[Official] uSFF/SFF Club - Page 219 - Overclock.net - An Overclocking Community
post #2181 of 2861 (permalink) Old 12-07-2015, 12:55 PM
I dunno what I'm doing.
Blze001's Avatar
Rep: 63 (Unique: 45)
Originally Posted by Shrak View Post
https://www.dan-cases.com/faq.html
For the price vs limitations, I think I'd rather go NCASE M1 still. Not a bad looking case though.
NCASE M1 - 185 + shipping / tax
240 x 160 x 328mm
DAN A4-SFX 200-230 + shipping / tax
205 x 112 x 327mm
Really not much smaller, but means no slot load optical drive and no radiator or otherwise larger than stock coolers... 40mm give or take a few on height and width, but other than that... I think I'd prefer to have the option for a better cpu cooler ( though I use an external rad box anyways, but finding a spot for passthrough quick disconnects on the A4... )
True, but I'm not ready to do watercooling yet. The only reason I'd go a little larger is if I could use full-size ATX supplies, but I can't do that with either, so for my plans I like the supertiny one. thumb.gif
It is what it is.
Waterworld
(21 items)
i7-8700k
ASRock Fatal1ty Z370 Gaming-ITX/ac
GTX-1080ti Founder's Edition
Kingston HyperX
Samsung M.2 950 PRO
SanDisk Ultra II
Corsair RM650x
Optimus V1 LGA-1151 Waterblock
Nemesis GTS240
Nemesis 120GTS
EK D5 Revo
Singularity Protium Pump Top/Case
EKWB 10x0 Waterblock
SavantPCs 240mm Reservoir
Noctua NF-A12x25
Fractal Nano S
Operating System
Windows 10 Pro
Alienware AW3418DW
Keyboard
GMMK TKL
Mouse
Logitech G602
Audio
Creative X7
Blze001 is offline
post #2182 of 2861 (permalink) Old 12-07-2015, 02:10 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
False, the M1 allows you to use an ATX PSU in the front. Makes for interesting setups with tower coolers, no need for watercooling at all.
I personally think the A4 is a huge step downward, though, it's close to half the volume of the M1.
iFreilicht is offline
post #2183 of 2861 (permalink) Old 12-07-2015, 02:38 PM
Blze001's Avatar
According to the website:
ATX PSU support is possible using the included bracket with the following limitations:
- Cannot be used with GPUs over 195mm long.
- Cannot be used with the dual 3.5" HDD cage or 240mm radiator mounted to the side bracket (120mm radiator is still possible over the motherboard area)
I have a reference GTX-780, so I'd be restricted to SFX powersupplies with the M1 as well. All I lose with the A4 is the 120mm radiator and tower cooler options.
It is what it is.
Waterworld
(21 items)
i7-8700k
Kingston HyperX
Samsung M.2 950 PRO
SanDisk Ultra II
Corsair RM650x
Nemesis GTS240
Nemesis 120GTS
EK D5 Revo
Noctua NF-A12x25
Fractal Nano S
Operating System
Windows 10 Pro
Alienware AW3418DW
Keyboard
GMMK TKL
Mouse
Logitech G602
Audio
Creative X7
Blze001 is offline
post #2184 of 2861 (permalink) Old 12-07-2015, 04:58 PM
Linux Lobbyist
bobfig's Avatar
Rep: 254 (Unique: 221)
just priced out the M1 and its close to the same price as they wat like $35-45 for shipping and thats for like 2-4 week shipping.
bobfig is offline
post #2185 of 2861 (permalink) Old 12-07-2015, 07:40 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
I got tired of waiting for my ideal case with a handle so I'm going to mod a handle on my SG05.
The plan is to attach it on rear since I don't think the top panel can support the weight.
The easiest way is to drill 2 holes and add the handle between the motherboard and psu.
I've found a handle that's just under 12cm. The screw holes are 100cm apart. Gonna start testing where to mount the handle for the best weight balance.
I've decided to add the handle on the rear so its more discreet.
Marked where to drill the holes
bolts I will be using
Drilling
Holes
View from below
Finished
The back plate is actually sturdy enough to support the weight from being carried around unless you swing it around as a weapon.
I forgot to weight it on a scale but currently it houses a standard m-itx system, a 2.5" hdd, a H80i with a delta fan, and a short length gpu.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #2186 of 2861 (permalink) Old 12-08-2015, 12:59 AM
Jimbags's Avatar
Rep: 83 (Unique: 73)
Why do people insidt on a handle? I cradle mine like a baby. Hold it close to my body.
Jimbags is offline
post #2187 of 2861 (permalink) Old 12-08-2015, 04:49 AM
Six-Strings's Avatar
Rep: 9 (Unique: 9)
Because cradling takes two hands and a handle takes one.
Six-Strings is offline
post #2188 of 2861 (permalink) Old 12-08-2015, 08:06 AM
Shrak's Avatar
Rep: 605 (Unique: 370)
And a backpack takes none.
Shrak is offline
post #2189 of 2861 (permalink) Old 12-08-2015, 12:29 PM
Blze001's Avatar
It is what it is.
Waterworld
(21 items)
i7-8700k
Kingston HyperX
Samsung M.2 950 PRO
SanDisk Ultra II
Corsair RM650x
Nemesis GTS240
Nemesis 120GTS
EK D5 Revo
Noctua NF-A12x25
Fractal Nano S
Operating System
Windows 10 Pro
Alienware AW3418DW
Keyboard
GMMK TKL
Mouse
Logitech G602
Audio
Creative X7
Blze001 is offline
post #2190 of 2861 (permalink) Old 12-08-2015, 12:57 PM
Shrak's Avatar
Imagine that nowadays...
SG05 or smaller, flat screen monitor, 60%-80% keyboard... it'd be so much more compact and lighter. Ideas for the ghetto rigging thread thumb.gif
What's funny though is when I was doing LANs a bit ago, I could fit my SG05 + monitor + keyboard + mouse + headphones in my backpack with 2 full changes of clothes, toiletries and my Macbook air with no problem. A handle on a case is just... not needed.
Also, Silverstone even makes a bag for the Sugo series of cases; http://silverstonetek.com/product.php?pid=32&area=en
Shrak is offline
