[Official] Fractal Design Node 304 Owners Club - Overclock.net - An Overclocking Community
post #1 of 7243 (permalink) Old 06-05-2012, 05:50 PM - Thread Starter
Did you say Abe Lincoln?
.theMetal's Avatar
Rep: 89 (Unique: 74)
________________________________________________________________________________
Welcome to the Official Fractal Design Node 304 Owners/Info Club
Information*:
The Node 304 features a unique modular interior for outstanding configurability.
The Node 304 accommodates up to six hard drives. Unused mounting brackets can be removed to allow for long graphic cards, additional airflow or more space for organizing cables. Additionally, it is equipped with three hydraulic bearing fans, easy-to-clean air filters in all intakes and two front USB 3.0 ports.
Featuring hybrid functionality, the Node 304 case is ideally used as a cool-running file server, a stylish and quiet home theatre PC or a powerful gaming system highlighting minimalistic and stunning Scandinavian design and maximum functionality.
Features:
  • Compact, modular interior
  • Minimalistic design with an elegant aluminum front panel
  • Unique new modular mounting system that accommodates up to 6 hard drives
  • Accommodates tower CPU coolers and single-fan water cooling systems
  • Filtered air intakes ensure a dust-free environment for internal components
  • Three Silent Series R2 hydraulic bearing fans included
  • Excellent cooling for all components
  • Accommodates ATX power supplies
  • Fan controller for all fans included
  • USB 3.0 for fast file transfers
Technical Specs*: Here (Click to show)
  • Mini ITX, DTX motherboard compatibility
  • 2 expansion slots
  • 6 – supports either 3.5" or 2.5" HDD / SSD
  • ATX PSUs, up to 160mm in length (To fit in combination with a long graphics card, PSUs with modular connectors on the back typically need to be shorter than 160 mm)
  • Graphics cards, up to 310mm in length, when 2 HDD brackets are removed (Graphics cards longer than 170 mm will conflict with PSUs longer than 160mm)
  • Tower CPU coolers, up to 165 mm tall
  • Case dimensions (W x H x D): 250 x 210 x 374 mm
  • Case volume: 19,5 Liters
  • Net weight: 4,9 kg
  • Colors available: Black and White
Cooling / ventilation:
  • 2 - Front mounted 92mm Silent Series R2 hydraulic bearing fans, 1300 RPM speed (compatible with 80mm fans) – included
  • 1 - Rear mounted 140mm Silent Series R2 hydraulic bearing fan, 1000 RPM speed (compatible with 120mm fans) – included
  • Removable air filters for front fans and PSU
  • Fan filter for graphics card
  • 1 - fan controller for all 3 fans included
Front interface:
  • 2 - USB 3.0 (Internal 3.0 to 2.0 adapter included)
  • 1 - 3.5mm audio in (microphone)
  • 1 - 3.5mm audio out (headphone)
  • Power button with LED
  • HDD LED
Retail package content:
  • Node 304 computer case
  • User manual
  • Accessory box
Additional Information:
  • EAN/GTIN-13: 7350041080978
  • UPC: 817301010979
  • Product code: FD-CA-NODE-304-BL
Product Page:
Black Version
White Version
Reviews:
Guru3d
Think Computers
TweakTown
AnandTech
Hardware Secrets
Owners:
To be added to the list:
From here on out, to be added to the list, just start your post off with "Add me" in bold and leave a picture of your Node. I will get you added as soon as possible.
Tips/Tricks:
  • .theMetal - A smaller power supply works really well, but with some tinkering you can actually fit much bigger, modular supplies in this case with a long graphics card. Simply remove the power supply bracket (4 screws) and move the supply further from the graphics card then mount it down with velcro or two sided tape of some kind. Many of us have done this and it works well.
  • .theMetal - Air cooling works well in the case. From what I've seen I'm almost positive any heat sink will fit in the case and fit is more determined by your itx motherboard than the case its self.
  • Mopar63 - (Magnetic replacement gpu filter) The filter I am using is for the Corsair 400R but it fits perfectly. I have actually removed the filter provides by Fractal and use this one only and am having great results. I am seeing temp 3 to4c lower on my video card and it will allow some cards with 2.5 slot coolers to work where before they were loud.
  • Front Audio/USB Problem - Some owners have seen issues with the front audio out causing strange noises (when moving mouse, when hard drives read, etc.) The problem is addressed here in this thread.
    Basically, there is a problem on the board where the usb and audio out headers sit. To fix it, you take a razer and make a cut down to the copper on the board between the audio and usb ports like this:
    Click for Image (Click to show)
    Thanks to dithes, for talking with Fractal Design and getting a fix. Its reported by a few members to take care of the issue.
    Here is another piece of info if the above does not work.
    For anyone else who may be having a few unruly USB issues with the front sockets:
    I spoke with Fractal about the problem after testing that my 3rd party extension worked fine and following their advice seems to have fixed it for me, was a little unsure at first though:
    "on some motherboard the USB 3 + USB 2 Adapter Cable make an issue.
    Maybe you cut of the USB 2 wire from the USB 2 / 3 Combo cable?
    On some motherboard this fixed the issue."
    The above image was supplied by Fractal too who assured me: "If this dont fix you issue we can change the hole USB PCB + Cable" when I asked about voiding warranty etc.
    Hope that helps, and good luck.
    Thanks to sprucejuice for this information!!
If you any tips or tricks for the case, just let me know and I can add them to the list and give you credit. thumb.gif
Recommended Equipment:
As more and more owners come through the thread, the question we see the most is will this power supply fit? So here is a list of the most threads most recommended equipment.
