[Official] Fractal Design Node 304 Owners Club - Page 2 - Overclock.net - An Overclocking Community
post #11 of 7218 (permalink) Old 06-06-2012, 05:35 AM
nexxusdev's Avatar
Rep: 1 (Unique: 1)
dont get the front dual 92mm. They have space for a 120 or even 140
nexxusdev is offline
post #12 of 7218 (permalink) Old 06-06-2012, 07:23 AM
subtec's Avatar
Rep: 58 (Unique: 53)
Originally Posted by funfortehfun View Post
And hurrah, Fractal Design stepped up to remove the frickin' 5.25 drive bays wheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gif
The Array doesn't have 5.25" bays either, which is, AFAIK, Fractal's oldest case. This new case actually seems like a replacement for the Array - a little larger and some layout improvements, but overall very similar.
Actually, they don't: the PSU sits in the front, with the exhaust to the side - much like the SG07/08. That's 87mm of the 210mm height of the case, leaving just 123mm. Add in structural bits and material thickness and 92mm is the largest standard size fan that will fit.
As for fitting a dual 92mm rad in front - you'd lose all the HDD bays and you'd be limited to a video card with a shorter PCB. But it seems doable.
It's a nice case, if a little on the larger side for ITX. Aesthetically, probably the best 'shoebox' style case yet. I'd take this over the SG07/08.
subtec is offline
post #13 of 7218 (permalink) Old 06-06-2012, 07:37 AM
Retired Staff
Riou's Avatar
Rep: 817 (Unique: 626)
Wow that is so gorgeous!
Riou is offline
post #14 of 7218 (permalink) Old 06-06-2012, 08:35 AM
thehidecheck's Avatar
Rep: 32 (Unique: 22)
Actually, word on the street is this will be available august. As a potential future build, Iv'e done a fair bit of snooping and I like what I see. Some less obvious characteristics: It will fit tall coolers(even the d14 with a few mm to spare), airflow looks fantastic, it comes with fractal silent r2 fans(pretty quality stuff), it comes with dust filters for the intake, psu, AND VGA, will retail about $90, comes with a 3 speed fan controller(at the back), and most importantly(;D) amazing gpu ventilation.
Now for my only niggle, psu placement. Dont get me wrong, I agree with the front mounted psu, its the only way to keep an itx form factor with adequate cpu cooler space(I myself prolly gonna stick a havik 140 in there). The problem lies in power cable pass through. Because of this, the psu back cannot sit plush with the left side panel. In pushing the psu towards the middle of the case, gpu clearance will be an issue with power supply cables with psus greater than 160mm in length. I almost think I would have prefered the psu sit plush with the side panel and have a cutout for the power cable pass through to come outside the case. In doing this, or having cutout plates enabling this to be done, they could either allow larger psus or (a greater point)they could keep the 160mm maximum but cut the width of the entire case.
Regardless of my suggestions for this one small niggle, I still think this is a sexy sexy case and should be considered an alternative to the bitfenix prodigy if you want to keep things aircooled.
thehidecheck is offline
post #15 of 7218 (permalink) Old 06-06-2012, 11:10 AM
osaft's Avatar
Rep: 0
NO 5,25'' thumb.gif ...that saves a lot of space and keeps the front clean.
Originally Posted by subtec View Post
The Array doesn't have 5.25" bays either, which is, AFAIK, Fractal's oldest case. This new case actually seems like a replacement for the Array...
The Array is ment to be an...an Array. It was somehow natural for it to leave out the optical.
It first came out without the support of dual-slot cards. Because it most likely only needed to fit a RAID card...
This case however is for your main PC. With tower cooler, big PSU and long graphicscard.
I really dont think the Array would be replaced by that.
i3-2100 @ Thermalright AXP-140 | GTX 560 PHANTOM 850Mhz @ 0.95V | Q07B
osaft is offline
post #16 of 7218 (permalink) Old 06-06-2012, 12:36 PM
CYRUS + KEF + LG OLED....
2002dunx's Avatar
Rep: 42 (Unique: 41)
But there was loads of room under the HDD cage in the Array to squeeze an optical drive in, my PSU sits under there in mine. Allows me space for my H90 cooler.
dunx
2002dunx is offline
post #17 of 7218 (permalink) Old 06-06-2012, 02:08 PM
snikki's Avatar
Rep: 0
I really love the design of this case. I've been planning on doing a SFF build and this will definitely be the case I'll be using. I googled it and found more pics at anandtech. Link---- [=http://www.anandtech.com/Gallery/Album/2033][/]
snikki is offline
post #18 of 7218 (permalink) Old 06-06-2012, 07:02 PM
Jayrock's Avatar
Rep: 36 (Unique: 34)
Just as I was about to buy the bitfenix, I saw this thread. Def opting for this instead. Thanks for the post!
Jayrock is offline
post #19 of 7218 (permalink) Old 06-06-2012, 07:43 PM
staryoshi's Avatar
Rep: 429 (Unique: 310)
A little large for an ITX case, but it's interesting. I prefer ones that use SFX PSUs now that Silverstone is rockin' out the nice 450w units. At least it isn't a gargantuan "SFF" case tongue.gif
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><b><a href="https://www.overclock.net/t/1294303/review-arctic-cooling-accelero-hybrid/0_20">My Arctic Cooling Accelero Hybrid Review</a></b><br><br><a href="#"><strong>My Other Reviews</strong> <span class="spoiler-help">(Click to show)</span></a><span></span><a class="spoiler-link H-spoiler-toggle" href="#"><strong>Warning: Spoiler!</strong> <span class="spoiler-help">(Click to show)</span></a><div class="spoiler-hidden"><br><a href="https://www.overclock.net/hard-drives-storage/989297-sataii-usb2-0-usb3-0-xfast.html"><span style="font-size: 12px;"><span>Quick USB 3.0 Benchmarks</span></span></a><br><span style="font-size: 12px;"><a href="https://www.overclock.net/nvidia/895590-gtx470-vs-gtx570-comparison.html">GTX470 vs GTX570 Comparison</a></span><br><a href="https://www.overclock.net/nvidia/835606-evga-gts-450-review-tons-content.html">EVGA GTS450 Review</a><br><a href="https://www.overclock.net/computer-cases/855693-myopenpc-dragon-bench-review-build-log.html">MyOpenPC Dragon Review and Build Log</a><br><a href="https://www.overclock.net/nvidia/793143-msi-gtx460-1gb-sli-review.html">GTX460 1GB SLI Review</a><br><a href="https://www.overclock.net/nvidia/778125-evga-gtx460-1gb-superclock-review.html">EVGA GTX460 1GB SC EE Review</a><br><a href="https://www.overclock.net/nvidia/800329-gtx460-1gb-vs-gtx465-review.html">GTX460 1GB vs GTX465</a><br><a href="https://www.overclock.net/ati/705552-5850-vs-5870-comparison-benchmarks.html">HD5850 vs HD5870 Comparison</a><br></div></div></div>
staryoshi is offline
post #20 of 7218 (permalink) Old 06-07-2012, 04:00 AM
enkay's Avatar
Rep: 35 (Unique: 32)
enkay is offline
