[Official] uSFF/SFF Club - Page 272 - Overclock.net - An Overclocking Community
post #2711 of 2861 (permalink) Old 01-09-2017, 11:19 AM
rfarmer's Avatar
Rep: 55 (Unique: 49)
Originally Posted by Simmons572 View Post
Howdy folks, the build has been finished!
Warning: Spoiler! (Click to show)
Would you all make me some recommendations for some free benchmarking softwares I can use? I want to stress test the hell out of this little box, and aside from furmark and prime95, I am not really sure what is out there that would be worth running. redface.gif
I like OCCT for OC stability testing and Unigine valley and heaven are pretty good for GPU testing. I prefer 3dmark but not free.
ncase m1
(14 items)
Intel i7 8700k
Gigabyte Z370N WIFI Mini
MSI GTX 1070 Aero itx
Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
MyDigitalSSD - BPX 128GB M.2-2280 Solid State Drive
Crucial - M500 960GB 2.5" Solid State Drive
Seagate - BarraCuda 2TB 2.5" 5400RPM Internal Hard Drive
Corsair - SF 600W 80+ Gold Certified Fully-Modular SFX Power Supply
Scythe - BIG Shuriken 2 Rev. B 45.5 CFM Sleeve Bearing CPU Cooler
Prolimatech - Ultra Sleek Vortex 12 55.7 CFM 120mm Fan
MI-6
Operating System
MS Windows 10 Pro
Intel Core i7-8700K Coffee Lake 6-Core
Gigabyte Z370N WIFI
PNY GeForce GTX 980 4GB GDDR5 PCI Express 3.0
CORSAIR Vengeance LPX 16GB DDR4
MyDigitalSSD 120GB M.2 SSD
OCZ Saber 1000 960GB
CORSAIR SF600 600W SFX 80 PLUS GOLD
be quiet! DARK ROCK TF
Ncase M1
Operating System
Microsoft Windows 10 Pro
ASUS VG248QE Black 24" Gaming Monitor
Keyboard
Logitech G105
Mouse
Logitech G402
Audio
Steelseries Siberia v2
rfarmer is offline
post #2712 of 2861 (permalink) Old 01-09-2017, 11:20 AM
Seban's Avatar
Rep: 6 (Unique: 5)
3dmark is just a synthetic benchmark. Its not any kind of stress test.
Seban is offline
post #2713 of 2861 (permalink) Old 01-10-2017, 08:00 PM
Rep: 0
UPDATE (UV Siamese)
So it has been nearly a month now and I am dying to post UV Siamese's system temps and stress test results using the Thermaltake Engine 27 CPU Cooler and the Noctua NF-S12B redux-1200 PWM 120 mm Case Fan. My computer is on 24/7 with neither system sleep or hibernation turned on; just screen sleep turned on.
CPU Cooler and Case Fan were both set on Gigabyte's 'Quiet' Smart Fan Auto Mode for the duration of the monitoring, as well as when performing the system stress tests which were conducted using HeavyLoad and StressMyPC stress tools. The CPU and M.2 SSD did not get as hot as I thought they would on the 'Quiet' Setting especially when I conducted the stress tests at the warmest time of the day with no air conditioning here in Thailand. Lowest temps reported were of course when the CPU was at idle with AC on during the evenings.
CPU: 24 | 57 °C
SYSTEM: 27 | 54 °C
M.2 SSD: 36 | 63 °C
2.5" SSD: 18 | 28 °C
I am very happy with this SFF build's performance thus far and extremely pleased with the performance of the little engine that could... at low rpm settings (under 700 rpm) the cooler is whisper quiet and I believe the Noctua may actually be more noisy than the Engine 27! The machine-like hum/whistle doesn't begin until the Engine reaches speeds over 700 rpm and the very load whine-like report, as heard on some YouTube review videos, only occurs when it is at max speed settings over 5500 rpm.
Suqrk68852 is offline
post #2714 of 2861 (permalink) Old 01-10-2017, 08:06 PM
rfarmer's Avatar
Originally Posted by ricochetsew View Post
UPDATE (UV Siamese)
CPU: 24 | 57 °C
SYSTEM: 27 | 54 °C
M.2 SSD: 36 | 63 °C
I am curious about something, is the bottom of your case solid. I have a Gigabyte Z170 with a bottom mounted M.2 SSD and my temps aren't nearly as high, highest I have seen is 52C. My Ncase has large ventilation on the back side of the case though.
ncase m1
(14 items)
Intel i7 8700k
MI-6
Operating System
MS Windows 10 Pro
Gigabyte Z370N WIFI
Ncase M1
Operating System
Keyboard
Logitech G105
Mouse
Logitech G402
Audio
rfarmer is offline
post #2715 of 2861 (permalink) Old 01-10-2017, 08:23 PM
Rep: 0
Yes, completely solid; no venting.
I have a Gigabyte Z170 with a bottom mounted M.2 SSD and my temps aren't nearly as high, highest I have seen is 52C,
From my limited internet research I believe the Samsung M.2 SSDs run slightly cooler than the Crucial M.2 SSDs so that could be a major factor. Also, please note that that max temp was begot via a SSD Stress Test conducted here in Thailand with no air conditioning on.
Yeah, probably a combination of inferior case ventilation (Silverstone ML06B-E has limited rear panel venting) and a slightly hotter running Crucial M.2 SSD. I am not too concerned as long as it stays under 70 C!
post #2716 of 2861 (permalink) Old 01-12-2017, 10:57 AM
Zebeyo's Avatar
Rep: 10 (Unique: 8)
Raijintek Metis - Sign me up! Downscaling from a Node 304.
"My goal is simple. It is a complete understanding of the universe, why it is as it is and why it exists at all."
- Stephen Hawking
Zebeyo is offline
post #2717 of 2861 (permalink) Old 01-13-2017, 02:16 AM
Linux Lobbyist
Rep: 1 (Unique: 1)
Encode a video or dvd with software like handbrake - stresses the cpu to the max
Play a couple of games where you max every setting - should at least stress the gpu to the max
Running any other bench or stress test, will give you results that will never be anything like the results you are going to get in everyday use.
for instance, software like intel burn, or other torture application is just that, torture of your component, and heaven or valley are synthetic, and doesn't use api's and call routines typical for gaming or encoding.
Hope this helps, and nice rig! looks very clean!
storm-83 is offline
post #2718 of 2861 (permalink) Old 01-18-2017, 08:22 PM
Rep: 0
Thank you. Unfortunately not a gamer nor video/photo editor so no dedicated GPU nor such related software installed. Cheers,
post #2719 of 2861 (permalink) Old 02-02-2017, 11:03 AM
TAGsystems's Avatar
Rep: 0
Some epic SFF builds here!!
Need to hurry up and crack on with my design for one!!
TAGsystems is offline
post #2720 of 2861 (permalink) Old 02-03-2017, 03:11 AM
hrockh's Avatar
Rep: 37 (Unique: 36)
hrockh is offline
