[Official] uSFF/SFF Club - Page 211 - Overclock.net - An Overclocking Community
post #2101 of 2861 (permalink) Old 11-30-2015, 07:26 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by ccRicers View Post
The most narrow I could make this case is 125mm, which means only cards with no side power connectors (like the Nano) would fit. This contributes greatly to its small volume.
Looks like it might be a bit over 6 liters since I want to extend the length of the case a bit to get some more cooling room. I'm trying to figure out how the front should look. I'm actually looking at NAS devices and not just other ITX cases for ideas.
This mockup uses the R9 fury cooler as a placeholder, which is 65mm combined width. For the CPU, I'll likely use a liquid cooler that is 60mm or less.
What would the size be if the radiator is above the motherboard. That way gpu power connectors on the top would work.
The case would be thicker but shorter
Originally Posted by NicolasTMills View Post
My lian li PC-Q21B
i5 4440
h97m/ac itx
8gb 1600mhz
silverstone sfx 450 modular
1tb hdd blue
and the weekend buy gtx 750 ti
Added you. Have you got the 750ti yet?
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #2102 of 2861 (permalink) Old 11-30-2015, 08:22 PM
Rep: 577 (Unique: 411)
Oh yeah, this thread. I'm not big on clubs but it's sad seeing cases listed in the OP with zero owners so please add me for the Lian-Li PC-Q33 (PC-Q33B).
Post in the other thread, including bad pics:
https://www.overclock.net/t/541767/club-for-those-with-beastly-matx-itx-rigs/12310#post_24649081
Contents, for reference:
Intel Core i7-6700K
Scythe Kotetsu
Asus Z170I Pro Gaming
Corsair 2x8 GB DDR4 2400 MHz Vengeance LPX
EVGA GTX 960 SC 2 GB
Crucial MX200 500 GB
Crucial M500 240 GB
Toshiba 1 TB 5400 rpm 2.5"
EVGA SuperNOVA 550 GS
Lian-Li PC-Q33B
mikeaj is offline
post #2103 of 2861 (permalink) Old 11-30-2015, 08:25 PM
Retired Staff
derickwm's Avatar
Rep: 379 (Unique: 291)
derickwm is offline
post #2104 of 2861 (permalink) Old 12-01-2015, 03:46 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
Isn't the point of this design that you get exceptional airflow for the radiator? By putting it above the mainboard, it would either be close to the PSU or to the 2.5" drives, obstructing a fair portion of the fan exhaust.
I found that build to be rather amusing. Of course, it looks good and it's amazing that they managed to cram so much stuff into that case, but why have a watercooling loop if you're placing radiators of the same surface area on the exact spots where the original heatsinks initially were? The answer is probably "because why not?".
iFreilicht is offline
post #2105 of 2861 (permalink) Old 12-01-2015, 06:51 PM
Retired Staff
derickwm's Avatar
It has improved the temps ever so slightly. Worth the extra effort? Probably not to be honest, but it was more of a "challenge" for me to try and fit a sizeable loop in such a tiny case :)
derickwm is offline
post #2106 of 2861 (permalink) Old 12-02-2015, 04:52 AM
akromatic's Avatar
Rep: 100 (Unique: 78)
not sure where is the best place to ask this but im contemplating about the viability of running a gtx 950 or other GPUs that i can run entirely off a pico 160XT with its 192w brick combo.
hardware that i could potentially pair it up with is ether a i5 3570 or i3 2100 and 2 drives.
abit sick of how weak the 7850k + r7 250 is especially compared to the 750ti
akromatic is offline
post #2107 of 2861 (permalink) Old 12-02-2015, 05:21 AM
I dunno what I'm doing.
Blze001's Avatar
Rep: 63 (Unique: 45)
The GTX950 pulls about 90w. The i5-3570 + GTX 950 + 2 drives adds up to 187w, leaving 5w for the other items like motherboard/memory/etc. The i3-2100 setup would get you to 175w leaving 17w for the other stuff. The i3 would maybe work. i5, not so much... I know components don't pull max rating all the time, but if you started gaming, you'd likely find the end of that 192w in a hurry.
I don't believe in having 500w of headroom with your PSU like some (Bro, you need at least 1000w to run 2 cards in SLI!1!!1!), but 17w is pretty close. For comparison, a 750ti only pulls 60w (and makes 60w worth of heat in a tiny package), which is why those are the darlings of the SFF/uSFF world.
It is what it is.
Waterworld
(21 items)
i7-8700k
ASRock Fatal1ty Z370 Gaming-ITX/ac
GTX-1080ti Founder's Edition
Kingston HyperX
Samsung M.2 950 PRO
SanDisk Ultra II
Corsair RM650x
Optimus V1 LGA-1151 Waterblock
Nemesis GTS240
Nemesis 120GTS
EK D5 Revo
Singularity Protium Pump Top/Case
EKWB 10x0 Waterblock
SavantPCs 240mm Reservoir
Noctua NF-A12x25
Fractal Nano S
Operating System
Windows 10 Pro
Alienware AW3418DW
Keyboard
GMMK TKL
Mouse
Logitech G602
Audio
Creative X7
Blze001 is offline
post #2108 of 2861 (permalink) Old 12-02-2015, 05:26 AM
akromatic's Avatar
fair enough, though my GPU would be external of case so heat isnt a big deal.
post #2109 of 2861 (permalink) Old 12-02-2015, 05:41 AM
Blze001's Avatar
It's not the heat so much as the power draw that's causing me worry with that 192w PSU. The 750ti is an awesome little card and would still be a great step up from the R7 250, though.
GPUs are thirsty beasts, which is a bummer for us small-computer nerds.
It is what it is.
Waterworld
(21 items)
i7-8700k
Kingston HyperX
Samsung M.2 950 PRO
SanDisk Ultra II
Corsair RM650x
Nemesis GTS240
Nemesis 120GTS
EK D5 Revo
Noctua NF-A12x25
Fractal Nano S
Operating System
Windows 10 Pro
Alienware AW3418DW
Keyboard
GMMK TKL
Mouse
Logitech G602
Audio
Creative X7
Blze001 is offline
post #2110 of 2861 (permalink) Old 12-02-2015, 05:49 AM
akromatic's Avatar
step up sure but really dated especially for the more recent titles. the thing is though if i am to get a 750ti i may as well get an alienware alpha.
the 950 is a significant step up to the 750ti.
doubt the PC would be constantly pulling 175 constantly, that should be absolute maximum peak power draw provided GPU boost doesnt do anything stupid. some benches kinda show that with a x99 8core (140w) with a 950 is pulling ~180w running crysis 3 (189w for stupidly boosted cards)
