[Official] uSFF/SFF Club - Page 232 - Overclock.net - An Overclocking Community
post #2311 of 2861 (permalink) Old 02-02-2016, 08:53 AM
Canada Goose Puncher
CynicalUnicorn's Avatar
It's probably looking at TDP. TDP isn't power consumption, but it can give you a rough idea. It stands for "thermal design power" and is the maximum amount of heat a particular component is rated to dissipate.
If they're not looking at TDP, then likely reviews measuring power draw from the wall. Great! Except AC-DC converters are never 100% efficient. A 100W CPU drawing power from an 80% efficient PSU will pull 125W from the wall. That's not enough to be concerned by if you're looking at, say, an 850W PSU, but when you're building a small system, every little bit matters.
There's not really an excuse to do that I don't think. Just get a high-power ammeter to measure current to a particular part. GPUs? That's easy - just measure the current through all the 12V lines. CPUs? A bit more difficult thanks to the VRMs, but you could measure the input to the VRMs (which would be more accurate for a PSU's needs but less accurate for a cooler).
Quote: Originally Posted by TheBadBull View Post
someone sig this
CynicalUnicorn is offline
post #2312 of 2861 (permalink) Old 02-02-2016, 12:15 PM
iFreilicht's Avatar
Rep: 29 (Unique: 22)
iFreilicht is offline
post #2313 of 2861 (permalink) Old 02-02-2016, 01:33 PM
I thought SFX and ATX shared a mount?
someone sig this
post #2314 of 2861 (permalink) Old 02-02-2016, 02:48 PM
timerwin63's Avatar
Rep: 70 (Unique: 57)
Nope. SFX is considerably smaller. Left to right, there's the adapter that came with my SX600-G, the SX600-G itself, and a cruddy ATX PSU I pulled out of a Dell a couple weeks back to turn into a bench supply (sorry for potato quality):
Edit: The fact that the tops of the PSUs aren't level, as well as the ATX unit being slightly angled due to non-modularity makes it seem like the difference is a tad bit bigger than what it really is.
Edit 2: Maybe this picture would show the difference better:
Originally Posted by iFreilicht View Post
BTW, Silverstone released an adapter plate from SFX- to ATX-PSUs that doesn't suck.
That looks fantastic, thanks! And they announced it at an MSRP of just under $7. Here I was expecting some of that "and all for the generic cost of $19.99" bull crap.
"Roses are red, violets are blue. They don't think it be like it is, but it do."
"What I've done so far is pour alcohol on things - it helps people, so I figured it would be the same for keyboards."
Clubs (Click to show)
Heatware: http://www.heatware.com/eval.php?id=101432
timerwin63 is offline
post #2315 of 2861 (permalink) Old 02-02-2016, 03:01 PM
KaffieneKing's Avatar
Rep: 68 (Unique: 62)
http://www.silverstonetek.com/product.php?pid=631&area=en
Looks like the adapter that came with mySharkoon QB one, but with vents biggrin.gif
KaffieneKing is offline
post #2316 of 2861 (permalink) Old 02-02-2016, 03:56 PM
ejohnson's Avatar
Rep: 33 (Unique: 31)
Looks nice, I need a adapter just like that for my new servers... My server cases take atx psu, but don't have vents for the psu fans.
ejohnson is offline
post #2317 of 2861 (permalink) Old 02-02-2016, 06:15 PM
ignsvn's Avatar
Rep: 13 (Unique: 9)
Thanks for the information. So in short, Outervision's PSU calculator does overestimate a bit?
For example; looking at your Osmium build (in your sig), PSU calculator says it requires about 195 watt. But seems that the 120 watt pico PSU works just fine?
ignsvn is offline
post #2318 of 2861 (permalink) Old 02-02-2016, 08:15 PM
Lolwut? Really? That seems very high. These things pull about 110W from the wall stock and under load.
It's an 80W PSU, actually, but it can peak at 120W for short periods. It's more than enough. Chipset is rated at 5W TDP, RAM uses around 5W, fans should be 5W tops, the SSD is maybe 2W, and that leaves an APU to use up the remaining 65W/105W. Even at stock it would probably be fine (unless I've got Prime95 and Furmark running at the same time), but I've undervolted and downclocked it such that it should be using half the stock power if the math works out.
I suppose if you take two-thirds what the PSU calculator says, you're good. 130W sounds about right with everything at stock speeds and voltage. It hasn't blown up yet, and the inside of that case gets HOT.
someone sig this
post #2319 of 2861 (permalink) Old 02-03-2016, 07:36 AM
Linux Lobbyist
BoloisBolo's Avatar
Rep: 13 (Unique: 13)
Hey guys I wanted to submit this for the club even though it isn't finished yet. Its functional right now just really some aesthetic things to change and need to add xfire, but I have another sff project that I want to complete first.
Build log here.
BoloisBolo is offline
post #2320 of 2861 (permalink) Old 02-03-2016, 11:43 AM
MiiX's Avatar
Rep: 17 (Unique: 15)
Originally Posted by timerwin63 View Post
I'm personally a huge fan of "Project Luna":
There's a log with some of his work here, but I couldn't find a full log anywhere.
Here you go smile.gif http://www.sweclockers.com/forum/trad/1356554-laines-luna
[Build Log] Cold Devil
Fractal Design Core 1000 Owners Club
Cold Devil
(16 items)
Intel Pentium G3258 @4.3GHz
Asus Z97 Maximus VII Gene
EVGA GTX 780 ACX
Corsair Vengeance Pro
Samsung 840 250GB
Coolermaster V650S
Corsair H100i
Scythe AP-15
Fractal Design Core 1000 USB3
Operating System
Windows 10 Home
BenQ XL2420T
Keyboard
Logitech G110
Mouse
Razer DeathAdder Chrome
Mouse
QPAD The Gathering 15 Edition
Audio
Philips Fidelio X1
Audio
Fiio E07K Andes
MiiX is offline
