[Official] uSFF/SFF Club - Page 159 - Overclock.net - An Overclocking Community
post #1581 of 2861 (permalink) Old 06-07-2015, 12:17 AM
remixedMind's Avatar
Rep: 13 (Unique: 10)
remixedMind is offline
post #1582 of 2861 (permalink) Old 06-07-2015, 12:24 AM
tabascosauz's Avatar
Rep: 9 (Unique: 7)
Anyone who's looking to build in the SG08 in the near future: remember to make up your mind completely on the CPU/cooler/motherboard/RAM combo before placing the motherboard in its eternal resting place. It's a real pain to change anything once you're done. A lot of SFF cases cannot accommodate a CPU cooler backplate cutout, but the SG08 goes a step further. Unless you are going solid-state only by duct taping it to the top of the PUS, as well as using either the ST45SF-G or SX600-G, it's going to be very hard to fiddle with the motherboard and the cooler components; just getting the board in and out is a pain. The PSU area frame has a protrusion over the motherboard, supposedly to connect with the hard drive cage, which also limits the space over the motherboard.
My two rigs are swapping places because I want more power to be in the SG08 and both to eventually go ITX (with SG08 in either a Mercury S3/Nova X2 and the Mini R2 in a smaller HTPC case), so I went and switched the 4160 and 4790K today. It should've been a simple switcheroo, but no, since the U9B goes wherever the i7 goes, with the stock cooler being too weak to handle the beefier CPU. Since the SG08 rig initially had the stock cooler over the i3-4160, it took a lot of wrestling to get the U9B and SecuFirm seated. I was also unable to swap the R7 265 and R9 280X as I initially wished; the SG08 can accommodate long cards and ones that are slightly more than 2 slots, but is very picky regarding cards that are taller than the PCIe bracket, because the annoying internal power cord extension gets in the way.
tabascosauz is offline
post #1583 of 2861 (permalink) Old 06-07-2015, 08:18 AM
Allanitomwesh's Avatar
Rep: 52 (Unique: 35)
@Wisk yeah I do,read it in this article
www.tomshardware.com/news/corsair-sf600-sfx-psu,29317.html
Good things come to those who wait.
Allanitomwesh is offline
post #1584 of 2861 (permalink) Old 06-09-2015, 04:06 PM
ShengLong16's Avatar
Rep: 1 (Unique: 1)
Just wanted to share this build with The SFF Club
specs
I7 4790k at 4.6 GHZ
Zotac GTX 980 OC 1490 Mhz
16 GB Ram at 2400mhz
Crucial M100 512GB SSD
EK full cover waterblock
Bitspower Fittings
aquacomputer Fabwerk
RBG LED (lighting changes based on CPU Temp)
Here are some Pics
ShengLong16 is offline
post #1585 of 2861 (permalink) Old 06-09-2015, 06:53 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by cdoublejj View Post
and it's not half bad!!! i found a 65 watt core 2 quad for about $30 USD SHIPPED! the original dual core was 65 watts. i had 4gb of ddr2 800 i got for free. i dropped in a cheap ssd and 5tb hdd and an $11 usb 360 receiver. i have ventilated the case and replaced most of the capacitors in the power supply.
This slot does indeed go in to the PSU, it cut the PSU temps in half they had to be ATLEAST 90c the caps inside are rated for 105c and they all bulged and leaking. likely not purely due to temps but, also age. it was so hot the out case cover was warm to the touch and the air coming out was rather warm. now only luke war air comes out the slot the is right in front of one of the internal PSU heat sinks so think that is why it helps so well.
i found where that black missing screw i forgot to reinstall goes! biggrin.gif i also need a VGA cover for the old VGA connector.
i just need a GT 730 or GTX 750 Ti, also wanna embed the wireless controller receiver. cpu never seems to go about high 40s or 50c tops. HDD never really seems to get more than luke warm.
Is that a Dell Optiplex 755? Nice mods BTW
specs
I7 4790k at 4.6 GHZ
Bitspower Fittings
Here are some Pics
Sweet. Our second EVGA Hydro case. Got any pics of the back?
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #1586 of 2861 (permalink) Old 06-09-2015, 08:30 PM
cdoublejj's Avatar
Rep: 241 (Unique: 201)
indeed it is. if i could just get a 750 ti in it and further reduce GPU temps it'd be golden.
Alienware M17x-R4
(18 items)
Core 2 Haf
(12 items)
i7-3920XM
GTX980M
G.SKILL Ripjaws 32GB Model F3-1866C10Q-32GRSL
Samsung SSD 850 EVO mSATA 1TB
WD Blue 5400 RPM 1TB
ODD Conversion w/ White Label 2TB
Empty / Free Bay
Optical Drive
Converted External USB
Dell 330 Watt Brick
M14x R2 10 CFM CPU fan
Liquid Metal Pro
Operating System
Windows 10 /w Telemetry Block
1080p 120Hz eDP
Sony FW900 @ 2304 x 1440 @ 80hz
Keyboard
Saitek Eclipse I
Mouse
Logitech G500s
Other
Intel Dual Band Wireless-AC 7260 w/ BT
Other
iGPU disable / bypass
Q8002S
GTX 750 Ti
DDR2 800 Kingston
C2Q Q9550
ASUS P5E3 Deluxe Wifi-AP
EVGA GTX 770 4GB Classified
Kingston HyperX DDR3 KHX1600C9D3K2/8G
PNY 1333
55gb, 320Gb, 500GB, 1TB
TX750
Corsair H80
Haf 912
Operating System
Win 7 Ultimate 64bit
Operating System
Lubuntu 16.04 x64
Dual 1600x1200 Dell m993s @ 70hz
cdoublejj is offline
post #1587 of 2861 (permalink) Old 06-10-2015, 05:42 AM
Linux Lobbyist
Wanou's Avatar
Rep: 30 (Unique: 21)
specs
I7 4790k at 4.6 GHZ
Bitspower Fittings
Here are some Pics Warning: Spoiler! (Click to show)
Wanou is offline
post #1588 of 2861 (permalink) Old 06-10-2015, 11:28 AM
Rep: 1 (Unique: 1)
Here is the requested pic of the back.... also will be installing this soon
post #1589 of 2861 (permalink) Old 06-10-2015, 11:33 AM
Rep: 1 (Unique: 1)
Thanks Wanou...
I am having another hadron chassis painted in an auto paint and installing the faceplate above wich is a anodized brushed aluminium. The hole is for a RGB antivandal switch.
post #1590 of 2861 (permalink) Old 06-11-2015, 01:28 AM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Thanks Wanou...
Where can you get RGB vandal switches from? I've only ever seen dual LED ones.
iFreilicht is offline
