[Official] uSFF/SFF Club - Page 95 - Overclock.net - An Overclocking Community
post #941 of 2861 (permalink) Old 08-20-2014, 02:11 PM
wyjeba's Avatar
Rep: 6 (Unique: 3)
Nexus Psile 10B
Hardware:
Gigabyte B75N
Pentium G2020
Cryorig C1
2x4GB Exceleram White Shark 1600 CL9 1.5V
Crucial M4 256GB
Seagate Momentus 1TB
TL-WN881ND
ITX FTW!
wyjeba is offline
post #942 of 2861 (permalink) Old 08-21-2014, 09:54 AM
Allanitomwesh's Avatar
Rep: 52 (Unique: 35)
Good things come to those who wait.
Allanitomwesh is offline
post #943 of 2861 (permalink) Old 08-21-2014, 08:20 PM - Thread Starter
NFSxperts's Avatar
Rep: 73 (Unique: 69)
Originally Posted by hyp36rmax View Post
Well here's my SG05
Added all of you.
Originally Posted by seriva View Post
Specs:
Case: Chieftec IX-01Bl
Proc: AMD A10-7700K Black Edition
Mobo: ASRock FM2A88X-ITX+
Memory: Corsair Vengeance LP 8GB 2133MHz CL11
SSD: Crucial M500 mSata 120GB
HDD: WD Blue WD5000LPVX, 500GB
CPU Cooler: Zalman CNPS2X
Case FAN: 50 mm, 3500 rpm
OS: Windows 8.1 Pro
Power: picoPSU-160-XT
Pics:
I`m not sure about the size of the case in liters but its super small. The A10-7700K is slightly under clocked and volted to keep the temperatures down. Idle is +-40 degrees and under full load around 67 degrees. Power usage is 40 watt idle and 95 watt under full load.
I plan to swap out the current msata SSD, HDD and the 50 mm fan and put in a 500 gb msata SSD and a 120 mm slim fan later on. I hope that then I can even overclock it a bit.
It should be 2.7Liters, even small than the 3.7L Antec ISK110. Whats the height of the cpu cooler or the max cpu height for the case? I quite like the size.
Originally Posted by wyjeba View Post
Nexus Psile 10B
Hardware:
Gigabyte B75N
Pentium G2020
Cryorig C1
Crucial M4 256GB
TL-WN881ND
That's a unique case, got any pics of the internal?
Originally Posted by WEXX View Post
Just added an Asus R7 240 to my Antec ISK. Much better improvement in how the PC runs. I'll take pics of it later, time to play WOT on my main rig. biggrin.gif
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><div style="text-align:center;"><a href="https://www.overclock.net/t/1300645/usff-sff-club">The Official <span style="font-size:9px;">uSFF</span>/<span style="font-size:10px;">SFF</span> Club</a></div><span></span><br><span>GeForce2 MX 64 &lt; FX 5200 128 &lt; Mobility Radeon 9700 64 &lt; 8400M GS 128 &lt; 9800GT 512 &lt; GTX 460 1 &lt; 650Ti Boost 2 &lt; 650TI Boost SLI 2 &gt; 650Ti Boost 2 &lt; GTX 1070 8</span><br><br><span>rma amount of times: (# of times rma-ed/product failed after warranty period/products owned)</span><br><span>Antec AIO: 2/0/1 | Corsiar AIO: 1/0/2 | Corsair ddr2 sodimm ram: 2/0/2 | Adata ddr2 ram: 2/2/4 | Adata SSD: 2/0/1</span><br><span>WD Black: 1/0/2 | WD Green: 1/1/3 | SilverStone SFX PSU: 2/0/4 | MSI gpu: 1/1/2</span><br><br><span>Products I am avoiding: Sandforce Controller based SSD | TLC nand flash SSD | Asetek | Anything that has season passes</span></div></div>
NFSxperts is offline
post #944 of 2861 (permalink) Old 08-22-2014, 09:57 AM
wyjeba's Avatar
Rep: 6 (Unique: 3)
Sure.
For now that's all. I'm waiting for the white wires to the power supply.
ITX FTW!
wyjeba is offline
post #945 of 2861 (permalink) Old 08-22-2014, 10:03 AM
@NSFexperts:
Why yes, and photos of my N54L microserver under re-construction to become my freenas server. WHS2011 was a PITA, so it was time to rebuild it. Waiting on 8gb of ECC memory to get here, and I have ALLOT of files to move as well.
Antec:
N54L:
WEXX is offline
post #946 of 2861 (permalink) Old 08-22-2014, 10:06 AM
Sure.
WEXX is offline
post #947 of 2861 (permalink) Old 08-22-2014, 11:46 AM
SilkyZ's Avatar
Rep: 2 (Unique: 2)
Sure.
Oh poo, it looks like its only a single slot PCI capable..... they make 750ti in single slot right?
SilkyZ is offline
post #948 of 2861 (permalink) Old 08-22-2014, 12:07 PM
Canada Goose Puncher
CynicalUnicorn's Avatar
So has anybody considered using a modified version of THIS backplate, an x4 to x16 riser, and a single-slot 750 or 750Ti? You ought to be able to a thin mITX Xeon E3 system in there.
Alternatively, get a single-slot DDR3 R7 240 or 250, a 7850k, an A88X motherboard, and desolder the rear I/O ports that might get in the way. You know, for warranty-voiding science. That's the smallest possible hybrid crossfire system, I believe.
Quote: Originally Posted by TheBadBull View Post
someone sig this
CynicalUnicorn is offline
post #949 of 2861 (permalink) Old 08-22-2014, 12:36 PM
ccRicers's Avatar
Rep: 72 (Unique: 66)
@ilovelampshade is working a on a build here that has a similar graphic card placement with the L1 case and a low profile 750 Ti, which involves modding the case. His pictures show exactly how the card is placed.
It ends up being taller than the backplate you mentioned, but it shows how much room there is between the card's fan and CPU fan so both of them get adequate cooling. He used a taller riser so that the card wouldn't interfere with the CPU cooler he's using.
ccRicers is offline
post #950 of 2861 (permalink) Old 08-22-2014, 01:13 PM
Nice! So definitely possible then. The reason it's taller is because the rear I/O is twice the height. The backplate I linked is for thin mITX, found in a very few Intel boards, and it apparently allows an expansion slot to sit on top of that at a standard height. If you're willing to void warranties, then desoldering onboard sound among other ports would allow that backplate to be used with practically any motherboard. Several ports could even be resoldered to a header and used elsewhere.
someone sig this
