[Official] uSFF/SFF Club - Page 161 - Overclock.net - An Overclocking Community
post #1601 of 2861 (permalink) Old 06-17-2015, 09:12 AM
cdoublejj's Avatar
Rep: 241 (Unique: 201)
Originally Posted by CynicalUnicorn View Post
Be warned that it's a slot and a half high unless you swap the cooler. Should be a good upgrade if it fits though. thumb.gif
that's not tooooo bad, it's a true dual slot it will have to go in to the HTPC or go back but, 1.5 slot should be doable or just barley do able.
Alienware M17x-R4
(18 items)
Core 2 Haf
(12 items)
i7-3920XM
GTX980M
G.SKILL Ripjaws 32GB Model F3-1866C10Q-32GRSL
Samsung SSD 850 EVO mSATA 1TB
WD Blue 5400 RPM 1TB
ODD Conversion w/ White Label 2TB
Empty / Free Bay
Optical Drive
Converted External USB
Dell 330 Watt Brick
M14x R2 10 CFM CPU fan
Liquid Metal Pro
Operating System
Windows 10 /w Telemetry Block
1080p 120Hz eDP
Sony FW900 @ 2304 x 1440 @ 80hz
Keyboard
Saitek Eclipse I
Mouse
Logitech G500s
Other
Intel Dual Band Wireless-AC 7260 w/ BT
Other
iGPU disable / bypass
Q8002S
GTX 750 Ti
DDR2 800 Kingston
C2Q Q9550
ASUS P5E3 Deluxe Wifi-AP
EVGA GTX 770 4GB Classified
Kingston HyperX DDR3 KHX1600C9D3K2/8G
PNY 1333
55gb, 320Gb, 500GB, 1TB
TX750
Corsair H80
Haf 912
Operating System
Win 7 Ultimate 64bit
Operating System
Lubuntu 16.04 x64
Dual 1600x1200 Dell m993s @ 70hz
cdoublejj is offline
post #1602 of 2861 (permalink) Old 06-19-2015, 07:08 PM
ivoryg37's Avatar
Rep: 19 (Unique: 19)
Is there any cheap cases that are about the same size as the ISK-110 with a PCIe slot? I'm currently using the ISK-110 for a PFsense build but want to add a pcie wireless card to it.
ivoryg37 is offline
post #1603 of 2861 (permalink) Old 06-19-2015, 09:26 PM
InfraRedRabbit's Avatar
Rep: 11 (Unique: 11)
Lone Industries L3 has 2 slots - but its te best option i can think of apart from maybe a Streacom chassis
quietpc have a full range of streacom chassis if you want to suss them out
InfraRedRabbit is offline
post #1604 of 2861 (permalink) Old 06-20-2015, 04:07 AM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Technically, it only has 1.5 slots as you can only mount a single PCIe bracket on the back but the case allows for more space to make Low-profile GPUs fit. The space where the second bracket would normally go is vented and a little bit smaller than it would need to be for a second bracket to fit.
iFreilicht is offline
post #1605 of 2861 (permalink) Old 06-20-2015, 11:50 AM
ivoryg37's Avatar
I currently have a L3 but I don't think I want to spend that much again on a case for a PFsense router lol. I was trying to get one under the 50$ range with a pcie slot so that I can still afford a picopsu as well lol
ivoryg37 is offline
post #1606 of 2861 (permalink) Old 06-20-2015, 02:35 PM
iFreilicht's Avatar
So I've hit a wall with my current project when choosing a flex riser to use. I know the manufacturer already, but the question is whether I want a right or left angled riser.
With the right angle, I have a shorter ribbon cable and better airflow for the GPU exhaust, but I would need to make the case slightly thicker and it would prevent me from moving the GPU down a bit and swapping fans later on.
With the left angle, the side exhaust of the GPU is blocked a little bit, but it allows the case to be as slim as possible and gives more flexibility with the exact placement of the GPU.
If you could help me out here, I would be very grateful.
post #1607 of 2861 (permalink) Old 06-20-2015, 11:44 PM
cdoublejj's Avatar
well it doesn't fit. i removed the shroud and it does. i'll have to see if i can find a way too actively cool it well enough to stay below 100c under extended heavy use. all else fails i can find another use for it.
Alienware M17x-R4
(18 items)
Core 2 Haf
(12 items)
i7-3920XM
GTX980M
Empty / Free Bay
Optical Drive
Dell 330 Watt Brick
Liquid Metal Pro
Operating System
1080p 120Hz eDP
Keyboard
Saitek Eclipse I
Mouse
Logitech G500s
Other
Other
Q8002S
GTX 750 Ti
DDR2 800 Kingston
C2Q Q9550
PNY 1333
TX750
Corsair H80
Haf 912
Operating System
Operating System
Lubuntu 16.04 x64
post #1608 of 2861 (permalink) Old 06-21-2015, 02:44 AM
iFreilicht's Avatar
Originally Posted by cdoublejj View Post
Warning: Spoiler! (Click to show)
I guess using a 2.5" drive instead isn't an option? Because that would give you plenty of room.
post #1609 of 2861 (permalink) Old 06-21-2015, 10:16 AM
cdoublejj's Avatar
yeah my thoughts exactly. that's a 5tb so my movies and steam library will actually fit and the drive not be 99.9% full. the 5tb is already 45%-55% full. i'm gonna see if i can get a better flowing fan at the END of the heat sink. depsite being upside down BTX or what ever, Dell DID put some air holes next to the DVI/HDMI port are despite not begin design for more than single slot card. so there is a place for it to escape. and of course i can always drill more holes. biggrin.gif i've also though about taking a laptop heatpipe sink and bolting it to the core and since they have 90 degree bends using a the laptop cpu fan to put the air out the side of the case. being around 60 watts that might be doable. especially if i AS5 epoxy a second and or more heatsink(s) on the heat pipe or existing heatsink(s)
Alienware M17x-R4
(18 items)
Core 2 Haf
(12 items)
i7-3920XM
GTX980M
Empty / Free Bay
Optical Drive
Dell 330 Watt Brick
Liquid Metal Pro
Operating System
1080p 120Hz eDP
Keyboard
Saitek Eclipse I
Mouse
Logitech G500s
Other
Other
Q8002S
GTX 750 Ti
DDR2 800 Kingston
C2Q Q9550
PNY 1333
TX750
Corsair H80
Haf 912
Operating System
Operating System
Lubuntu 16.04 x64
post #1610 of 2861 (permalink) Old 06-21-2015, 01:53 PM
iFreilicht's Avatar
You know that there's a 2TB 2.5" drive by Samsung that's just 9.5mm thick, right? You could easily put two, maybe even three of those in your rig, giving you similar storage with better thermals for the GPU.
