Guide to Overclocking the Core I7 920 or 930 to 4.0ghz - Page 148 - Overclock.net - An Overclocking Community
post #1471 of 1479 (permalink) Old 05-01-2017, 01:30 AM
Akusho's Avatar
Rep: 7 (Unique: 7)
My dad asked me to overclock his old 920. Currently stopped at 3.95 at 1.245 volts. Will wait a few weeks for the weather to warm up and see what the temps will be to decide if I have a bit of room to go 4.1 or not.
Something that is bothering me is the LLC. I've searched the net but haven't found a definitive answer to whether it can hurt the CPU or not with the voltage spikes. I would prefer to not damage it and let it live at least a few years more. Any advice?
Without LLC I would have to bump the voltage up to 1.3, and with the voltage not downscaling on idle I would prefer to not have it sit always at 1.3.
Akusho is offline
post #1472 of 1479 (permalink) Old 05-01-2017, 08:53 AM
7175's Avatar
Rep: 0
I've had LLC enabled on my i7 920 @ 3.8-4.0 GHz 24/7 since 2009. Use this PC for 3D games and compiling stuff pretty regularly. Just my two cents.
7175 is offline
post #1473 of 1479 (permalink) Old 08-18-2017, 01:44 AM
Nicholas Steel's Avatar
Rep: 1 (Unique: 1)
I was thinking about overclocking my Intel i7 920 D0 Stepping CPU that I purchased back in 2009: http://ark.intel.com/products/37147/Intel-Core-i7-920-Processor-8M-Cache-2_66-GHz-4_80-GTs-Intel-QPI
At 2.793 Ghz (multiplier increased to 21x and Turbo Boost disabled, everything else on Auto) I get these temperature results in AIDA64 while using Prime95's Small FFT stress test: (20 minutes) http://imgur.com/eVelXwp Edit: It's been an hour and 50 minutes with Prime95 now and the hottest CPU Core is holding at 65 degrees celcius and "CPU" (what does this variable refer to?) is holding at 56 degrees celcius. Edit: http://imgur.com/MqxGzPK (2 hours 10 minutes)
Should I be worried about these results before even beginning to consider overclocking? I am using a Noctua DH14 Heatsink, are these temperatures in line with using this heatsink? If they aren't then maybe I applied the thermal paste improperly or the heatsink isn't applied as firmly against the CPU as it should be.
I've been reading this guide on overclocking the CPU and am currently just monitoring temperatures before doing anything drastic. I'm pretty unfamiliar with modern overclocking but can understand the guide in the original post, It was a lot easier when you just had a FSB and Multiplier to adjust smile.gif
If the temperatures are good, what are some good suggested voltages for achieving an overclock of say, 3.2 to 3.4Ghz? The guide provides values for achieving a 4Ghz overclock but I don't want to be quite that risky with my hardware.
Thank you,
Edit: "What are safe voltages?" should be updated to mention the 1.275v VCore value for D0 Stepping CPU's.
Edit: Modern Prime95 versions don't seem to let you specify more Threads than there are CPU Cores. In the case of the 920 and 940 CPU that would be 8 threads max (not 10!).
Nicholas Steel is offline
post #1474 of 1479 (permalink) Old 08-18-2017, 10:25 AM
Rep: 1 (Unique: 1)
I've taken the plunge and have configured my BIOS with the following settings:
CPU Multiplier: 19 (3.6GHz)
Base Clock: 190MHz
RAM Multiplier: Lowest Available Option (I chose 2nd lowest, 1.5GHz)
UnCore Multiplier: Lowest Available Option
QPI Quickpath Interconnect Multiplier: Lowest available Option
RAM Timings: Auto
RAM Command Rate: 2
Hyperthreading: Disabled (reduces heat)
Vcore (CPU Voltage): 1.2750v (Guide says 1.2750v for D0 Stepping CPU)
PLL: 1.88v
qpi/uncore (VTT): 1.35v
IOH: 1.2v
ICH: 1.2v
Vdimm: 1.50v (I am using 1.50v RAM so I see no reason to increase it to 1.65v)
Load Line Calibration: Enabled
Both Spread Spectrum Settings: Disabled
I performed Prime 95's Small FFT stress test on 8 (hyperthreaded) Cores while watching Youtube for 33 minutes and encountered no issues. The CPU didn't exceed 64 degrees celcius (TJMax=67.9 celcius) each time I stopped to look at it for 30 seconds and each CPU Core never exceeded 71 degrees celcius (80 degrees and higher is bad and 90 degrees and higher is dangerous/stupidly hot I think?). I will of course need to do an overnight stress test to be confident that this setup is stable.
