Guide to Overclocking the Core I7 920 or 930 to 4.0ghz - Page 112 - Overclock.net - An Overclocking Community
post #1111 of 1479 (permalink) Old 01-27-2011, 01:02 PM
Linux Lobbyist
Nemesis158's Avatar
Rep: 166 (Unique: 131)
Originally Posted by HaMMeR=GoM= View Post
I was wondering why my Gigaflops were a little on the low side and now I know why. Everyone needs to read this:
https://www.overclock.net/intel-cpus/...test-linx.html
It also helps both Linx and IBT to update the Linpack libraries manually to the latest version.
When running Linx or IBT the GigaFlops have to be close to the rating for your particular chip. If it isn't then, you're not stressing the Overclock correctly.
After I loosely followed this guide my GigaFlops increased dramatically and my core temps rocketed by 5°C Luckily, I had previously increased my vcore and my qpi voltage due to Prime 95 Bsod after 8hrs. I now feel that if Linx is run properly, it will tell you if you're overclock is stable within 99%, I would guess
I found these here on OCN and I feel that the above and these should be added to the guide.
BSOD viewer:
http://www.nirsoft.net/utils/blue_screen_view.html
BSOD codes:
BSOD codes for overclocking
0x101 = increase vcore
0x124 = increase/decrease vcore or QPI/VTT...have to test to see which one it is
0x0A = unstable RAM/IMC, increase QPI first, if that doesn't work increase vcore
0x1E = increase vcore
0x3B = increase vcore
0x3D = increase vcore
0xD1 = QPI/VTT, increase/decrease as necessary
0x9C = QPI/VTT most likely, but increasing vcore has helped in some instances
0x50 = RAM timings/Frequency or uncore multi unstable, increase RAM voltage or adjust QPI/VTT, or lower uncore if you're higher than 2x
0x109 = Not enough or too Much memory voltage
0x116 = Low IOH (NB) voltage, GPU issue (most common when running multi-GPU/overclocking GPU)
Thank you for those codes and what causes them. knowing what the rest of these are caused by will help Overclockers like me get past 4GHz
+rep
clubs 'n stuff (Click to show)
If you live in the NW (Washington, Idaho, Oregon, Montana), check out the NW Overclocker Club
camera.gifNikon D5500|AF-S 18-55mm 1:3.5-5.6G VR II DX|AF-S 35mm 1:1.8G DX|AF 50mm 1:1.8D
AF-S 55-200mm 1:4-5.6G VR | BR2A | BR-3 | BR2A+BR-3=Extension Ring
Nemesis158 is offline
post #1112 of 1479 (permalink) Old 01-27-2011, 01:14 PM
Tleilaxu Ghola's Avatar
Rep: 15 (Unique: 13)
BSOD viewer:
BSOD codes:
This is great! +1 to you bro. It would be nice to add to this, I wish I could offer some additions to this right now.
-TG
Tleilaxu Ghola is offline
post #1113 of 1479 (permalink) Old 01-28-2011, 02:37 PM - Thread Starter
chadamir's Avatar
Rep: 284 (Unique: 272)
chadamir is offline
post #1114 of 1479 (permalink) Old 01-28-2011, 04:29 PM
jeezuz's Avatar
Rep: 1 (Unique: 1)
I've noticed with my overclocked settings that the voltage stays at or pretty close to 1.28, where as with stock it would fluctuate from 1.20-1.21 and pretty close to 1.0 when idle.
Obviously this is from setting the Vcore to 1.28 for my overclock. However is I set it to auto with the bclck at 160 the voltage goes as high as 1.4 which at this point is undesirable.
