[OFFICIAL] Raspberry Pi Owner's Club - Page 68 - Overclock.net - An Overclocking Community
post #671 of 699 (permalink) Old 08-02-2016, 02:54 PM
Mugen87's Avatar
Rep: 6 (Unique: 5)
Anyone know anything about odroid-c2. In my hunt for a cheap linux based Nas sent me to some info that the pi3 only has 100 Mbps Ethernet and usb/Ethernet share a bus. This isn't ideal for a Nas setup (I know it works but I would like performance out of the Nas). This odroid-c2 has a quad core CPU, 2 gb ram, gig Ethernet, and no bus sharing. For $60 of Amazon it sounds good.
http://www.hardkernel.com/main/products/prdt_info.php
DD-WRT Firmware Club
Mugen87 is offline
post #672 of 699 (permalink) Old 08-03-2016, 06:49 PM
Chipfire's Avatar
Rep: 0
Yeah the Raspberry Pi is more of a learning/prototyping/cheap PC. Probably not good for things like routers, NAS, HTPC where your data, security, performance are very important. Not that you can't create these things with the Pi, but its just a baby PC, maybe a large toddler. It can do lots of things, some very well, some more at the level of proof of concept. That's why for $35 it really makes sense as a solution instead of an old PC with its power requirements, space requirements, and heat. The way I see it once you have a real use case that requires more resources than the Pi, you go for something like one of the new inexpensive small PCs.
Give us more info on that odroid-c2 device if you pick one up.
Current build: ASRock X99 Extreme6/3.1<>5930K<>Noctua D15s<>32GB GSkill <> Sandisk Extreme Pro
A few other machines - i7-860, couple of i5s, 4770 Delidded, 4790,
Chipfire is offline
post #673 of 699 (permalink) Old 08-03-2016, 10:58 PM
Eastern Bloc Electronics
Pawelr98's Avatar
Rep: 55 (Unique: 45)
You may want to take a look into Terminals.
They are usually normal x86 computers with passive cooling and actually some upgrade options (like Ram,cpu, some even PCI/PCIE).
And they tend to go for less than most of current powerful ARM miniputers.
Power wise we are talking about 25-30W. I personally use HP T5735 with upgraded cpu (Sempron 2100+ changed to Turion X2 TL-60 as well as very quiet active cooling) as a HTPC.
Even the fastest pc in the world cannot beat imagination.
Spoiler!
i7 [email protected]@1.325V 2.05V input
Asrock X99 Extreme 4
Sapphire R9 290X [Uber Mode]
Nvidia Geforce GT240 GDDR5 512MB [PhysX + analog output]
Crucial Ballistix 2400mhz 4GB 1.3V
Crucial [email protected] 4GB 1.3V
Seagate 4TB
Samsung 840 EVO 120GB[OS]
WD Red 1TB
Samsung 840EVO 120GB[Arma 3]
Cooler Master Real Power 850w
Koolance 380A [modded for LGA2011v3]
MCP655 with Alphacool HF acetal top [5th gear]
Cooltek 120mm rad [antec tri-speed]
Black Water Ultimate 123 [3x Corsair AF120 Performance Edition]
Feser 10/13 UV Tubing
Alphacool CKC clear
Cooltek 120mm Rad [Corsair SP120 High Performance Edition]
Alphacool GPX-A 290 [290X waterblock]
Cooler Master Haf 932 Amd Edition
Operating System
Windows 7 Ulitimate 64 bit
LG 29EA93 [2560x1080]
Samsung SMB2030N [1600x900]
LG L1715S [1280x1024]
DIY display on V59 controller[[email protected]]
Keyboard
4Tech X7 G800
Mouse
Microsoft Mobile Mouse 4000
Audio
Superlux hd681
Audio
FiiO E07K
Audio
SoundMax Superbeam [bundled with P5B DLX]
Other
Scythe Kaze Master Pro 6 chanell
Other
2x Sharkoon 30cm red cold cathodes
Other
2x Revoltec 10cm UV cold cathodes
Athlon II X2 250 @2GHZ @1core
Gigabyte 870A-USB3
Ati X600 128MB
GoodRam 4gb 1333mhz
Hitachi Ultrastar 1TB
6x Hitachi 2TB (RAID 6)
Samsung 40gb[OS]
2x160GB RAID 1
Pentagram Silent Force 460W
Operating System
Debian 8.2.0 x64
Other
Ever Eco Pro 700 CDS [UPS]
Other
Edimax EW-7318USg [Access Point]
Pawelr98 is offline
post #674 of 699 (permalink) Old 08-03-2016, 11:22 PM
Mugen87's Avatar
Rep: 6 (Unique: 5)
Power wise we are talking about 25-30W. I personally use HP T5735 with upgraded cpu (Sempron 2100+ changed to Turion X2 TL-60 as well as very quiet active cooling) which I use as HTPC.
