[Official] uSFF/SFF Club - Page 105 - Overclock.net - An Overclocking Community
post #1041 of 2861 (permalink) Old 10-13-2014, 06:17 PM
Rep: 10 (Unique: 9)
I just looked up the ASrock board, that CPU is an impressive performer for the tiny 10w TDP.
void is offline
post #1042 of 2861 (permalink) Old 10-15-2014, 02:28 AM
Hasdrubal's Avatar
Rep: 5 (Unique: 5)
I installed my wife's new computer in a In Win H-Frame Mini (green), can I join the club? Pictures to follow later.
Hasdrubal is offline
post #1043 of 2861 (permalink) Old 10-15-2014, 12:43 PM
mbondPDX's Avatar
Rep: 5 (Unique: 5)
Finally finished my NCASE M1 build. Couldn't be happier with the results!
mbondPDX is offline
post #1044 of 2861 (permalink) Old 10-15-2014, 12:46 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Originally Posted by mbondPDX View Post
Finally finished my NCASE M1 build. Couldn't be happier with the results! Warning: Prequel! (Click to show)
This case is so perfectly designed. Really cool idea with the two fans blowing on a passive cooler! thumb.gif
iFreilicht is offline
post #1045 of 2861 (permalink) Old 10-15-2014, 12:51 PM
Stock
hyp36rmax's Avatar
Rep: 144 (Unique: 122)
Warning: Spoiler! (Click to show)
hyp36rmax is offline
post #1046 of 2861 (permalink) Old 10-15-2014, 01:22 PM
frack0's Avatar
Rep: 23 (Unique: 22)
Finally finished my NCASE M1 build. Couldn't be happier with the results! Warning: Spoiler! (Click to show)
Nice! Looks much cleaner than a lot of the M1 builds I've seen
frack0 is offline
post #1047 of 2861 (permalink) Old 10-15-2014, 01:27 PM
Ultra-m-a-n's Avatar
Rep: 111 (Unique: 67)
What cooler is that on the M1 system?
Ultra-m-a-n is offline
post #1048 of 2861 (permalink) Old 10-15-2014, 01:56 PM
mbondPDX's Avatar
Rep: 5 (Unique: 5)
Agreed! Wahaha and Necere really outdid themselves.
Originally Posted by hyp36rmax View Post
Thanks! I'm glad I saved a few from my old 800d build.
Aw shucks, thanks!
It's a Noctua NH-C14.
mbondPDX is offline
post #1049 of 2861 (permalink) Old 10-15-2014, 03:54 PM
Rep: 160 (Unique: 133)
Looks almost exactly like mine before I switched to a better fan setup. Glad you enjoy it!
Tennobanzai is offline
post #1050 of 2861 (permalink) Old 10-17-2014, 01:44 AM
seriva's Avatar
Rep: 0
Originally Posted by seriva View Post
Specs:
Case: Chieftec IX-01Bl
Proc: AMD A10-7700K Black Edition
Mobo: ASRock FM2A88X-ITX+
Memory: Corsair Vengeance LP 8GB 2133MHz CL11
SSD: Crucial M500 mSata 120GB
HDD: WD Blue WD5000LPVX, 500GB
CPU Cooler: Zalman CNPS2X
Case FAN: 50 mm, 3500 rpm
OS: Windows 8.1 Pro
Power: picoPSU-160-XT
Pics:
I`m not sure about the size of the case in liters but its super small. The A10-7700K is slightly under clocked and volted to keep the temperatures down. Idle is +-40 degrees and under full load around 67 degrees. Power usage is 40 watt idle and 95 watt under full load.
I plan to swap out the current msata SSD, HDD and the 50 mm fan and put in a 500 gb msata SSD and a 120 mm slim fan later on. I hope that then I can even overclock it a bit.
I have updated my rig. The A10-7700k has been replaced by a A10-7850K, The memory has been upgraded from 2133mhz to 2400mhz. Finally the 500 GB harddrive and the 120 BG msata drive have been replaced by a single 480 GB msata drive.
The 40 mm fan has been removed and I have added a 120 mm scythe slim fan I had laying around. For this I cut out an air hole to make the airflow less upstructed. Cooling is great with idle temperatures of 35 degrees and 65 under full load. Even with an overclocked GPU from 720 to 1050 mhz biggrin.gif The best part is that the CPU cooler is not even spinning up more then 1600 rpm under full load and the 120 mm is running at 800 rpm so the thing is near silent now
Some images for your enjoyment:
I`m planning one final upgrade. The 120 mm fan is going to be replaced with this Proloma 140 mm slim fan:
The current Zalman CNPS2X CPU cooler is going to be replaced with the Noctua NH-L9a. I will remove the original fan of the Noctua and I hope the Proloma 140 mm fan will give enough airflow to keep the thing cool:)
seriva is offline
