[Official] uSFF/SFF Club - Page 187 - Overclock.net - An Overclocking Community
post #1861 of 2861 (permalink) Old 09-04-2015, 01:09 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Originally Posted by NFSxperts View Post
Very nice. Did the previous owner glue the dust filters? The SFX bracket is better than the ones silverStone include with their PSUs since its offset to the side.
Is this a new build or will you move the hardware from the Chieftec?
No, glued dustfilters are standard on the c10.
It will be half new - i keep some parts of my old gaming tower case (RAM, PSU, SSD and GPU - ASUS GTX 660 OC).
I just buy a new CPU (i5-4460), a aftermarket cooler and a mainboard.
-Leopold- is offline
post #1862 of 2861 (permalink) Old 09-04-2015, 05:01 AM
Jimbags's Avatar
Rep: 83 (Unique: 73)
Can it fit a rad up top?
Jimbags is offline
post #1863 of 2861 (permalink) Old 09-04-2015, 05:40 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Yes, 240mm smile.gif but then you cant use a DVD-Drive.
post #1864 of 2861 (permalink) Old 09-05-2015, 11:31 AM
esseun's Avatar
Rep: 1 (Unique: 1)
I've had this build for almost 3 years now - recently RMA'ed the motherboard so thought I'd snap a few pictures while it was open.
Specs
Intel Core i5-2500k
2 x 4gb Samsung DDR3 "Magic Ram"
Plextor 256gb ssd
Zotac GTX570
Silverstone SFX 450W V1
Asetek 760GC CPU + GPU Liquid Cooler (120mm x 50mm Radiator)
Gentle Typhoon AP-15
esseun is offline
post #1865 of 2861 (permalink) Old 09-05-2015, 11:32 AM
Smanci's Avatar
Rep: 75 (Unique: 64)
Clean. Very clean.
Smanci is offline
post #1866 of 2861 (permalink) Old 09-05-2015, 02:54 PM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Yes, this looks very good. I thinking about modding my C10 - i am pretty sure i can mod an 2 x 92mm front intake.
post #1867 of 2861 (permalink) Old 09-05-2015, 11:10 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Specs
Intel Core i5-2500k
Plextor 256gb ssd
Zotac GTX570
Is that the SG05?
Have you tried changing your fan to pull instead of push? I find that the temps are around the same but you'll get some airflow going over the motherboard.
My 9L case has arrived. Here's a badly edited teaser.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #1868 of 2861 (permalink) Old 09-06-2015, 01:19 AM
esseun's Avatar
Rep: 1 (Unique: 1)
Is that the SG05?
Yes, it is a pull configuration right now.
CPU Temp maxes out in the low 60's when gaming and GPU temps never goes past 60C.
Overall the cooling is great - I can hear the AP-15 but it is a pleasing sound.
esseun is offline
post #1869 of 2861 (permalink) Old 09-06-2015, 09:15 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Just removed all parts of my C10 - i think its possible to mod it to fit an 240mm Radiator (Enermax Liqmax II 240) and a HDD/SSD. And maybe some front intake like my old 92mm fans. In the standard configuration cou cant place 2 fans or a 240mm radiator when u also want to place a 3.5" HDD at the front bay.
post #1870 of 2861 (permalink) Old 09-06-2015, 07:29 PM - Thread Starter
NFSxperts's Avatar
The mac pro clone case. Vast Dust Man Pi itx case.
This will replace my htpc.
At 206mm in diameter and 276 tall, if I still remember the formula, π103²*276, which is 9.2L.
It's a m-itx case supporting SFX PSU, single slot low profile card and cpu coolers up to 60mm tall. 1 2.5" ssd and 13.5" hdd.
The top i/o has a power and reset button, a 3 speed fan switch and a hdd light. There are no usb ports.
The side panels have a rubberized finish, similar to the ones found on mouse grips.
https://translate.google.com/translate?hl=en&sl=zh-CN&u=http://www.expreview.com/42578-all.html&prev=search
It comes with a SFX 230watt psu which I tossed it aside immediately.
Vast Dust Man gallery
