keep your Vcore and LLC limited.
1st PC >>> Ryzen 3700x @ PBO OC - 16GB 3800mhz CL16 - 5700XT @ 2150mhz
2nd PC >>> Intel I5-4790K @ 4,7ghz - 16GB 2133mhz - RX570
3rd PC >>> FX-6300 @ 4,5ghz - 8GB 1866mhz - GTX960
4th PC >>> Dual Core E5700 - 2GB 800mhz - HD6670
Main PC
(25 items)
AMD Ryzen 3700X
Asus Gaming TUF X570
Sapphire RX5700 XT Nitro+ Special Edition @ 2150mhz
G.skill Ripjaws 16GB 3800mhz 16-16-16-36
Samsung 256GB NVME
Samsung 860 EVO 500GB
Seagate 3TB 7200rpm
Seagate 3TB 7200rpm
Corsair RMI 1000W
Scythe Fuma Triple Fan
Lamptron Fan Controller
5x Corsair AF120
Corsair AIR540
Iiyama 1440p
Keyboard
Logitech G413 Silver
Mouse
Logitech G403 Wired
Mouse
Razer Naga Trinity
Mousepad
A big one
Audio
Oppo Sonica DAC (modified)
Audio
Lehmann Linear headphone amp
Audio
AKG K812
Audio
Sennheiser HD650
Audio
Audioqeust Nighthawk
Audio
Beyerdynamic DT770
Audio
Focal Elear
I5-4790K @ 4,7ghz
Asus Z97 Pro Gaming
Sapphire RX570
16GB G.E.I.L Black Dragon 2400mhz
Samsung 860 EVO 256GB
Seasonic 500W
Scythe Fuma 2
Farih is offline
post #3 of 3 (permalink) Old 07-19-2020, 09:50 AM - Thread Starter
Rep: 0
Thanks Farih!
Refering RAM I have just get the problem. I used only 1.5V and need more. So now I have 1.65V and can use it with its fabric clocks 2133.
I tried your tips refering to CPU Voltage. Now its in Auto and I can see at load it uses 1.220V aprox. for 4.3Ghz
I will tell you with near 1.3V
Thanks
maeggor is offline
