[Official] uSFF/SFF Club - Page 94 - Overclock.net - An Overclocking Community
post #931 of 2861 (permalink) Old 08-15-2014, 02:37 AM
InfraRedRabbit's Avatar
Rep: 11 (Unique: 11)
Originally Posted by frack0 View Post
Nice rig!
thanks! biggrin.gif was really happy with how it went together - a few minor changes to be made (replace the H80i i expect) and reroute some cale management and ill be stoked.
another note i forgot to mention is that if you use a really long card you effectively compartmentalise the case between the CPU and GPU areas, which really helps with keeping overall case temps low
InfraRedRabbit is offline
post #932 of 2861 (permalink) Old 08-15-2014, 03:18 AM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by InfraRedRabbit View Post
some pics of my build in the new M1. the build (including teardown of my old pc) took me maybe 3h, half of which was working out how to fit the H80i (poor choice by me about 12 months ago to go with a fat rad AIO).
thanks to W360 and Necere for probably the highlight of my year - the little intricacies of building in this case has been the most fun ive had in a long time. quite seriously, the more i looked the more options to put different parts in different places, and its all been just so well thought out.
pull up your socks pc case building industry, because this case is outstanding, and nothing ive ever built in matches the ingenuity or attention to detail the M1 v2 has.
parts:
4x Noiseblocker eLoop 120mm PWM fans
SX600-G PSU
i5 4670k @ 4.2ghz
H80i 120mm AIO
Z87i-pro mITX
XFX R9 290 DD (mild OC)
2x 250GB Samsung EVO SSD's
WD Black 750GB 2.5" HDD
enjoy!
That's a really well thought out case, and your cable management isn't bad either!
Originally Posted by Tennobanzai View Post
Awesome! I'm wondering if the upgrade to the SX600-G is worth it for the fan noise alone. Maybe i'll wait for the SFX-L tongue.gif
This is what I'm planning as well. Maybe even a 300-450w SFX-L to replace my ST45SF-G. I'm currently only using just over 200watts. If the ST30SF has 2x 6pin connectors, I would've gotten it already.
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #933 of 2861 (permalink) Old 08-15-2014, 09:03 PM
Stock
hyp36rmax's Avatar
Rep: 144 (Unique: 122)
Well here's my SG05
hyp36rmax is offline
post #934 of 2861 (permalink) Old 08-17-2014, 07:51 PM
Just added an Asus R7 240 to my Antec ISK. Much better improvement in how the PC runs. I'll take pics of it later, time to play WOT on my main rig. biggrin.gif
WEXX is offline
post #935 of 2861 (permalink) Old 08-20-2014, 07:54 AM
seriva's Avatar
Rep: 0
Specs:
Case: Chieftec IX-01Bl
Proc: AMD A10-7700K Black Edition
Mobo: ASRock FM2A88X-ITX+
Memory: Corsair Vengeance LP 8GB 2133MHz CL11
SSD: Crucial M500 mSata 120GB
HDD: WD Blue WD5000LPVX, 500GB
CPU Cooler: Zalman CNPS2X
Case FAN: 50 mm, 3500 rpm
OS: Windows 8.1 Pro
Power: picoPSU-160-XT
Pics:
I`m not sure about the size of the case in liters but its super small. The A10-7700K is slightly under clocked and volted to keep the temperatures down. Idle is +-40 degrees and under full load around 67 degrees. Power usage is 40 watt idle and 95 watt under full load.
I plan to swap out the current msata SSD, HDD and the 50 mm fan and put in a 500 gb msata SSD and a 120 mm slim fan later on. I hope that then I can even overclock it a bit.
seriva is offline
post #936 of 2861 (permalink) Old 08-20-2014, 08:13 AM
Allanitomwesh's Avatar
Rep: 52 (Unique: 35)
Nice build
Good things come to those who wait.
Allanitomwesh is offline
post #937 of 2861 (permalink) Old 08-20-2014, 09:28 AM
Reindoonicorn's Avatar
Rep: 2 (Unique: 2)
Reindoonicorn is offline
post #938 of 2861 (permalink) Old 08-20-2014, 10:55 AM
SilkyZ's Avatar
Rep: 2 (Unique: 2)
Originally Posted by hyp36rmax View Post
Well here's my SG05
Was going to ask you on the SG05/06 thread, but are you going to add the GPU to the water-loop any time soon?
SilkyZ is offline
post #939 of 2861 (permalink) Old 08-20-2014, 12:02 PM
Stock
hyp36rmax's Avatar
Yes, awaiting arrival of my EK block as we speak. My SG05 build is being transferred to a Cooler Master Elite 130 case. While I'll be using my left over parts to build another system into the SG05 smile.gif
post #940 of 2861 (permalink) Old 08-20-2014, 01:29 PM
SilkyZ's Avatar
Rep: 2 (Unique: 2)
SilkyZ is offline
