Guide to Overclocking the Core I7 920 or 930 to 4.0ghz - Page 4 - Overclock.net - An Overclocking Community
post #31 of 1479 (permalink) Old 07-17-2009, 09:40 PM
Data Recovery Engineer
Lord Xeb's Avatar
Rep: 1343 (Unique: 999)
TL;DL But I will definately look at it tomorrow. Too tired right now but from a quick glance it looks good!
Only fools do not BACKUP their DATA!
"Everyone is an expert in something. Knowledge is acquired not earned. Always be humble and wise. Never look down on others ignorant in your ream of expertise."
Hsvkinyodh
(15 items)
3770k @ 4.5 1.384v
Asus Z77 Sabertooth
GTX 1070 Gaming 2126/2249 w/ Hybrid cooler
TridentX 16GB 2400MHz
Samsung 850 Pro 1TB
Seagate 2TB
Seasonic X 760W
H105
CM 690 II Adv
Operating System
Windows 10
Asus MG279Q - 24" 144Hz 1080p
Keyboard
Filco Majestic II w/ Cherry Reds
Audio
AKG A701
Audio
JDS Labs Objective 2
Audio
JDS Labs ODAC
Lord Xeb is offline
post #32 of 1479 (permalink) Old 07-17-2009, 09:50 PM
Dyson Poindexter's Avatar
Rep: 209 (Unique: 161)
Originally Posted by chadamir View Post
whats the code? Whats your bclk?
I forgot which one, but I think it was the x101 error. Bclk is 191, and my multi is 21. Sometimes it pops down to 20 though, which upsets me considering the TDP protection is disabled in the BIOS.
Thanks for your help. I'll note the exact code when it happens again.
Why do we mount round fans on square radiators?
Dyson Poindexter is offline
post #33 of 1479 (permalink) Old 07-18-2009, 12:43 AM
Rep: 46 (Unique: 36)
When running a higher Uncore & QPI what voltages would be required to get stability?
Wadkiller is offline
post #34 of 1479 (permalink) Old 07-18-2009, 04:48 AM - Thread Starter
chadamir's Avatar
Rep: 284 (Unique: 272)
at 1.115 you are not going to hit 4ghz The best chips do it at ~1.17.
QPI/Uncore (vtt). QPI has little to no effect on system performance and uncore is a ***** to get stable as far as my efforts have gone.
chadamir is offline
post #35 of 1479 (permalink) Old 07-18-2009, 12:48 PM
Ok, I switched to 211x19 to avoid the throttling and the dreaded 20x200 instability.
I got it mostly stable by setting vcore to ~1.19 in the bios. CPUZ would show 1.200 idle and 1.184 under load. That's vdroop, right? I enabled LLC and now it's 1.208 idle and load. Will LLC hurt the chip at 1.208? I've heard that it can cause voltage spikes, but the vcore is still pretty low. (and I bet I can take it lower since it was almost stable at 1.184 load)
post #36 of 1479 (permalink) Old 07-18-2009, 12:52 PM
CyberDruid's Avatar
Rep: 2585 (Unique: 1242)
Thanks for the guide. I might just have to clock up my i7 now.
August 13th, 2011 sad-smiley-002.gif Happy trails, may we meet again.
CyberDruidPC is History
CyberDruid is offline
post #37 of 1479 (permalink) Old 07-18-2009, 12:59 PM
SlicketyRickety's Avatar
Rep: 85 (Unique: 65)
I stopped reading after i read D0's are better then C0's. Biased opinions make a crappy guide
Gr33nMachine
-=I Fold for 37726=-
SlicketyRickety is offline
post #38 of 1479 (permalink) Old 07-18-2009, 01:02 PM - Thread Starter
chadamir's Avatar
Unless you're doing some extreme voltages, you should be fine. I've never read about anyone frying a chip because of LLC. I think you'd hear more about it from intel or mobo manufacturers if it was an actual problem. Besides if you cut your chips life down from 10 to 5 years are you going to care?
chadamir is offline
post #39 of 1479 (permalink) Old 07-18-2009, 01:15 PM - Thread Starter
chadamir's Avatar
As I said, I've owned both. My d0 is much better than my c0. Sorry Thanks for stopping by to troll though.
chadamir is offline
post #40 of 1479 (permalink) Old 07-18-2009, 06:29 PM
I don't think it's biased if the statement is backed by empirical evidence. D0's are newer, and have been shown to clock higher with less voltage. I would consider that "better."
