[Official] uSFF/SFF Club - Page 63 - Overclock.net - An Overclocking Community
post #621 of 2861 (permalink) Old 04-12-2014, 07:28 AM
tysonischarles's Avatar
Rep: 5 (Unique: 4)
Originally Posted by concept73 View Post
Love the cable management! cant wait to see the loop!
Air cooled frown.gif couldn't fit the pump/res in frown.gif
I'm actually a Nvidia fanboy, Fury X hype was too stronk.
tysonischarles is offline
post #622 of 2861 (permalink) Old 04-14-2014, 12:56 AM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by tysonischarles View Post
Tyson Charles
Gallery http://imgur.com/a/q7JY1#QXNkhv2
Looking good! How'd you get the colors on the mockup? I thought it was the final build at first.
Also added the new jonsbo C2:
jonsbo C2
200 x 224 x 262mm / 11.7L
[m-itx, triple slot, ATX PSU]
Product Page
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #623 of 2861 (permalink) Old 04-14-2014, 02:05 AM
Allanitomwesh's Avatar
Rep: 52 (Unique: 35)
Interesting, no ventilation, bottom intake,psu as exhaust. The gpu would also have to blow heat out the case then. Could do wonders for quitness this. Temps,not so much...
Good things come to those who wait.
Allanitomwesh is offline
post #624 of 2861 (permalink) Old 04-14-2014, 02:21 AM
Rep: 5 (Unique: 4)
post #625 of 2861 (permalink) Old 04-14-2014, 02:23 AM
Phobia's Avatar
Rep: 4 (Unique: 4)
What's so important is that need to maintain enough intake of cold air and the best hot air out, ideas?
Phobia is offline
post #626 of 2861 (permalink) Old 04-14-2014, 02:56 AM
Sexagenarian
Rep: 28 (Unique: 21)
Originally Posted by pony-tail View Post
As of (hopefully)tomorrow I am about to embark on my first full sff build - I have had Shuttles before - but this time I am starting with an empty case . A Lian Li PC-TU200B to be precise - with a Gigabyte GA-F2A88XN-WIFI FM2 board and an AMD A10-7850K APU , with a couple of Seagate 1 Tb hard drives . I've not worked out what PSU to use as the 550 watt Antec (VP-550) I bought for it has REALLY long cables .ll
That's all I have bought so far but it is a start .
Still have to get Ram and an optical drive - looking toward a bluray but not sure . I would like to get a low profile cooler rather than the stock one - but not sure which one because of ram slot clearance .
Thats it so far -
I posted earlier about my upcoming build
Well things have not gone as planned !
First even with the F3 bios we could not get the A10-7850 to work on on the board . So I swapped it out for an Intel board - A Gigabyte Z87N-wifi and a 4770 non k . Then my case arrived damaged and has been sent back to the wholesaler - new one will be here next week.
If the pics actually turn out you will see that I have built the machine in an old micro atx Antec case as a temporary measure til the new one turns up .
Just hoping nothing else bad happens .
pony-tail is offline
post #627 of 2861 (permalink) Old 04-14-2014, 10:52 AM
Linux Lobbyist
concept73's Avatar
Rep: 5 (Unique: 5)
concept73 is offline
post #629 of 2861 (permalink) Old 04-14-2014, 05:03 PM
InfraRedRabbit's Avatar
Rep: 11 (Unique: 11)
Hi guys...first time poster here.
Ive recently had to RMA my Antec ISK 300-150 for a PSU issue and Antec replaced it without return of the old case (sweet!).
So I've been thinking this seems like a good opportunity for a first time SFF build. Ive recently been looking at the new Galaxy 750Ti OC Slim - anyone got any ideas on how high the heatsink runs in terms of slots on this? The web states 2-slot but it doesnt look like a full hieght 2-slot cooler to me.
Would be pretty awesome to be able to slot one of these badboys into an ISK 300 with a reasonable power i3/i5 - with a custom cooler/PSU solution of course.
Any ideas/feedback/experience would be great. Id measure the space myself but i dont have a spare mobo to put in the case to measure the GPU clearance in the case.
Cheers
InfraRedRabbit is offline
post #630 of 2861 (permalink) Old 04-14-2014, 07:07 PM - Thread Starter
NFSxperts's Avatar
edit: Added your new pics.
I had thought that clear side panel looked familier
Cheers
The isk300 has space for a singleslot low profile card. The galaxy card has a low profile bracket which you can replace by removing the vga ribbon cable.
http://www.galaxytech.com/__EN_GB__/Product2/ProductDetail?proID=517&isStop=0&isPack=False&isPow=False
That 750 sounds perfect for your needs (low power, low heat, short pcb), except for the dual slot heatsink.
If you can somehow find a single slot cooler replacement for it, it'd be perfect.
