[Official] uSFF/SFF Club - Page 101 - Overclock.net - An Overclocking Community
post #1001 of 2861 (permalink) Old 09-29-2014, 01:57 AM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by blooder11181 View Post
here the pics of my sff and smaler rigs pics
compaq evo d510
compaq evo d500 usdt
These look like 2u servers.
how come you've removed your previous post of the HP dc7700?
https://www.overclock.net/t/1300645/official-usff-sff-club/400#post_21681251
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #1002 of 2861 (permalink) Old 09-29-2014, 04:34 AM
blooder11181's Avatar
Rep: 44 (Unique: 41)
i dont have the dc7700 anymore
i sold it and it was a bad idea because my last to rigs are slower
NVIDIA and AMD(ATI)
INTEL and AMD
i love them all
APPLE OBSOLETE RIGS USER BUT STILL GOOD
blooder11181 is offline
post #1003 of 2861 (permalink) Old 09-30-2014, 10:12 AM
Smanci's Avatar
Rep: 75 (Unique: 64)
I retired my VX550W. It's served my needs very well since '08 but being non-modular and only rated at 80 plus, it's not the ideal choice for an SFF build. redface.gif
Idling @ 33 Watts speedstep disabled!
Smanci is offline
post #1004 of 2861 (permalink) Old 09-30-2014, 10:52 AM
Linux Lobbyist
Wanou's Avatar
Rep: 30 (Unique: 21)
Wanou is offline
post #1005 of 2861 (permalink) Old 10-06-2014, 09:30 AM
SilkyZ's Avatar
Rep: 2 (Unique: 2)
BTW, has anyone seen how small Zotac made the board on thier 970?
They say the total length of the card is about 208mm, that would make it able to fit in a TU100 or a CM 110. Reviews arn't half bad either.
SilkyZ is offline
post #1006 of 2861 (permalink) Old 10-06-2014, 12:53 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Warning: Picture ahead! (Click to show)
Yes, I've seen that biggrin.gif And according to @ccRicers, it is even shorter without the shroud, 191mm to be exact. It can fit nearly anywhere. I am in the planning phase of putting one into a LianLi PC-Q12, and from everything I've tested and measured, it will fit nicely.
iFreilicht is offline
post #1007 of 2861 (permalink) Old 10-06-2014, 01:01 PM
SilkyZ's Avatar
Rep: 2 (Unique: 2)
I am wondering how you plan on pulling that off. That case doesn't even have an expansion slot.
Closest thing I found was someone cutting out a single slot
SilkyZ is offline
post #1008 of 2861 (permalink) Old 10-06-2014, 01:04 PM
greywarden's Avatar
Rep: 22 (Unique: 19)
I should be getting my final pieces in today, I'll report back shortly!
hail sithis!
greywarden is offline
post #1009 of 2861 (permalink) Old 10-06-2014, 01:44 PM
iFreilicht's Avatar
Build log can be found here. In short, I will do the following:
  • use a FlexATX PSU with dimensions of 81*150*40.5mm, which will sit directly at the bottom,
  • make a custom Motherboard mount that will put the MB in direct touch with the upper wall of the case.
  • use a flexible riser card to position the GPU flat in the case, partially over the MB.
  • remove the shroud of the GPU to shorten it to 191mm
I already tried it out with cardboard mock ups in the real case, and it will actually work biggrin.gif
The layout picture probably explains it best:
post #1010 of 2861 (permalink) Old 10-06-2014, 01:45 PM
ccRicers's Avatar
Rep: 72 (Unique: 66)
Pic ahead (Click to show)
Clean build, man. Here is my U2 build
I'll be putting it under water soon.
ccRicers is offline
