[Official] uSFF/SFF Club - Page 181 - Overclock.net - An Overclocking Community
post #1801 of 2861 (permalink) Old 08-17-2015, 01:52 AM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by jooopaaa View Post
Modded cooltek U1, my primary gaming rig:
Asrock Z97-ITX motherboard
i5-4690k (at 4.5Ghz)
8GB DDR3
120GB SSD
KFA2 GTX970 4GB Grapichs
Silverstone SFX 600w modular psu
nanoxia sleeved cables
2x80mm fans at bottom intake
120mm exhaust
120mm intake pwm controlled
80mm enermax pwm controlled for cpu
Temps in BF4 gaming:
CPU max. 72c
MB max. 45c
GPU max.70c
Added you. Our first U1 owner. The top grill looks great, but the front grill spoils the look abit.
Originally Posted by Duality92 View Post
I've been wanting to mod my ISK600 for quite a while now. For the past few days I have been working hard to make this happen.
Mod list
-Perforated side panels for GPU and radiator air flow
-Cut away to place the radiator along holes for mounting
-3rd SSD mounting under the 2x SSD caddy for moar SSD fun
-LED strip under the GPU
-Front panel LED removal (including HDD activity)
-GPU bracket with foam to keep the GPU properly placed (two side taped)
-Dremeled the fan for the CPU block bracket
Wow, that is very packed. Good job
Originally Posted by ccRicers View Post
Here is my Rosewill Legacy U2 build, being prepared for watercooling. I will be using soft tubing for now, but want to move to hard tubing for the final version.
You can see more in my build log.
That looks very nice. CAn't believe you packed 2 radiators into that thing.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #1802 of 2861 (permalink) Old 08-21-2015, 07:36 AM
Canada Goose Puncher
CynicalUnicorn's Avatar
So I'm disappointed yet somewhat happy. The GTX 950 looks like it has so much potential, yet everything is massive. Guys. Come on. It's a 750Ti with a sixth SMM and twice the ROPs. It's a 960 with 3/4 the SMMs. Why can't we have smaller versions of this?! Its TDP is two digits! TWO! (I assume, given how cool both full GM107 and full GM206 are.)
On a positive note, this means the 750Ti + mod wasn't actually a horrible idea! wheee.gif
Quote: Originally Posted by TheBadBull View Post
someone sig this
CynicalUnicorn is offline
post #1803 of 2861 (permalink) Old 08-21-2015, 07:39 AM
ლ(╹ε╹ლ)
Rep: 175 (Unique: 136)
I mean even the 970 comes in small PCBs, I bet they could easily make it short and low profile.
Duality92 is offline
post #1804 of 2861 (permalink) Old 08-21-2015, 09:48 AM
tabascosauz's Avatar
Rep: 9 (Unique: 7)
They could, but they'd go and charge extra for the "mini-ITX edition". That's how they make $$$
tabascosauz is offline
post #1805 of 2861 (permalink) Old 08-21-2015, 01:17 PM
ccRicers's Avatar
Rep: 72 (Unique: 66)
The reference card posted in NVidia's site is pretty small, though.
I'm actually disappointed at the power specs. TDP went up by 50% compared to the 750Ti, and the reference card has a 6-pin connector now. I guess I was expecting too much of a power efficiency leap from Maxwell 1 to 2.
But I'll wait for the reviews to see some actual power output numbers. As I know the bios in the 750Ti actually limits power to 38w I will expect this card to not reach close to its rated maximum either.
ccRicers is offline
post #1806 of 2861 (permalink) Old 08-21-2015, 01:39 PM
Remember, there are a lot more ROPs. The back-end pipeline costs quite a few watts.
I'm not sure how many would be expected however, but it's an increase regardless. Uh... 650Ti vs 650Ti Boost is a good comparison, as is a 660Ti vs a 670 if you want to see a (smaller) effect on Kepler.
someone sig this
post #1807 of 2861 (permalink) Old 08-21-2015, 06:08 PM
akromatic's Avatar
Rep: 100 (Unique: 78)
big sells, idiots take one look at the amount of fans and think that must be better
look how stupid a G1 cooler is on a 960.
akromatic is offline
post #1808 of 2861 (permalink) Old 08-21-2015, 08:04 PM
ccRicers's Avatar
Looks like I'd go with the base EVGA or Zotac cards if I want a 950 on the smaller side.
ccRicers is offline
post #1809 of 2861 (permalink) Old 08-22-2015, 05:11 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Here are some more Screenshots of the Components inside my Chieftec IX-03B:
Mainboard (ASUS H81T Thin mITX) with installed RAM & mSATA SSD
Size Comparsion between SilverStone Nitrogon NT07-115X & Intel Boxed
Case with Mainboard
Empty Case
Soo, i want to build a gaming rig in a mITX case as small as possible - but it is so hard to choose a case tongue.gif.
I want to re-use my be Quiet! Pure Power L8 430W ATX PSU, so maybe the Cooltek Coolcube (=jonsbo V3+) will be fine.
It is veeery small but fits my PSU. I only need a new ITX Graphics Card then. Maybe the R9 Nano or so.
And i think for good cooling i must mod the case maybe. I dont want 4x 40mm little weak, screaming fans.
Maybe 2x 80mm or 1x 120mm Front intake and 80mm Top outtake - what do you think?
Rest of the hardware will be:
ASRock H97M-ITX/ac
2x 4GB DDR3-1600 RAM
i5-4460
and a Raijintek Pallas or similar
-Leopold- is offline
post #1810 of 2861 (permalink) Old 08-23-2015, 02:34 AM - Thread Starter
NFSxperts's Avatar
Same here, I wish we'd go back to single slot coolers for low power cards.
I'm happy with a 750ti, too bad it doesn't support sli
Case with Mainboard
Empty Case
ASRock H97M-ITX/ac
i5-4460
Nice, I'll add your new links.
Have you considered the SilverStone SG13? Aluminum cases with no front intake have problems removing heat from the case so temps get quite toasty inside.
