[Official] uSFF/SFF Club - Page 170 - Overclock.net - An Overclocking Community
post #1691 of 2861 (permalink) Old 07-07-2015, 03:33 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Originally Posted by Aibohphobia View Post
Turn off hibernation, delete the recovery image, turn down page file size, delete old updates. There's ways to trim Windows down.
Even more extreme is tweaking the installation image, I was able to trim Windows 7 to a bit under 4GB that way when I was installing it on a netbook with an 8GB SSD several years ago.
I just realised that I use sleep, not hibernate, so that's a good idea. I'll have a look at the page file size, but I think I already moved the pagefule to my HDD completely. There are some things that I can't work around. Visual Studio needs a few GB on the system partition, no matter where you install it. Thanks for the helpful tips!
Originally Posted by Eiko View Post
30GB isn't even really a challenge, honestly. It's my default size for a minimal Windows Server VM. I'll bump it up to 80GB if I have to install any applications or large roles, but nothing short of a dedicated file server has more than 80GB on a boot partition on my domain. For a machine that only needs to stream videos and access a file server, 30GB is plenty. If my servers weren't managed via Active Directory and Group Policy, I would use linux and maybe boot from a 4GB USB stick.
I guess Windows Server allows control over what kinds of driver packages are preinstalled and stuff like that more easily than the retail versions of Windows. But yeah, it's only something like 12GB or so when you install it, so it seems reasonable that there is a way to keep it there.
iFreilicht is offline
post #1692 of 2861 (permalink) Old 07-07-2015, 11:17 PM
Allanitomwesh's Avatar
Rep: 52 (Unique: 35)
I just give windows 70GB. Its comfortable there without any tweaking.
Good things come to those who wait.
Allanitomwesh is offline
post #1693 of 2861 (permalink) Old 07-10-2015, 05:10 AM
Six-Strings's Avatar
Rep: 9 (Unique: 9)
I can't decide between the Node 202 and the Cooltek Coolcube (no maxi, no mini, just Coolcube).
They are both around 10l.
The coolcube is half the price and looks much, much nicer.
The Node 202 would fit in my luggage much better and would support a bigger gpu at some point.
Six-Strings is offline
post #1694 of 2861 (permalink) Old 07-10-2015, 10:39 AM
Woxys's Avatar
Rep: 3 (Unique: 3)
@Six-Strings i would go with node, much better thermal design.
Woxys is offline
post #1695 of 2861 (permalink) Old 07-10-2015, 11:35 PM
The Jonsbos are more for saving desk space or for HTPC duty in the living room,where they look great. Not really a layout for carrying around
post #1696 of 2861 (permalink) Old 07-11-2015, 01:43 AM
Rep: 9 (Unique: 9)
Will a 300w PSU suffice for a 65w i5 and a GTX 970?
The 970 is rated at 145w, which leaves 30w headroom for the rest of the headroom (assuming 80% efficiency).
post #1697 of 2861 (permalink) Old 07-11-2015, 06:17 AM
Eiko's Avatar
Rep: 42 (Unique: 35)
The case was a bit larger than I was hoping it would be, but it still fits behind the TV where it needs to.
Eiko is offline
post #1698 of 2861 (permalink) Old 07-11-2015, 06:39 AM
KaffieneKing's Avatar
Rep: 68 (Unique: 62)
The efficiency rating actually works the otherway around, meaning you will have 90 Watts remaining for drives and fans ect
EDIT: And so will definitely be okay
KaffieneKing is offline
post #1699 of 2861 (permalink) Old 07-11-2015, 06:48 AM
Rep: 9 (Unique: 9)
Great, thanks. That means I will stop scanning eBay for 960s and try and find a 970.
post #1700 of 2861 (permalink) Old 07-11-2015, 11:00 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Added. Strange you chose a htpc case and hide it behind the tv, and you got the front facing the inside.
I would suggest the node 202. I have the jonsbo C2 (which is similar to the Coolcube) and it does not have good cooling. If you'll be carrying it around, then the 202 would be beter.
I would not run a 970 on 300w. Which 300w are you referring to? The 970 reference uses 2 6pins connectors.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
