[Official] uSFF/SFF Club - Page 166 - Overclock.net - An Overclocking Community
post #1651 of 2861 (permalink) Old 06-27-2015, 03:37 PM
Jimbags's Avatar
Rep: 83 (Unique: 73)
Originally Posted by cdoublejj View Post
if you look there is no fan at all what so ever, however i did wire up a toshiba laptop fan directly to the power supply. (with plug of course) the question is what are the voltage and how long will that fan last. it runs full tilt non stop. idle temps where in the 30s.
The thing about factory OCed video card is every once in a while 1 or 2 cards will not be fully stable and stutter.
If its factory OC'd then it should be stable and not stutter? I dont see why you said that? What cooling did it have to start with?
Jimbags is offline
post #1652 of 2861 (permalink) Old 06-27-2015, 03:47 PM
cdoublejj's Avatar
Rep: 241 (Unique: 201)
dual fans but, there area quite a few posts here on OCN where people complain about stutter on factory oced cards, they told to download an OC utility, under clock and low and behold and the stuttering stops. the binning/testing procedures at the factory aren't always perfect. then again defective products are nothing new. tongue.gif
Alienware M17x-R4
(18 items)
Core 2 Haf
(12 items)
i7-3920XM
GTX980M
G.SKILL Ripjaws 32GB Model F3-1866C10Q-32GRSL
Samsung SSD 850 EVO mSATA 1TB
WD Blue 5400 RPM 1TB
ODD Conversion w/ White Label 2TB
Empty / Free Bay
Optical Drive
Converted External USB
Dell 330 Watt Brick
M14x R2 10 CFM CPU fan
Liquid Metal Pro
Operating System
Windows 10 /w Telemetry Block
1080p 120Hz eDP
Sony FW900 @ 2304 x 1440 @ 80hz
Keyboard
Saitek Eclipse I
Mouse
Logitech G500s
Other
Intel Dual Band Wireless-AC 7260 w/ BT
Other
iGPU disable / bypass
Q8002S
GTX 750 Ti
DDR2 800 Kingston
C2Q Q9550
ASUS P5E3 Deluxe Wifi-AP
EVGA GTX 770 4GB Classified
Kingston HyperX DDR3 KHX1600C9D3K2/8G
PNY 1333
55gb, 320Gb, 500GB, 1TB
TX750
Corsair H80
Haf 912
Operating System
Win 7 Ultimate 64bit
Operating System
Lubuntu 16.04 x64
Dual 1600x1200 Dell m993s @ 70hz
cdoublejj is offline
post #1653 of 2861 (permalink) Old 06-27-2015, 03:58 PM
Rep: 10 (Unique: 9)
Yeah, I have personally had a pretty hit or miss experience with factory OC cards and stability.
void is offline
post #1654 of 2861 (permalink) Old 06-27-2015, 08:05 PM
Jimbags's Avatar
Wow I never realised , I've always been lucky I guess. If I got a card that stuttered out of the box I'd return it, wouldn't you? rolleyes.gif
Jimbags is offline
post #1655 of 2861 (permalink) Old 06-27-2015, 11:26 PM
Rep: 10 (Unique: 9)
I probably was just unlucky, but yes they were RMA'd. A couple had weird issues like only crashing in Blizzard games but running other stuff (source engine) fine.
void is offline
post #1656 of 2861 (permalink) Old 06-28-2015, 10:45 PM
cdoublejj's Avatar
ypu certain game engines ultilize only certain parts of the gpu.
Alienware M17x-R4
(18 items)
Core 2 Haf
(12 items)
i7-3920XM
GTX980M
Empty / Free Bay
Optical Drive
Dell 330 Watt Brick
Liquid Metal Pro
Operating System
1080p 120Hz eDP
Keyboard
Saitek Eclipse I
Mouse
Logitech G500s
Other
Other
Q8002S
GTX 750 Ti
DDR2 800 Kingston
C2Q Q9550
PNY 1333
TX750
Corsair H80
Haf 912
Operating System
Operating System
Lubuntu 16.04 x64
post #1657 of 2861 (permalink) Old 06-29-2015, 01:25 AM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
While technically somewhat correct that is a very crude statement to make. Of course not all engines utilise the full potential and the full feature-set of a GPU, but that's got little to do with them not utilising all "parts" of the GPU. As long as there is no bottleneck between the GPU and CPU and the game doesn't implement VSync in software, the GPU will render as many frames as possible. It is very unlikely that Blizzard games use a certain feature inside the GPU that no other game engine uses which somehow gets unstable with higher clocks. The problem is quite certainly a lot more delicate than that. Maybe they use it way more often than other engines, maybe it's a certain combination of functional units that had a small manufacturing error which only comes into play at high clocks and when they're all used at once.
iFreilicht is offline
post #1658 of 2861 (permalink) Old 06-29-2015, 08:47 AM
cdoublejj's Avatar
indeed.
Alienware M17x-R4
(18 items)
Core 2 Haf
(12 items)
i7-3920XM
GTX980M
Empty / Free Bay
Optical Drive
Dell 330 Watt Brick
Liquid Metal Pro
Operating System
1080p 120Hz eDP
Keyboard
Saitek Eclipse I
Mouse
Logitech G500s
Other
Other
Q8002S
GTX 750 Ti
DDR2 800 Kingston
C2Q Q9550
PNY 1333
TX750
Corsair H80
Haf 912
Operating System
Operating System
Lubuntu 16.04 x64
post #1659 of 2861 (permalink) Old 06-29-2015, 11:43 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
and it's not half bad!!! i found a 65 watt core 2 quad for about $30 USD SHIPPED! the original dual core was 65 watts. i had 4gb of ddr2 800 i got for free. i dropped in a cheap ssd and 5tb hdd and an $11 usb 360 receiver. i have ventilated the case and replaced most of the capacitors in the power supply.
Added you. Is that a FlexATX psu or a custom one? and could you confirm the dimensions of the optiplex case? Is it 340 x 314 x 93 mm at 9.9L?
Originally Posted by xP_0nex View Post
I'll add to this.
Setup is as followed:
Intel Core i5 4690k
EVGA Z97 Stinger WIFI
16GB Kingston FURY 1866
ASUS GTX 970 Mini
Silverstone SX600
Corsair H50
Intel 530 180GB SSD
2x WD Blue 1TB
NCASE M1 V3
Pic above has it running with the Noctua-NH-U9B-SE2, however, CPU and HDD temps were a bit on the high side after some time of gaming so I swapped in a spare Corsair H50 and added a 92mm fan blowing on the two HDDs and temps are somewhat better.
Nice case. You should have tried the Noctua cooler horizontally so it sucks air across the hdds instead of sucking in hot air from the gpu
Originally Posted by exodus1500 View Post
Love everyone's builds in here.
I am currently building a Hadron air case with 2 240mm radiators in it.
If anyone cares, here is the build log:
Here are a couple of the current pics:
Added you as well. Nice color scheme (and name as well rolleyes.gif)
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #1660 of 2861 (permalink) Old 06-30-2015, 05:10 AM
wiretap's Avatar
Rep: 18 (Unique: 15)
- Silverstone PT13 Slim-ITX Case
- Jetway NF9HG-2930 (Intel Celeron N2930 1.83 - 2.16 GHz Quad Core Processor, 4x Intel i211AT Gigabit LAN, mini-PCIe, mSATA, etc..)
- 8GB DDR3-1600 Kingston HyperX Impact 1.35v (Part#: HX316LS9IB/8)
- 128GB SanDisk x110 mSATA SSD
wiretap is offline