My end plan was to use an arm device to serve a usb raid enclosure in raid 1. Space and cost being the factors for me. I won't be streaming movies over the network (music yes), but would like to backup computers directly to the nas.
Should I go with something that is a step up from an arm CPU? What are these WD cloud books using for a cpu...
Mugen87 is offline
post #675 of 699 (permalink) Old 08-04-2016, 09:40 PM
Pawelr98's Avatar
Cost wise such stuff can wary from sub-10$ on low-end(like HP T5720) to 50-ish$ on "high-end" side(like HP GT7725).
All depends on what exactly you need.Size wise it should be similar or bit bigger than aftermarket NAS.
In general all aftermarker NAS use very weak hardware for high cost.
According to some DIY guy who took apart such Western Digital MyCloud those devices use low power dual core ARM @650Mhz as cpu.
It also has 256MB ram.
http://mybookworld.wikidot.com/my-cloud
I guess any other devices are similar.
Building your own NAS allows you to customize it more (for example adding streaming or torrent client).
Spoiler!
Seagate 4TB
WD Red 1TB
Alphacool CKC clear
Operating System
Keyboard
4Tech X7 G800
Mouse
Audio
Superlux hd681
Audio
FiiO E07K
Audio
Other
Other
Other
Gigabyte 870A-USB3
Ati X600 128MB
GoodRam 4gb 1333mhz
Samsung 40gb[OS]
2x160GB RAID 1
Operating System
Debian 8.2.0 x64
Other
Other
Pawelr98 is offline
post #676 of 699 (permalink) Old 12-03-2016, 01:13 PM
Rep: 63 (Unique: 48)
I'm also upgrading my RPi2 to Odroid-C2, such a massive upgrade it should be. 4K output and everything, amazing deal for such a cheap and tiny machine.
kbab?
Stige is offline
post #677 of 699 (permalink) Old 12-18-2016, 12:55 PM
SLADEizGOD's Avatar
Rep: 9 (Unique: 9)
hey just bought my Raspberry Pi today. Got everything set but I noticed on Youtube videos they don't share where they get the bios & games. does anyone know where i can find them?
SLADEizGOD is offline
post #678 of 699 (permalink) Old 12-18-2016, 01:23 PM
battleaxe's Avatar
Rep: 97 (Unique: 79)
battleaxe is offline
post #679 of 699 (permalink) Old 12-19-2016, 10:09 PM
andyroo89's Avatar
Rep: 80 (Unique: 67)
Originally Posted by battleaxe View Post
How do I join? I'm a Pi 3 owner.
just making a post is sufficient, what are you going to do with it, also your avatar makes me think "how it feels to be the tank"
If you come across cute ginger girls and have pics pm me them :3
<In my avatar, IDK but TheODDone gave me this one <33
andyroo89 is offline
post #680 of 699 (permalink) Old 12-20-2016, 06:41 PM
battleaxe's Avatar
Right now I'm just using it to goof around with. Surfing and that sort of thing is all.
But I have plans to use it to implement speaker crossovers in a stereo system.
Or I might let my kids use it for their computer maybe, not totally sure yet.
