~ Official i7 950 Overclockers Club ~ (Read First Post) - Page 286 - Overclock.net - An Overclocking Community
post #2851 of 2869 (permalink) Old 05-18-2017, 05:29 AM
Camo5's Avatar
Rep: 0
Hmm, I just clicked submit instead of trying to revalidate...
In other news, i'm adjusting the Bclock right now and i've already gotten to 180!
I had to raise the qpi twice from 1.215 to 1.255 because it did some wierd double startup thing for two attempts, but bios is showing the voltage isn't increasing when I increase the setting?
https://valid.x86.fr/vau011
Camo5 is offline
post #2852 of 2869 (permalink) Old 05-18-2017, 06:12 AM - Thread Starter
Lister
alancsalt's Avatar
Rep: 303 (Unique: 187)
72
alancsalt is offline
post #2853 of 2869 (permalink) Old 05-20-2017, 12:04 AM
Camo5's Avatar
Rep: 0
I have an update!!
https://valid.x86.fr/r3mtgh
Managed 4073.5mhz clock using a multiplier of 21x and a bclock of 194. Vcore is set to 1.31875v (cpuid shows 1.296 Vcore) and QPI/VTT = 1.295V. I have HT on and dynamic Vcore +.05
I tried 23x but even at 1.4v it wouldn't boot, so I bumped to 21x and am dialing down the Vcore. What's a respectable voltage for these clocks?
DDR is set at 1.66v (1.63v)
Intel burnin says I have a speed of 45 Gflops and a time of 170 seconds on very high load with chrome running....stock was 27 and almost 500!! biggrin.gif
Temps are poking around 65C, on a corsair H80 with a stock fan in pull on medium (I have a 2150 gentle typhoon on the way...)
Question: should I leave Uncore and ram where they are? (6x and 16x, respectively)
Camo5 is offline
post #2854 of 2869 (permalink) Old 05-20-2017, 05:10 AM - Thread Starter
Lister
alancsalt's Avatar
I have an update!!
post #2855 of 2869 (permalink) Old 07-14-2017, 10:31 AM
sofaMonster's Avatar
Rep: 0
Late to the party, but I finally OC'ed my old rig instead of buying new smile.gif
Had no idea on how OC'ing worked or how to do it, but I think I managed OK.
https://valid.x86.fr/cs1vjy
This seems stable, but a question regarding some of these validations. I could boot and run stuff at lower VCore, but would that be "accepted"? I mean, it looks kind of better?
I ran OCCT Linpack test for an hour with temps around 65-70c; normal temps or bad?
Some settings:
Multiplier x23
Vcore 1,31875
QPI/VTT 1,225
SPD x8
Uncore x16
DRAM 1,64
IOH Core 1,14
LLC Enabled
EIST Enabled
Hyperthread Enabled
sofaMonster is offline
post #2856 of 2869 (permalink) Old 07-14-2017, 10:45 AM - Thread Starter
Lister
alancsalt's Avatar
Some settings:
Multiplier x23
Vcore 1,31875
QPI/VTT 1,225
SPD x8
Uncore x16
DRAM 1,64
IOH Core 1,14
LLC Enabled
EIST Enabled
Hyperthread Enabled
72
It's been a while since I overclocked one of these, but the usual aim for a stable OC is to find the lowest voltage you can run at without crashes. If you get to the point where you crash, usually, raise vcore 2 increments and test again...
post #2857 of 2869 (permalink) Old 07-14-2017, 10:57 AM
Rep: 0
The system seems stable with 1,31875 whereas with 1,3125 it would give a warning in OCCT.
It didn't crash per se, but I figured it was not good to get an error. So I bumped the Vcore 1 up and haven't had issues so far smile.gif
post #2858 of 2869 (permalink) Old 07-18-2017, 10:58 AM
335is
NoGuru's Avatar
Rep: 769 (Unique: 312)
NoGuru is offline
post #2859 of 2869 (permalink) Old 07-18-2017, 04:26 PM - Thread Starter
post #2860 of 2869 (permalink) Old 09-08-2017, 07:08 PM
IceNoise's Avatar
Rep: 0
Hello to you all!
I have been reading these forums for years it seems, So much amazing information, thank you!
I finally managed to post and validate at 4.5Ghz!
IceNoise is offline
