[Official] uSFF/SFF Club - Page 143 - Overclock.net - An Overclocking Community
post #1421 of 2861 (permalink) Old 04-07-2015, 01:50 AM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by QinX View Post
As I had mentioned I couple of pages back I was in the middle of planning my own custom build.
It's pretty much done! only paint/anodising left to do.
The size of the case is:
Without the front and back lips
21.75 cm x 26.225 cm x 4.76 cm = 2.715L
With the front and back lips:
21.75 cm x 27.5 cm x 5.81 cm = 3.475L
Specs:
CPU: Core i5-4670
Mobo: ASUS Q87T
GPU: GeForce GTX 970
RAM: 1x4GB SODIMM
PSU: 350W External brick/250W HD-Plex DC-DC Board
SSD: Sandisk 128GB X110 mSATA
Cooling:
Custom GPU and CPU block, Custom Radiator(2x80mm rad, 30FPI, 28.6mm thick) and a Custom reservoir
Buildlog can be found here
Added. If you're going to use 2 power adapters, how will you be combining the 2 together?
Also, next time could you take the picture with a clean background? It was hard to cutout the case for the thumbnail.
Originally Posted by xpinkkittehx View Post
Warning: Spoiler! (Click to show)
Your receiver is so close to the gpu intake vents. Does the 780 have enough cooling?
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #1422 of 2861 (permalink) Old 04-07-2015, 01:56 AM
QinX's Avatar
Rep: 6 (Unique: 6)
I will make keep it in mind for next time, I'm in the middle of setting up a dedicated room for my PC/Builds and will be making room for better photography.
with regards to the 2 Adapter, 1 adapter will go straight into the motherboard and power the CPU,SSD etc. the other adapter is dedicated for the GPU and the case will have a second DC Inlet that is connected to the GPU.
QinX is offline
post #1423 of 2861 (permalink) Old 04-10-2015, 03:30 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Here's a quick teaser of the scratch build planning to do in the next couple of months:
This case will fit my current hardware (GTX970, FlexATX PSU, mITX board, 2.5"x9.5mm HDD) in an even lower volume.
414(H)*60(W)*197(D)mm < 4.9L
iFreilicht is offline
post #1424 of 2861 (permalink) Old 04-10-2015, 03:59 PM
ccRicers's Avatar
Rep: 72 (Unique: 66)
Looks good, almost like my design. My custom case will be more square in shape (side view that is, not a cube).
ccRicers is offline
post #1425 of 2861 (permalink) Old 04-10-2015, 04:43 PM
Dimensive's Avatar
Rep: 227 (Unique: 140)
Submitting my latest SFF build using the Hadron Air. All about emulation on this rig.
Mimic build log: https://www.overclock.net/t/1548240/build-log-mimic-emulation-rig/
Dimensive is offline
post #1426 of 2861 (permalink) Old 04-11-2015, 03:31 AM
iFreilicht's Avatar
Does the Slim Machine already have an outside design already? Didn't see one in your build log.
I love that case so much, even if just for the PSU biggrin.gif And that 960 has the most odd connector placement I've seen so far. Will you place this next to your TV or under the desk?
post #1427 of 2861 (permalink) Old 04-11-2015, 06:31 AM
Dimensive's Avatar
Yea, I'm used to the connector being near the end of the GPU, but it works just fine either way. I put it in my entertainment center in between my 360 & PS3.
post #1428 of 2861 (permalink) Old 04-11-2015, 06:33 AM
iFreilicht's Avatar
Yea, I'm used to the connector being near the end of the GPU, but it works just fine either way. I put it in my entertainment center in between my 360 & PS3. Warning: Spoiler! (Click to show)
Ah that seems like the perfect place for it. Really fits the rest of your entertainment setup. thumb.gif
post #1429 of 2861 (permalink) Old 04-15-2015, 10:14 AM
ivoryg37's Avatar
Rep: 19 (Unique: 19)
I just got my lone industries l3 yesterday and it makes the evga hadron look like an atx case lol
ivoryg37 is offline
post #1430 of 2861 (permalink) Old 04-15-2015, 11:04 AM
remixedMind's Avatar
Rep: 13 (Unique: 10)
remixedMind is offline
