Gigabyte Z77N-Wifi/H77N-Wifi = No voltage control? (Voltage hard mod info inside) - Page 4 - Overclock.net - An Overclocking Community
post #31 of 45 (permalink) Old 10-18-2012, 07:15 AM
Rep: 8 (Unique: 8)
Originally Posted by Jocelyn84 View Post
Lastly, the Broadcom chip on the Asrock board is much better than the Realteks on the Gigabyte
Originally Posted by xxsashixx View Post
Sucks that the Asrock H77 has a realtek chip in it, gah I don't need the Z77 frown.gif
What is the difference between these two?
SpyderMS is offline
post #32 of 45 (permalink) Old 10-18-2012, 09:07 AM
So yeah.. anyone care to help me with this..? we can likely find a way to mod for vcore..
 From the pic I posted above, I do not see an IC for vcore.. it may be mounted on the back of the PCB...
CL3P20 is offline
post #33 of 45 (permalink) Old 10-18-2012, 09:42 AM
funfortehfun's Avatar
Rep: 109 (Unique: 94)
Not all motherboards have overvolting/undervolting capabilities. I know for a fact that the P8H77-I does not have overvoltage or undervoltage, and now neither the H77N-WiFi. The best bet for you is to try the H77M-ITX and see if that works for you. Last chance would be just to use a Z77 mini-ITX motherboard.
flickr | Camera Hardware: Nikon D90 + AF-S DX Nikkor 12-24 f/4G + AF-S DX Nikkor 35mm f/1.8G + AF-S micro-Nikkor 105mm f/2.8G + Yongnuo YN-560 III + Crumpler 7MDH wheee.gif
Hilarious Quotes (Click to show)
Question - the dollar sign goes before U.S. monetary amounts. If I am speaking in terms of Canadian dollars, do I put CAD before or after the amount?
you put it on top like a hat, i.e. canada aka USA's hat
CAD
3.50
funfortehfun is offline
post #34 of 45 (permalink) Old 10-18-2012, 04:27 PM
Rep: 6 (Unique: 5)
I have sent you a PM
xxsashixx is offline
post #35 of 45 (permalink) Old 10-18-2012, 05:47 PM
got it .. looks like power control IC located in your first pic.. just to lower left of large iTE chip
CL3P20 is offline
post #36 of 45 (permalink) Old 10-19-2012, 09:16 AM
Got it...
 Got a copy of the datasheet this morning in my email from Intersil biggrin.gif
**Now - the first pic is poor quality.. but i can see there is no surface mounted resistor on the backplane that connects to 'FB'. The orientation in the first photo, has pins 11-20 located along the right side of the chip as it sits in the picture [notice the small dot in corner to indicate alignment].
 This means that you need to locate the 'dive-through' on the front side of the PCB.. where there will be a small surface mounted resistor. It should have continuity to the 'FB' pin on one side of the resistor... and continuity to ground on the other; if it does -> this is your mod point. Measure and post the resistance here in the thread please.. with a better pic or two if you can manage as well. wink.gif
The formula for calculating your VR size for vcore mod is : [r* 20] = ~size for VR needed for mod, where stock resistance value = 'r'
 Good luck.. I will look back for your post.
CL3P20 is offline
post #37 of 45 (permalink) Old 10-19-2012, 04:49 PM - Thread Starter
Rep: 297 (Unique: 244)
CL3P20, let me know if I should change the title of the thread. Maybe add "Hard voltage mod info inside"? tongue.gif
Jocelyn84 is offline
post #38 of 45 (permalink) Old 10-19-2012, 06:15 PM
Rep: 6 (Unique: 5)
Pmed you
Also here are some better pics
This pic shows the two resistors that looks like it is connected to the IC
Can't tell which resistor is connected to the IC, there are couple above the caps
post #39 of 45 (permalink) Old 10-19-2012, 11:50 PM
edited the pic.. you are definitely in the right spot on that last pic in your above post.
**FB pin marked in orange
Measure there for resistance to ground. Then probe those 2x resistors in your pic, just beneath the caps. One of them will have the same resistance value on one side.. and will be connected to ground on the other. We can use it as a mod point.. or the spot on the mobo I have marked is suitable mod point as well. Please measure/record/post resistance value.
**Do you have another CPU for this mobo to test? - It is picking vcore.. so resistance value should be related to your current vcore setting. We will call this our new "stock" value.
CL3P20 is offline
post #40 of 45 (permalink) Old 11-27-2012, 10:29 PM
dmanstasiu's Avatar
Rep: 154 (Unique: 118)
So since the Gigabyte Z77 doesn't have any voltage control, any concrete data that the ASRock / Asus Z77 mITX boards do?
Derickwm, EK Employee: "The motherboard will be safer in the blender"
Sunreeper: Yeah dman is so Canadian that he oozes out maple syrup
dmanstasiu is offline
