[Official] uSFF/SFF Club - Page 251 - Overclock.net - An Overclocking Community
post #2501 of 2861 (permalink) Old 04-11-2016, 08:37 PM
Hey I get one of these!
KyadCK's Avatar
Rep: 307 (Unique: 217)
Originally Posted by ccRicers View Post
Originally Posted by KyadCK View Post
They're spaced right for a 240mm, yes.
And correct, no 3.5" slot, but it can handle two 2.5" drives and has a large enough hole for an M.2 on the back of the MB.
They are spaced for 240mm, but depending on the radiator you choose, the area with the ports may interfere either with the I/O panel on the front or the large-ish AC power connector in the back. (Pic for reference) If that happens, you'll have to drill some offset holes to get the radiator to fit completely.
More important would be chopping up the middle separator to even get tubes to it in the first place I'd think.
What you're saying is mostly irrelevant; fans fit fine with the AC adapter there, and just go frame -> fans -> rad with 90* fittings above the rad, one of them a T fitting for a fill port. Problem solved. It's cooling an APU, you don't need a 68mm rad and deltas. A slim rad and/or fans should be fine with a 240.
I'm more interested on where in the hell he'll put a res/pump. tongue.gif
Forge
(18 items)
Forge-LT
(7 items)
AMD Threadripper 1950X
Gigabyte X399 Designare
EVGA 1080ti SC2 Hybrid
32GB G.Skill TridentZ RGB (4x8GB 3200Mhz 14-14-14)
Intel 900P 480GB
Samsung 950 Pro 512GB
Corsair AX1200
EK Predator 240
Corsair Graphite 780T
Operating System
Windows 10 Enterprise x64
2x Acer XR341CK
Keyboard
Corsair Vengeance K70 RGB
Mouse
Corsair Vengeance M65 RGB
Audio
Sennheiser HD700
Audio
Sound Blaster AE-5
Audio
Audio Technica AT4040
Audio
30ART Mic Tube Amp
i7-4720HQ
UX501JW-UB71T
GTX 960m
16GB 1600 9-9-9-27
512GB PCI-e SSD
Operating System
Windows 10 Pro
4k IPS
KyadCK is offline
post #2502 of 2861 (permalink) Old 04-11-2016, 09:05 PM
Jimbags's Avatar
Rep: 83 (Unique: 73)
Just letting you all know corsair sfx psu's are out now, and a 92mm fan too smile.gif
https://www.ple.com.au/Products/623484/Corsair-SF600-600W-80PLUS-Gold-Modular-SFX-Power-Supply
Come in 450w and 600w
Jimbags is offline
post #2503 of 2861 (permalink) Old 04-11-2016, 09:09 PM
Jimbags's Avatar
Same size as Silverstone ones. Gold rated also. But with a 92mm fan insteas of 80mm like the silverstone :-D
Jimbags is offline
post #2504 of 2861 (permalink) Old 04-11-2016, 09:57 PM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
A sub 10L case that can fit up to 240mm rad? I can't think of any that is possible without modding, but the Node 202 case comes real close at 10.2 liters.
Since you want an APU build you could just use the entire GPU compartment of the case for the radiator and fans, and should fit no problem as long as the total thickness doesn't exceed 75mm. But you'll need to drill holes inside the case in order to mount the radiator and fans in place.
Then i need to build myself a case from Lego.
-Leopold- is offline
post #2505 of 2861 (permalink) Old 04-12-2016, 05:39 AM
IntoxicatedPuma's Avatar
Rep: 7 (Unique: 7)
Lian Li TU-100 maybe. Jonsbo C2 is close and can support a 120 or 140mm fan.
IntoxicatedPuma is offline
post #2506 of 2861 (permalink) Old 04-14-2016, 11:29 AM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
Some Actual Pictures of my Sharkoon SHARK ZONE C10:
Fits an Enermax Liqmax II 240 with a bit of Modding.
post #2507 of 2861 (permalink) Old 04-14-2016, 12:34 PM
Linux Lobbyist
BoloisBolo's Avatar
Rep: 13 (Unique: 13)
Warning: Spoiler! (Click to show)
Digging the paint job. What did you use?
BoloisBolo is offline
post #2508 of 2861 (permalink) Old 04-14-2016, 09:23 PM
-Leopold-'s Avatar
Rep: 6 (Unique: 6)
For the GPU first simply hot glue to add this structure/3D-effect, then i painted the glue with yellow spray paint (glossy). For the Case i used only spray paint (except in a few places on the sidepanel)
post #2509 of 2861 (permalink) Old 04-15-2016, 12:35 PM
Klutz0's Avatar
Rep: 6 (Unique: 6)
Here's a blast from the past for you guys :
Does anyone know if the MSI low-profile GTX 750ti comes with a low-profile bracket?
If it doesn't, does anyone know of a compatible one?
Klutz0 is offline
post #2510 of 2861 (permalink) Old 04-15-2016, 01:31 PM
Canada Goose Puncher
CynicalUnicorn's Avatar
It does. Two in fact - one for VGA and one for the DVI and HDMI. VGA is on a ribbon cable so it can be removed entirely.
Quote: Originally Posted by TheBadBull View Post
someone sig this
CynicalUnicorn is offline
