10900k frequency and voltage not dropping when idle - Overclock.net - An Overclocking Community
post #1 of 3 (permalink) Old 07-25-2020, 07:15 PM - Thread Starter
naved777's Avatar
Rep: 36 (Unique: 36)
Hi all,
I have trying to figure this out but cant seem to solve it. I am using a biostar z490 gta evo board. Not a popular or a good board to begin with. Now what feature should i turn on or disable so that the in idle it doesn't run with static voltage and frequency. I have overclocked using adaptive voltage with offset of +50 and LLC set to level 1.
Thanks in advance !
naved777 is offline
post #2 of 3 (permalink) Old 07-26-2020, 10:29 AM
Rep: 0
Make sure that your computer is not in "performance mode" in the power options. That will cause you to stay at max frequency. Depending on what LLC you used, you may actually experience higher voltages at idle than when under load. That is normal and is a feature to prevent transient voltages.
Haxasaurus is offline
post #3 of 3 (permalink) Old 07-26-2020, 10:49 AM
Not a Linux Lobbyist
Sedril's Avatar
Rep: 2 (Unique: 2)
One thing that got me a while back on this very issue was on my cache OC, I had set min and max to 48.... Everything else was set to let the voltage and freq drop at idle... Once I set the minimum cache to Auto it worked as intended...
Make sure speedstep and speedshift are enabled, and like mentioned, make sure you are on balanced, or that your minimum / maximum cpu control are 0 and 100... I keep a shortcut handy for when I don't want it to drop, I just swap to high performance quickly...
Let us know some of your other settings if you haven't figured it out yet...
Apex
(14 items)
i9 9900k
ASUS ROG Maximus XI Apex
EVGA RTX 2080 Super FTW3 HydroCopper
G.Skill TridentZ DDR4 16gb 4133
Samsung 970 Pro m.2 512GB
Samsung M.2 960 Evo 1tb
Western Digital Black
EVGA 1200 P2
Custom water
Thermaltake Core X9
Operating System
Windows 10 Pro X64
LG 27" Ultra HD 4k
Keyboard
Microsoft Natural Ergonomic
Mouse
Logitech G900
Sedril is offline
