[Official] uSFF/SFF Club - Page 180 - Overclock.net - An Overclocking Community
post #1791 of 2861 (permalink) Old 08-05-2015, 09:42 PM
akromatic's Avatar
Rep: 100 (Unique: 78)
Originally Posted by CynicalUnicorn View Post
I still can't figure out why there's no short 680 or 980 - the 670 and 970 had variants after all. Same GPU, same amount of VRAM, and only marginally more cooling capabilities needed.
people have a bigger is better mindset, like cases, mobos, GPU cooler (ahem gigabyte G1 and it is the best selling nvidia 970/980/ti cards) etc
makes me wonder how overkill and ridiculous having a G1 cooler on a 960 is
akromatic is offline
post #1792 of 2861 (permalink) Old 08-05-2015, 11:02 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by gintama7888 View Post
You'll have to wait a bit for that Dan A4 case, and it won't be cheap(probably the most expensive case in $$$ per volume). One thing I don't like about Dan A4 case is the 10.5" GPU support, imo smaller version of the case with ~7-9" GPU support would have been much better. Anyway the side panel mechanism on Dan A4 is very similar to TU100(but you pull the sticking out part instead of using leaver to pop open the side panel) so I prefer the side panel mechanism on TU100.
With the current psu placement in Dan's A4, its the psu that's defining the length of the case.
On the left is the layout in Dan's A4, mid is a possible shorter case, and on the right is my proposed layout with an intake fan.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #1793 of 2861 (permalink) Old 08-06-2015, 12:33 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Originally Posted by NFSxperts View Post
The sg05 has good positive air pressure. Will be be using the optical and 3.5 hd cages? If you remove the cases, there will be not airflow restrictions.
If the Asus 660 is 10.2" (25.91cm) it should fit as the sg05 supports up to 262mm without modding.
Are you sure thats not the IX-03B http://www.chieftec.eu/en/chassis/itx-tower/ix-03b.html with the hdd attachment?
No, i would remove them to use a SFX-L PSU.
The SG05 supports up to 262mm? Pretty good, on their homepage they wrote "up to 254mm", so i was a little bit worried about fitting my GTX 660 in it.
Does it make sense to replace the standard front fan with another 120x120x25mm fan like the EK Water Blocks Vardar F3 or Noctua NF-F12 or is the
standard fan powerful enough? And if it is recommended to replace the fan, is the Vardar or the NF-F12 a good choice?
And yes, you're right, it's the IX-03B + HDD attachment, sorry.
-Leopold- is offline
post #1794 of 2861 (permalink) Old 08-06-2015, 02:48 AM - Thread Starter
NFSxperts's Avatar
There's a FAQ section in the first post towards the bottom. Its hard to see unless you scroll down.
The specs has some 'wiggle room' since on some gpus, the power connectors are on the side.
Yes, you should replace the fan. I don't own any of those fans but reading online, the performance is similar. Go with the cheaper one.
I'm assuming you'll be using a 2.5" drive. Any idea where you'll be mounting it?
I added the ix-03 to the list.
post #1795 of 2861 (permalink) Old 08-07-2015, 01:35 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
I think the only Option is to mount it on the side or at the bottom. I will find a place for one or two 2,5" drives. Maybe 3,5" is to big to mount it without the drive HDD-Cage.
post #1796 of 2861 (permalink) Old 08-10-2015, 08:38 AM
jooopaaa's Avatar
Rep: 5 (Unique: 3)
Modded cooltek U1, my primary gaming rig:
Asrock Z97-ITX motherboard
i5-4690k (at 4.5Ghz)
8GB DDR3
120GB SSD
KFA2 GTX970 4GB Grapichs
Silverstone SFX 600w modular psu
nanoxia sleeved cables
2x80mm fans at bottom intake
120mm exhaust
120mm intake pwm controlled
80mm enermax pwm controlled for cpu
Temps in BF4 gaming:
CPU max. 72c
MB max. 45c
GPU max.70c
jooopaaa is offline
post #1797 of 2861 (permalink) Old 08-10-2015, 12:29 PM
ccRicers's Avatar
Rep: 72 (Unique: 66)
Originally Posted by jooopaaa View Post
Warning: Spoiler! (Click to show)
8GB DDR3
120GB SSD
120mm exhaust
CPU max. 72c
MB max. 45c
GPU max.70c
Nice build. The fan grills look great on it. How did you get the 970 in there? Was it vertically mounted with a riser cable?
ccRicers is offline
post #1798 of 2861 (permalink) Old 08-14-2015, 02:45 PM
ლ(╹ε╹ლ)
Rep: 176 (Unique: 137)
I've been wanting to mod my ISK600 for quite a while now. For the past few days I have been working hard to make this happen.
Mod list
-Perforated side panels for GPU and radiator air flow
-Cut away to place the radiator along holes for mounting
-3rd SSD mounting under the 2x SSD caddy for moar SSD fun
-LED strip under the GPU
-Front panel LED removal (including HDD activity)
-GPU bracket with foam to keep the GPU properly placed (two side taped)
-Dremeled the fan for the CPU block bracket
Duality92 is offline
post #1799 of 2861 (permalink) Old 08-16-2015, 12:59 AM
WeiZhong's Avatar
Rep: 2 (Unique: 2)
8GB DDR3
120GB SSD
120mm exhaust
CPU max. 72c
MB max. 45c
GPU max.70c
Sick looking build! Will love to see more pictures and more details of the rig! thumb.gif
WeiZhong is offline
post #1800 of 2861 (permalink) Old 08-16-2015, 08:58 PM
ccRicers's Avatar
Here is my Rosewill Legacy U2 build, being prepared for watercooling. I will be using soft tubing for now, but want to move to hard tubing for the final version.
You can see more in my build log.
ccRicers is offline