First off, the power supplies:
- Seasonic G-550
- Silverstone ST55F-G
I will continue to work on this list, but this is a start.
More Pictures*: Black Version Here (Click to show)
White Version Here (Click to show)
Unboxing of White version (Compliments of MetallicAcid**) (Click to show)
Signature:
post-flame-small.gif Official Fractal Design Node 304 Club post-flame-small.gif
[CENTER][URL=https://www.overclock.net/t/1266342/fractal-design-node-304-owners-club/0_20#post_17415246]:clock: Official Fractal Design Node 304 Club :clock:[/URL][/CENTER]
Edits/Notes (Click to show)
7/6/13: I've taken over the thread to turn it from a new case thread to an actual owners club. I am open to suggestions, so please let me know if you have any comments or any thing else to add.
* All information and pictures are from Fractal Design website
**Credit for the unboxing photos of the White version goes to MetallicAcid. (Thanks for letting me use them! -.theMetal)
Spitting in the Stream of Consciousness
Colorado Overclockers
The Donbot
(12 items)
Crushinator
(10 items)
i7 3770 @ (4.2~4.4)
ASUS P8Z77-I Deluxe
MSI 1070 Gaming X
16gig Crucial Tactical LP (@2000)
Crucial BX100 500gb
3TB hard drive
Silverstone ST55F-G
Phanteks PH-TC14PE
Phanteks Evlov ITX
BenQ 27inch IPS (2560x1440)
Keyboard
Blackwidow Tournament
Mouse
Logitech G203 Prodigy
i5 2320
Asrock H61M-VG4
EVGA GTX 970
8gig Samsung LowPro
Samsung 840 Evo 250gb/WD Black 640gb
Rosewill Hive 550
Apevia X-ENERQ Pink
Asus 24 inch (1080p)
Keyboard
Sades Mechanical w/blues
Mouse
Razer Abyssus 2014
.theMetal is offline
post #2 of 7243 (permalink) Old 06-05-2012, 05:53 PM
SohcSTI's Avatar
Rep: 28 (Unique: 24)
I love Fractal Design cases. So clean!
So an iOS 6 user walks into a bar. Or a restaurant. Or a river... I don't even know. biggrin.gif
SohcSTI is offline
post #3 of 7243 (permalink) Old 06-05-2012, 07:23 PM
BobTheChainsaw's Avatar
Rep: 4 (Unique: 4)
Is there any way to have an optical drive? I still buy physical discs now and then.
BobTheChainsaw is offline
post #4 of 7243 (permalink) Old 06-05-2012, 07:32 PM
listen to remix's Avatar
Rep: 88 (Unique: 72)
Holy crap...First the Prodigy Case and now this one. Makes me regret my mATX build.
listen to remix is offline
post #5 of 7243 (permalink) Old 06-05-2012, 07:40 PM
funfortehfun's Avatar
Rep: 109 (Unique: 94)
The size of this is only a bit larger than the Sugo's. This case isn't a monstruo like the Prodigy, either. I can see this as being a pretty good case. I'm digging the brushed aluminum, too.
And hurrah, Fractal Design stepped up to remove the frickin' 5.25 drive bays wheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gifwheee.gif
flickr | Camera Hardware: Nikon D90 + AF-S DX Nikkor 12-24 f/4G + AF-S DX Nikkor 35mm f/1.8G + AF-S micro-Nikkor 105mm f/2.8G + Yongnuo YN-560 III + Crumpler 7MDH wheee.gif
Hilarious Quotes (Click to show)
Question - the dollar sign goes before U.S. monetary amounts. If I am speaking in terms of Canadian dollars, do I put CAD before or after the amount?
you put it on top like a hat, i.e. canada aka USA's hat
CAD
3.50
funfortehfun is offline
post #6 of 7243 (permalink) Old 06-05-2012, 07:45 PM
Linux Lobbyist
Rep: 435 (Unique: 327)
My question is, when and where can I get one?
Quick question though, how is having steel armor in skyrim like having an ipad in world war 2? If the U.S stormed normandy with ipads i'm pretty sure we would all be speaking german about now.
Scorpion49 is offline
post #7 of 7243 (permalink) Old 06-05-2012, 07:57 PM
Rep: 37 (Unique: 34)
Use an external drive, alot of them are USB powered and bootable.
No word on this yet.
headphone.gifXonar U3 (Transport) -> Optical Out -> Yulong D100 -> Beyerdynamic DT880 (600 Ohm) headphone.gif
subnet is offline
post #8 of 7243 (permalink) Old 06-06-2012, 02:30 AM
Rep: 55 (Unique: 52)
very beautiful case, very well designed.
My next build will be in this case.
adjas is offline
post #9 of 7243 (permalink) Old 06-06-2012, 03:57 AM
lAptOp jUnKie
drBlahMan's Avatar
Rep: 243 (Unique: 210)
Nice case but would of been even better if those front fans were 120mm, imo thinking.gif
Buy usb external optical drive & follow these instructions...How to Boot from the USB CD Drive
drBlahMan is offline
post #10 of 7243 (permalink) Old 06-06-2012, 04:06 AM
aCe_eXtreME's Avatar
Rep: 57 (Unique: 49)
this , who uses a cdrom? i havent in years , if i needed to i use a temp one. there has not been one in my case for atleast 9 years. its noisy and wastes space.
u can use virtual cdrom program , there are many free out there that work great.
NICE case love the simplicity of lay out and how the back fan is almost made for water cooling. i wonder how "sturdy" or solid the case actually is . that would be a seller for me if it the frame feels solid
aCe_eXtreME is offline
