KaTaToNiK ~ W/C Prodigy - Overclock.net - An Overclocking Community
post #1 of 23 (permalink) Old 10-25-2012, 08:38 AM - Thread Starter
CH4PZ's Avatar
Rep: 23 (Unique: 21)
WeLcOmE !! wave2.gif So seems EVERYONE jumped on the prodigy bandwagon, lol but gonna do a bit of work to mine so thought i'd throw together a log. These pics are just to get the log going, sorry but they were taken on my iphone. i actually had the rig up and running first on air, then once it installed windows ok, went to water. Given that its just a 240 rad the temps were fine(mid 30's) but when i went to overclock theres just no option there, and had a few issues with the board so at the moment its just being tested, which isnt bad gives me a chance to do some case work
MoBo and EK Supremacy, i really didnt like the circle design, but when i got it i was suprised it has a real classy, quality design
so this is how you do the pin striping, apply the paint
then i just use my license to scratch off the excess. this the backplate as i forgot to do a after pic but you get the idea
2nd in
Cant really see but this the loop
another angle, ended up getting a rotary off the t-line so minimal tubing, i also brought more monsoon fittings and theyre all silver shining fitting, all uniform like biggrin.gif
Fillport, its only red because i had it from another build, like much all of these parts
then done the gpu window, was just trying designs at this stage
then out she goes....
NOW, just from the get go i wanna be clear !! i PERSONALLY think Di-Noc is entirely waaaay over used in modding these days!! accents are cool but people go bezerk with it, i prefer subtly!!... that being said i decided to Di-Noc most of this Project LOL lachen.gif just because i find the white much more stealth than black, and i brought a roll of black, and a roll of white a year n half ago and wanted to use it somewhere ...
i just fluked the first window being in line with the mb tray/psu cover but was a touch out, but im not too worried, on the other side though i had to change the design as theres a large bar that holds the power/reset/usb etc. so i followed similar window at the back, then arched the top so that i could see the water level in the T-line, and sort of cut it back, i dont like it as much as the other side but it should really help with cable management of the HDD etc and still allows you to view the loop, and enermax Vegas 140mm fan i now have in the back
i have a lot more planed for the build, but i need the board back before i can do much more, hopefully get my dslr back too for some decent pics wink.gif Stay tuned
CH4PZ is offline
post #2 of 23 (permalink) Old 10-25-2012, 09:27 AM - Thread Starter
CH4PZ's Avatar
So JUST shoe horned the fan controller in, sits proud about a mm at the top but its barely noticeable. the entire front panel will be getting re-covered, as you can see the top above fan controller knife slipped and tore the di-noc, got like 3m, so should be right thumb.gif
CH4PZ is offline
post #3 of 23 (permalink) Old 10-29-2012, 02:02 AM
( ━☞´◔‿ゝ◔`)━ ☞
Kokin's Avatar
Rep: 427 (Unique: 365)
Don't you get a lot of vibrations from your D5 being bolt mounted? Ever since I had mine suspended in mid-air by tubing, it's pretty silent even at setting 4 or 5. When I had it bolted on, it was loud at setting 3.
It's looking pretty good and clean so far. I really like how you have different shapes for your windows, keeps it unique. thumb.gif
Black Heart
(22 items)
AMD Ryzen 9 3900X 12c/24t
Asus ROG Crosshair VIII Impact X570
EVGA GTX 1080Ti FTW3 11GB
G.Skill TridentZ DDR4 2x16GB 3200MHz 14-14-14-34 1.35V
Inland Premium 2x2TB PCIe 3.0 NVMe SSD in Raid0
Crucial MX500 2TB Sata SSD
Seasonic Prime 600W Titanium Fanless SSR-600TL
EK-Supremacy EVO RGB - Acetal+Nickel
EK-FC1080 GTX Ti FTW3 - Nickel
Phanteks Glacier R160 Reservoir
Swiftech MCP35X
Hardware Labs Black Ice Nemesis 280GTS White
Hardware Labs Black Ice Nemesis 240GTS White
Noctua NF-A12x25 PWM (4x rad intakes, 1x case exhaust)
Case Labs Mercury S3
Operating System
Windows 10 Pro
Alienware AW3418DW 34" Ultrawide IPS 3440x1440 120Hz G-Sync
Qnix QX2710 PLS 2560x1440 120Hz
Keyboard
WASD CODE V2 87-Key [MX Green + /dev/tty Keycaps]
Mouse
Logitech G Pro Wireless
Audio
Sennheiser HD 6XX
Audio
Micca OriGen G2 USB DAC/Amp
Kokin is offline
post #4 of 23 (permalink) Old 10-29-2012, 06:34 AM - Thread Starter
CH4PZ's Avatar
thanks m8 biggrin.gif nah not really and when i briefly had it up and running it was straight steel bracket onto steel, i've now installed a silicon pad underneath so hopefully its pretty quiet thumb.gif
CH4PZ is offline
post #5 of 23 (permalink) Old 10-29-2012, 06:41 AM - Thread Starter
CH4PZ's Avatar
thought i recognized your name, i wandered through your build log a few weeks back!! didnt notice you had a white one too LOL
CH4PZ is offline
post #6 of 23 (permalink) Old 10-29-2012, 07:03 AM - Thread Starter
CH4PZ's Avatar
Started on the side panel over the weekend installing the vandal reset and power
marked them out exactly where i wanted them, evenly spaced so the reset was halfway between the power and headphone/mic
then marked the old power and reset for removal
Then off with his head
then the mounting bar also had a date with the Hacksaw
Had a busy day at uni the next day, so thought i'd outsource some work to my dad who was twiddling his thumbs, wats the worst that could happen, i marked exactly to the mm where i wanted them..... BIG mistake!! much like other 'outsourcing' you get a much lower quality madsmiley.png not only did he not follow my markings, he put them so close together that i almost cant do them up, i was fuming !! he also marked on the outside with texta so they look even closer again(one of the switches they sent was a latching one, hence the fatter line, in the process of getting a replacement now thumb.gif) almost considering welding up part on the hole and moving it, or even source another panel(if possible)
CH4PZ is offline
post #7 of 23 (permalink) Old 10-30-2012, 04:52 PM
( ━☞´◔‿ゝ◔`)━ ☞
Kokin's Avatar
It does look very thin, though if it works, I don't see why you should have to move it.
Black Heart
(22 items)
Swiftech MCP35X
Operating System
Windows 10 Pro
Keyboard
Mouse
Audio
Sennheiser HD 6XX
Audio
Kokin is offline
post #8 of 23 (permalink) Old 11-03-2012, 09:25 AM - Thread Starter
CH4PZ's Avatar
So got some more goodies which should be able to finish off now ... as soon as MB gets back mad.gif
Decided to leave the back off just because it was easier, and the fact that you cant see it anyway as it faces front fan
Had these just lying around from when i first got into pc's 6 years ago, lol thought why not
Switches Finished
But when i tighten it this happens, so might just secure it with double sided tape and not over tighten it
Sooo then my OCD got the better of me, i filed the holes further apart
as you can see theres a bit of a gap when they're in place but i can cover that with the di-noc
then covered the side, pretty happy with the results
CH4PZ is offline
post #9 of 23 (permalink) Old 11-08-2012, 07:22 AM
Hardware Rep
Rep: 283 (Unique: 184)
Bill Owen is offline
post #10 of 23 (permalink) Old 11-08-2012, 07:49 AM - Thread Starter
CH4PZ's Avatar
Originally Posted by Bill Owen View Post
CH4PZ is offline
