Best GPU for Sugo SG05? - Page 7 - Overclock.net - An Overclocking Community
post #61 of 81 (permalink) Old 11-18-2012, 01:18 AM
8.2 liters
WiSK's Avatar
Rep: 553 (Unique: 361)
Originally Posted by Volkswagen View Post
What are the chances of a Gigabyte GTX 670 fitting in a SG05...Card is 11 inches long- I am ok with cutting up the front part of the case to gain a little space....Not sure if someone that has the case can measure it? If I convert to ITX SG05 is the case I want but it would suck if I have to get rid of my 670- having to sacrifice as is....
Don't think your card is exactly 11 inches. Can you measure in mm from the outside of expansion bracket (not including the little tab)?
SG06 is maybe a better option - is a bit deeper on the front panel bit.
WiSK is offline
post #62 of 81 (permalink) Old 11-18-2012, 08:11 AM
Volkswagen's Avatar
Rep: 55 (Unique: 47)
11 inches....PCB is a little shorter but the heat pipes and shroud overhang a little.
Volkswagen is offline
post #63 of 81 (permalink) Old 11-18-2012, 08:46 AM
8.2 liters
WiSK's Avatar
If it's exactly 11 inches (= 279.4 mm) then it won't fit in an SG05. Internal length is 262 mm, cutting through the case to SG05 front panel would add no less than 7mm.
SG06 is 10mm longer on the outside, but I can't promise you how much of that is usable, since I don't own that case. I would guess that since the front panel of the SG06 is 0,6mm aluminium, while the SG05 front panel plastic is like 4mm think, then you might be looking at total gain of 13mm. Then it would fit, just about.
Need someone with an SG06 to measure the inside depth of the front panel to confirm smile.gif
WiSK is offline
post #64 of 81 (permalink) Old 11-18-2012, 05:49 PM
NFSxperts's Avatar
Rep: 73 (Unique: 69)
The SG05 definitely won't work. According to thecrim, the Gigabyte GTX 670 is Exactly 276mm long.
The longest gpu known to fit in the SG05 if you cut the front frame is the reference GT280 with is 10.5 inches (267 mm). Link here
I would say the sg06 might have less than 1cm of space so that still wouldn't be enough/
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #65 of 81 (permalink) Old 11-19-2012, 01:08 AM
8.2 liters
WiSK's Avatar
Naah it's much wider smile.gif See here Miah's picture of the front part. The top bit with the optical drive is the same depth as the SG05, but the lower part is double the width, and the metal is much thinner than the plastic of the SG05. So it think it can be done.
Edit: Ah ha! We need to ask Machupo how long this 6950 was that he put in his SG06 smile.gif
WiSK is offline
post #66 of 81 (permalink) Old 11-19-2012, 04:02 AM
Machupo's Avatar
Rep: 3 (Unique: 3)
WiSK -- that 6950 (Sapphire) is 274mm long.
To fit it in the SG06, that required removing a section of the metal interior panel (rectangular shape would be the minimum required, but I removed the bulk of the front panel) as well as sanding/grinding down an interior rib of plastic from the main front panel / fascia. I feel confident that there are 2-3mm of room remaining, but it will be darn close!
Machupo is offline
post #67 of 81 (permalink) Old 11-19-2012, 04:12 AM
8.2 liters
WiSK's Avatar
Originally Posted by Machupo View Post
...that 6950 (Sapphire) is 274mm long... I feel confident that there are 2-3mm of room remaining, but it will be darn close!
WiSK is offline
post #68 of 81 (permalink) Old 11-19-2012, 04:52 AM
Machupo's Avatar
Rep: 3 (Unique: 3)
WiSK -- sorry, I take that back, that particular card in the picture was a HIS 6950 2GB, not a Sapphire (I blew up the Sapphire thumb.gif )
The dimensions for the HIS card are listed as 275mm, though, so you're still good on measurements!
Machupo is offline
post #69 of 81 (permalink) Old 11-19-2012, 08:14 AM
Volkswagen's Avatar
Appreciate all of the hard work guys- sounds like it will be very tight...I may just need to try and trade for a reference 670/680 and still go with the SG05.
post #70 of 81 (permalink) Old 11-19-2012, 10:42 AM
sadkatz's Avatar
Rep: 0
Hi guys, I'm using an SG05-450 case and am looking around for a gpu.
1) Has there been anyone successfully installing an HD7970 into an SG05? I've found two people with a Powercolor PCS+ HD7950 in an SG05 in my research, but haven't seen anyone with an HD7970 yet. I checked Powercolor's website and I found the Powercolor HD7970 V3 listed as shorter than the PCS+ HD7950 (265mm vs 275mm)
1)a) I wonder if it's okay to create a new thread on the Graphics forum asking anyone who has a Powercolor HD7970 V3 measure the card redface.gif
2) Will I damage or overheat my internals using a non-blower GPU? Should I just stick with a reference blower style GTX670?
I'm using 3570k with asrock z77 board. Planning to only OC the cpu.
Thanks!
sadkatz is offline
