[Official] uSFF/SFF Club - Page 202 - Overclock.net - An Overclocking Community
post #2011 of 2861 (permalink) Old 10-23-2015, 03:04 PM
ccRicers's Avatar
Rep: 72 (Unique: 66)
Originally Posted by ivoryg37 View Post
No problem! I will definitely let everyone know if this case is worth the price they're asking for. I also notice that watercooling kit and was interested in it but shipping would be too much since their store is overseas apparently.
Ah yeah, that threw me off because I thought their boutique shop was based in LA but that's just some other eBay seller.
I probably might not buy this case in the end. I'm now more leaning to making a custom case for my next SFF build. About the size of a Dan A4 and same layout, but it will also accommodate a GPU with a hybrid liquid cooler.
The case will have a metal front and top with clear acrylic side panels. I have figured out the outer measurements of this case and it will be 8.5 L, a mere 1.25 L more than the Dan A4.
ccRicers is offline
post #2012 of 2861 (permalink) Old 10-23-2015, 03:25 PM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Meh, Noctuas Homepage says that the NH-L9a is not compatible to the MSI A88X ITX V2 Board.
-Leopold- is offline
post #2013 of 2861 (permalink) Old 10-23-2015, 04:38 PM
frack0's Avatar
Rep: 23 (Unique: 22)
Originally Posted by Jimbags View Post
I actually find the noctua fan really quiet even when its at full rpm. Ynless your refering to the noise of wind turbulence?
Exactly. All the Noctua fans I've had are real quiet but any of them up against a grille can make some noise at medium to higher RPMs from the turbulence.
frack0 is offline
post #2014 of 2861 (permalink) Old 10-23-2015, 05:57 PM
Jimbags's Avatar
Rep: 83 (Unique: 73)
Originally Posted by -Leopold- View Post
I have my "old" 120GB SSD here, but i think i will go for a 500GB 2.5" HDD or so. Two drives paired with a CPU with a TDP of 95W and a small cooler is not the best idea i think.
Its not a big problem when its gonna to be a little bit noisy. I can really deal with that. and if not - i have Headphones biggrin.gif
Single hdd for boot and storage are so slow after using an ssd. I tried it recently and it sucked. I have an SSD in my htpc for os. Just so much smoother. Could you stack an ssd with the hdd?
Jimbags is offline
post #2015 of 2861 (permalink) Old 10-24-2015, 01:50 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Stacking Could work, dont know. I have a SSD in my HTPC oft OS, toi. Ans yes, it runs very smooth smile.gif.
I think i have to switch to the ASRock FM2A88X-ITX+ for Compatibility with the Noctua NH-L9a. You can also switch the WiFi/Bluetooth Card for a mSATA SSD.
post #2016 of 2861 (permalink) Old 10-24-2015, 10:37 AM
TinoArg's Avatar
Rep: 4 (Unique: 4)
The FM2A88X-ITX+ has a great layout, I use a CM GeminiiS and RIpjawsX RAMs without problems. And I put a 32GB SSD mSATA just for the OS and a 2TB HDD for games and storage.
TinoArg is offline
post #2017 of 2861 (permalink) Old 10-24-2015, 10:51 AM
Canada Goose Puncher
CynicalUnicorn's Avatar
My sole complaint about that thing is that it can't take mSATA and mini PCIe simultaneously. I don't think it would be too difficult to do, even it it meant two cards stacked on top of each other. Some thin mITX boards do this, for example.
Quote: Originally Posted by TheBadBull View Post
someone sig this
CynicalUnicorn is offline
post #2018 of 2861 (permalink) Old 10-24-2015, 11:04 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Good to hear, thanks. Its more a question of the case - i want one as small as possible with hardware as strong as possible - the M350 is well perforated, and AMDs A10-7xxx APUs are extremely interesing in iGPU Power.
post #2019 of 2861 (permalink) Old 10-26-2015, 09:36 PM
Klutz0's Avatar
Rep: 6 (Unique: 6)
Klutz0 is offline
post #2020 of 2861 (permalink) Old 10-26-2015, 11:11 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Originally Posted by Klutz0 View Post
Build log here: https://www.overclock.net/t/1577503/build-log-hubble-a-node-304-skylake-build/0_20
Sorry to distract from the build, but that is one nicely designed build-log! Really easy to follow.
iFreilicht is offline