My previous attempt at overclocking involved leaving all the voltages and various settings set to "Auto" and was a really poor attempt at overclocking in hindsight (it resulted in blue screens occurring every so often and on other occasions, rebooting without warning).
ASUS P6T
24GB DDR3 RAM
Geforce 760 4GB
post #1475 of 1479 (permalink) Old 08-24-2017, 12:18 AM
Rep: 1 (Unique: 1)
I went with a 19x multiplier and Hyperthreading disabled. I have to say, I literally experience no performance increase in:
- DOOM (2016) (must lower resolution to improve FPS to 60 when smoke is on screen/looking through glass)
- The Witcher 3 (720p resolution improves FPS but its still too low most of the time to be enjoyable, & 720p sucks)
- Dark Souls 3 (Upgrading from a 560Ti to the 760 allows me to play 60FPS at 1600x900 instead of 50+FPS at 720p)
- Guild Wars 2
- Lords of the Fallen
- The Surge (same places and camera angles still result in FPS loss. Lowering resolution or resolution scaling greatly helps FPS while greatly lowering visual fidelity)
- Dragon Age: Inquisition
etc.
Which proves a Geforce 760 4GB video card is the limiting factor and not the CPU.
Edit: my friend has the same CPU and Motherboard as me and they recently upgraded to a Geforce 960 4GB video card. They can achieve notably improved frame rates at 1920x1080 than I can in many of these games (especially The Witcher 3).
Edit 2: Dragon Age: Inquisition exhibits more consistent frame timing with the overclock.
post #1476 of 1479 (permalink) Old 09-18-2017, 11:54 AM
HugoTheOne's Avatar
Rep: 0
With my system i can manage to get 3.10Ghz Fix, without issue. If i do 3.5, or 3.6 the system not boot. It's maybe my system can't handle more, or i just mess up something with the settings.
HugoTheOne is offline
post #1477 of 1479 (permalink) Old 09-20-2017, 02:56 AM
Rep: 1 (Unique: 1)
Take photos of all the voltage & clock speed BIOS settings on your motherboard.
post #1478 of 1479 (permalink) Old 10-25-2018, 02:17 AM
blodflekk's Avatar
Rep: 7 (Unique: 7)
Good guide, the best one I have found for x58. Decided to pull out my old 930 and gigabyte ga-x58a-ud3r and see what it can do. Sadly I can get stable at 3.99GHz (190*21) but the voltage it needs 1.42v I hit Tj Max after 15minutes of p95 large FFTs. Doesn't boot on 190*20 so I have to drop to 190*19 which is 3.5GHz, BLCK at 191 won't boot so I guess I'm stuck, can't push it any further?
And War, War Never Changes
Rampage
(14 items)
Intel Core i7 6850K
Asus Rampage V Edition 10
eVGA RTX2080Ti FTW3 Ultra
G.Skill Trident Z
Samsung 840 Pro
Corsair HX850
Noctua NH-D15
eVGA DG-87
Operating System
Windows 7 Ultimate x64
HP 2511x
Keyboard
Razer Blackwidow Ultimate
Mouse
Roccat Kone EMP
Mousepad
Roccat Alumic
Audio
Hyper X Cloud II
blodflekk is offline
post #1479 of 1479 (permalink) Old 11-08-2019, 04:00 AM
Rep: 1 (Unique: 1)
BSOD code 124: Increasese or decrease the qpi/uncore by .25. Depending on where you are in your stability tests you'll probably need to increase it. 1.375 is the max I'm comfortable with although people say 1.4+ is safe. This is for you to determine and research. Don't do anything you're not comfortable with. Intel says do not go above 1.35 so 1.375 with droop and loss is safe and not too outside specification.
I figured I'd point out this seeming mistake in the original guide. The suggested QPI/Uncore is 1.35v and the suggestion is to increase/decrease by 0.25??? That's a massive change! I have a feeling the Op meant to say 0.025.
