[Official] uSFF/SFF Club - Page 21 - Overclock.net - An Overclocking Community
post #201 of 2861 (permalink) Old 07-11-2013, 08:36 PM
psyclum's Avatar
Rep: 424 (Unique: 300)
Originally Posted by akromatic View Post
its not a good idea to run a PSU so close to shut down ether, i'd normally like to leave about 20% spare capacity to factor in aging and stress
that depends on the quality of the PSU. but yah. pushing it to shutdown limit is bad biggrin.gif i would say maybe 10% on the "rated" power to account for aging is good enough. 20% is overkill.
psyclum is offline
post #202 of 2861 (permalink) Old 07-11-2013, 11:49 PM
Xyphyr's Avatar
Rep: 25 (Unique: 24)
James (xyphyr)
Compact Splash / 290 x 170 x 310mm / 15.3L thumb.gif
I need to get some kind of light setup inside still, considering white led fans.
Super excited to actually have this thing.
95.567% of people make up the stats in their sig. If you are part of the 4.433% who uses real stats, put
this in your sig.
Xyphyr is offline
post #203 of 2861 (permalink) Old 07-12-2013, 02:21 AM
Allanitomwesh's Avatar
Rep: 52 (Unique: 35)
Wow.
Good things come to those who wait.
Allanitomwesh is offline
post #204 of 2861 (permalink) Old 07-12-2013, 04:19 AM
8.2 liters
WiSK's Avatar
Rep: 553 (Unique: 361)
I didn't even stop to think about using Splash all-in-one coolers... thumb.gif
WiSK is offline
post #205 of 2861 (permalink) Old 07-14-2013, 07:31 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
I worded my post poorly. What I meant was Silverstone's next SFX psu will probably be a new design instead of just tweaking the current one so the wattage output will probably be more than just a 50watt increase. I'm guessing a minimum of 550w.
James (xyphyr)
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #206 of 2861 (permalink) Old 07-14-2013, 11:55 PM
Xyphyr's Avatar
Thanks for the comments, I just replaced my 3570k with a i7 3770k from SLE, and put 2 more corsiar fans on the h100i. thumb.gif
this in your sig.
Xyphyr is offline
post #207 of 2861 (permalink) Old 08-10-2013, 09:50 AM
Smanci's Avatar
Rep: 75 (Unique: 64)
Just a little update on my Q11 rig.
Sold my EVGA 560Ti SC and bought an MSI GTX 660 TF III. I also downclocked my 3570K to 3Ghz since these Gigabyte m-ITX boards offer no voltage adjustment options mad.gif... Anyhow, things are now running surprisingly cool and quiet - which I didn't really expect to be possible in this case, at least with this kind of hardware and cooling solutions.
The CPU reaches max. of 73° in a 25° room while the stock cooler's fan is spinning 2,5K RPM, and yes, that's on the loud side but when in idle and desktop - not really. 64° for the GPU in full stress, barely audible.
Still on the to-do list: Get the Noctua NH-L9i thumb.gif
Smanci is offline
post #208 of 2861 (permalink) Old 08-10-2013, 11:53 AM
andydviking's Avatar
Rep: 2 (Unique: 2)
Before I read the last line I was going to suggest the Noctua L9i. I might also suggest getting the thicker 90mm fan if it'll fit and you feel like shelling out the extra as the cooler comes with screws for it and it should perform better (I did NOT do this but wish I tried it out. I am running with the thin 90mm) I just ran a quick Intel burn test of two passes. My hottest core was 77*C. I also have a thermometer next to me and I am at 25.6*C ambient temps. My specs are similar to yours.
CPU-i5-3570K @ stock
MOTHERBOARD- Gigabyte H77N-Wifi
CASE- CM Elite 120 advanced
CPU COOLER- Noctua L9i
GPU EVGA GTX 650ti 2gb
What is your CPU cooler?
andydviking is offline
post #209 of 2861 (permalink) Old 08-10-2013, 01:39 PM
Smanci's Avatar
Thanks for the response! I'll definitely give the thicker one a try as soon as I can. smile.gif
I'm using Intel's stock cooler and btw, can you tell me anything about the noise level of the NH-L9i? How's it compared to the 3570K's stock cooler, I mean, can you run that little thing on a really low RPM and still get equal or better results?
EDIT: thumb.gif
Smanci is offline
post #210 of 2861 (permalink) Old 08-10-2013, 06:19 PM
Milestailsprowe's Avatar
Rep: 31 (Unique: 29)
EDIT: thumb.gif
I have the cooler running normal and there is NO noise.
Milestailsprowe is offline
