The true power of Sandy Bridge? (130 GFlop peak linpack) - Page 2 - Overclock.net - An Overclocking Community
post #11 of 61 (permalink) Old 01-16-2011, 08:37 PM
soldierblue's Avatar
Rep: 4 (Unique: 3)
When I run it I get about ~64 Gflops at 4.5ghz.
soldierblue is offline
post #12 of 61 (permalink) Old 01-16-2011, 08:47 PM
Rep: 312 (Unique: 259)
Originally Posted by BallaTheFeared;12037639
We need some new testing done with regards to the SB chips vs the 980x in apps that can take advantage of SB's new instructions.
Also 50C max load, on some chill water is crazy, what are the people on air getting?
I dont see how your results are even remotely possible, IBT results are heavily influenced by number of cores, as well as ram performance. A 980x on this Thread at 4.5ghz was only able to achieve 97 gflops. The fact that you are able to surpass a hexacore, with and without HT is beyond me.
No offense my friend, but I find your results highly suspect....
"Being wrong is erroneously associated with failure, when in fact to be proven wrong should be celebrated. For it is elevating someone to a new level of understanding, furthering awareness."
"Always question the recieved reality, the consensus reality is often intentionally misleading"
"No trees were killed to send this message, but a large number of electrons were terribly inconvenienced."
Thermal Compound Application Instructions:
Click Here for Guide
Mattb2e is offline
post #13 of 61 (permalink) Old 01-16-2011, 08:48 PM
LethalRise750's Avatar
Rep: 228 (Unique: 207)
Installed SP1 RTM and getting the same GFlops as before Lol..
LethalRise750 is offline
post #14 of 61 (permalink) Old 01-16-2011, 08:58 PM - Thread Starter
No problem man.
It's called core advancement.
Look up AVX and you'll understand, SP1 allows usage of that instruction set, which basically doubled SB FP.
BallaTheFeared is offline
post #15 of 61 (permalink) Old 01-16-2011, 09:00 PM
wumpus's Avatar
Rep: 292 (Unique: 245)
gigaflops mean nothing.
but then again that is a lot of them.
I like overclocking more than actually playing video games.
wumpus is offline
post #16 of 61 (permalink) Old 01-16-2011, 09:02 PM
Originally Posted by BallaTheFeared;12038536
No problem man.
I'm on SP1, but I'm not getting those GFlops lol Is there something specific to enable AVX?
post #17 of 61 (permalink) Old 01-16-2011, 09:03 PM - Thread Starter
No.. Just the correct linpacks, download LinX - it has them, copy them into your IBT directory if you would rather use IBT.
They're both the same, just a different interface.
post #18 of 61 (permalink) Old 01-16-2011, 09:07 PM
rainmaker's Avatar
Rep: 12 (Unique: 12)
Did you notice any difference in games or cpu whoring apps?
rainmaker is offline
post #19 of 61 (permalink) Old 01-16-2011, 09:10 PM
i_hax's Avatar
Rep: 84 (Unique: 77)
As I just posted in the 5+ghz thread, this is far from exciting or what I'd consider 'tech advancement'...
Show me a real-world example. A stress testing program with a big number is useless.
i_hax is offline
post #20 of 61 (permalink) Old 01-16-2011, 09:14 PM
Rep: 64 (Unique: 55)
This is soooooo sig worthy - it really conveys what OCN is all about!
cmeeks is offline
