[Official] uSFF/SFF Club - Page 72 - Overclock.net - An Overclocking Community
post #711 of 2861 (permalink) Old 05-07-2014, 06:46 AM
Linux Lobbyist
concept73's Avatar
Rep: 5 (Unique: 5)
Opinions on test benches? currently designing an Itx watercooled bench, so the internal workings will only be about 10 liters but then there is the motherboard ontop, opinions on brining it to the group?
If you want to see it im more thanhappy to post, if not ill just post in other threads, up to you guys smile.gif
concept73 is offline
post #712 of 2861 (permalink) Old 05-07-2014, 07:52 AM
Allanitomwesh's Avatar
Rep: 52 (Unique: 35)
Look who's come to town
http://www.techpowerup.com/mobile/200578/silverstone-milo-ml07-now-available.html
Good things come to those who wait.
Allanitomwesh is offline
post #713 of 2861 (permalink) Old 05-07-2014, 09:19 AM
Linux Lobbyist
concept73's Avatar
Rep: 5 (Unique: 5)
Yes my cad work is crap, but the frame will be made from metal and welded, with either left open, or acrylic panels havent decided, but overall size will be 300x180x160, More updates tonight smile.gif
post #714 of 2861 (permalink) Old 05-07-2014, 10:10 PM
Interesting
post #715 of 2861 (permalink) Old 05-08-2014, 03:51 AM
ataryens's Avatar
Rep: 2 (Unique: 2)
Hello all,
Figured this is the best place to ask. I plan on going from sg05 to something smaller as I dont need a gpu. Thinking of getting the (1) Antec ISK110($70) + extra power brick or the (2) Lone Industries L1 + two power bricks.
My questions are:
1. Is this what I would need as a 2nd power brick for the ISK110? http://www.ncix.com/detail/mini-box-ea11203x-series-102w-b7-58019.htm
2. Does the L1 come with everything I need except for a power brick? Would I be able to get 2 of the above or do I need something for the internal as well. Such as http://www.ncix.com/detail/picopsu-80-with-power-kit-includes-28-50810.htm
Thanks
ataryens is offline
post #716 of 2861 (permalink) Old 05-08-2014, 06:56 AM
Rep: 7 (Unique: 6)
Why would you need two picoPSUs? There are stronger ones with 150w and 160w you can use if you need the extra wattage for your CPU and HDDs/SDDs. There are also power bricks with 120w and more I think.
I would go with Lone's case, just because he has done some really great work with his case.
hampurista is offline
post #717 of 2861 (permalink) Old 05-08-2014, 09:41 AM
frack0's Avatar
Rep: 23 (Unique: 22)
Originally Posted by ataryens View Post
Hello all,
My questions are:
Thanks
The L1 comes with a power switch and some rubber fan mounts, you need to get a picoPSU and a brick, but that is about it. The PSUs usually come with the rest of what you need. I used a picoBox Z3 200W PSU with a Dell 330W brick on mine powering a 3770K mildly OC'd. There's one guy running and AMD 7750 low profile graphics card plus CPU off of the 160-XT with no problems, I don't think you'll need a second brick, just choose wisely, brick power should be greater than the PSU power. Although this is easier done with 19V bricks, my picoBox PSU takes 19V input, got it off ebay and works great.
http://www.pico-box.com/z3-atx-200.html
HDPLEX makes some really nice supplies also but don't plug directly into the mobo
frack0 is offline
post #718 of 2861 (permalink) Old 05-08-2014, 09:52 AM
TinoArg's Avatar
Rep: 4 (Unique: 4)
Hi, I join the club with a Winsis WI-02 from an OEM computer I bought for my Steam Machine/HTPC. It's still on WIP.
Case: Winsis Wi-02 (6.45lts)
CPU: AMD Llano A8-3850
GPU: AMD Radeon HD6550D 512MB
MoBo: ASRock A75M-ITX FM1
RAM: G.Skill 2x2GB DDR3 2133MHz DC
HDD: Velociraptor 300GB + Samsung 750GB
ODD: Lite-On DVD-RW slim
PSU: HP TFX12V 220W (16A @12V)
WiFi: TP-Link 7200ND @ internal USB header
OS: Windows 8.1 Pro MCE x64 + Steam Big Picture as shell
Cooling:
- GeminII S modded heatsink
- Noctua NF-A9x14 PWM fan
- AVC 80x35mm 0.85A PWM fan (from Dell Optiplex GX620)
- Custom heatsinks on VRMs
I set bclk to 113.5MHz and overclocked RAM to 2133MT/s (from 1866), NB to 916MHz (from 800), GPU to 685MHz (from 600) and underclocked CPU to 2850MHz (from 2900),with all the undervolt I could. Temps are under 55°C under load. Noctua at 5/10 from BIOS until 50°C and AVC 1/10 until 55°C.
EDIT.: Fixed URLs!
TinoArg is offline
post #719 of 2861 (permalink) Old 05-08-2014, 11:40 AM
Smanci's Avatar
Rep: 75 (Unique: 64)
The. Most. Beautiful. Case. Ever.
Smanci is offline
post #720 of 2861 (permalink) Old 05-08-2014, 03:28 PM
ataryens's Avatar
Rep: 2 (Unique: 2)
I forgot to mention that I move the computer between 2 places where I have a monitor/keyboard/etc setup.
So if I understand correctly, if I dont want to move the brick (outside of case), I would have to buy a separate brick for the antec and if I go the L1 route, I would need a combo picoPSU+brick and then another brick alone.
Id really appreciate a confirmation.
Thanks!
ataryens is offline