Is there any way around this? Is there a setting I can modify to get the voltage to idle when cpu power is not necessary? My settings are a couple of pages back (pg 110) but here's the main ones just for recap:
CPU Ratio: Auto
Turbo: Enabled
BCLK: 160
DRAM: 1282
QPI:5774
Voltages:
VCore:1.281
PLL: 1.84
QPI: 1.30
IOH:1.2
ICH:1.1
DRAM: 1.64
LLC: Enabled
CPU Diff amp: auto
CPU clock skew: 100ps
Anything spectrum: Disabled
CIE and C-State: Disabled
Virtual: Enabled
HT: Off
TM:Enabled
Nemesis wrote in response to my original post:
I would try raising your cpu VTT as you dont seem to have done anything with that. VTT is for the ram controller, and should be within .45v of Vdimm for best results
VTT is the same as QPI voltage correct? I did raise it as high as 1.32 but couldn't get a stable 1600 memory speed, I'm stuck with 1282 for the time being until i've had my system a few more weeks and decide to up the voltages a little bit.
jeezuz is offline
post #1115 of 1479 (permalink) Old 01-28-2011, 05:25 PM
MMJA's Avatar
Rep: 34 (Unique: 31)
I've noticed that most of the time if I get a 0x101 BSOD it shows up as 0x124 in blue screen viewer, anyone know why this is?
MMJA is offline
post #1116 of 1479 (permalink) Old 01-29-2011, 11:59 AM
HaMMeR=GoM='s Avatar
Rep: 33 (Unique: 32)
Please add PERSPOLIS's How to run linpack to the LinX section of your guide please.
https://www.overclock.net/intel-cpus/645392-how-run-linpack-stress-test-linx.html
Thanks to everyone for the reps, but all I was doing was repeating info that I found on the forums. I would like to credit the original authors, but I don't know who they are.
HaMMeR=GoM= is offline
post #1117 of 1479 (permalink) Old 01-31-2011, 03:27 PM
hi?
h2on0's Avatar
Rep: 30 (Unique: 29)
CPU Ratio: Auto
Turbo: Enabled
BCLK: 160
DRAM: 1282
QPI:5774
Voltages:
VCore:1.281
PLL: 1.84
QPI: 1.30
IOH:1.2
ICH:1.1
DRAM: 1.64
LLC: Enabled
CPU Diff amp: auto
Virtual: Enabled
HT: Off
TM:Enabled
Disable the turbo and try it again and see if it goes to 1.4
h2on0 is offline
post #1118 of 1479 (permalink) Old 01-31-2011, 07:38 PM
Rep: 0
nice guide. nothing is perfect but there is definitely a lot of good reference material here. I don't have the money for a great cooling system or a new case right now so i am trying to get a small boost without killing my system and you seem to have helped a lot.biggrin.gif
Truck_Drivin_Jesus is offline
post #1119 of 1479 (permalink) Old 02-01-2011, 07:23 AM
Prabuddha87's Avatar
Rep: 0
can i7-920 processor work on DH55PJ Motherboard?
Prabuddha87 is offline
post #1120 of 1479 (permalink) Old 02-01-2011, 07:57 AM
B-Con's Avatar
Rep: 121 (Unique: 97)
That's a negative. That board is an 1156 socket.
Here's an overview of the board...
http://www.intel.com/Products/Deskto...J-overview.htm
Here's a list of supported processors...
http://processormatch.intel.com/Comp...ardName=DH55PJ
BMW 932i
(19 items)
i7-920 D0 @ 4.0 GHz (1.28V)
ASUS P6X58D-E
EVGA GTX 780 Classified (417.71)
3 x 4 GB G.Skill Ripjaws Z 1600 MHz (7-8-8-22)
Samsung 850 EVO 500 GB
Samsung 840 PRO 256 GB
Western Digital Caviar Black 1 TB
Optical Drive
Sony AD-7240S DVD RW
EVGA SuperNOVA 750 G3
Corsair H55 (GT AP-15 Pull + Shroud)
Cooler Master HAF 932
Operating System
Windows 10 Professional 64-bit
ASUS PB278Q 27" LED 1440p
ViewSonic VX2433wm 24" LCD 1080p
Samsung LN46C630 46" LCD TV 1080p
Keyboard
Logitech G510s
Mouse
Roccat Kone XTD (Laser)
Mouse
SteelSeries 4HD
Audio
NVIDIA / Yamaha RX-V467 / HyperX - Cloud II
B-Con is offline
