[OFFICIAL] Raspberry Pi Owner's Club - Page 70 - Overclock.net - An Overclocking Community
post #691 of 699 (permalink) Old 11-01-2017, 05:22 AM
in da freezing hell
termathor's Avatar
Rep: 4 (Unique: 4)
Hi there,
Wow, an official RP thread, here, in OC ! I'm in !
So, the project:
- RP3
- a Z wave plus razberry daughter card
- an home automation software (to be defined, which one)
- a proof of concept of a working home automation
The RP3 is cool for this because the controller can be sneaked out anywhere without taking
space. It's largely powerful enough for simple HA. Also, the ethernet port will probably come handy
for remote operation.
Here goes. Parts to be ordered this WE.
If anyone has any inputs for the above, they are very welcome.
[edit] looks like jeedom is gonna be my choice of software to begin with. Next will be home assistant.
[edit2 21/11/2017] OK, I installed raspbian stretch from sept. 2017. The razberry card was also installed. Turned out, the z-way server couldn't boot, due to a missing 1.0.0 SSL lib (post 4 of https://forum.z-wave.me/viewtopic.php?t=25337 gives the solution, but you may have to adapt to whatever pkg there is, currently).
After this, z-way server did boot up as expected, and all z-wave devices worked as expected and could be controlled from the PI.)
However, z-way couldn't do all the stuff I wanted so I moved to jeedom.
Jeedom proved a fuming mess. I can't grab how it works, to be honest. I'll keep reading the doc but I'm not positive I can use a tool I need to read the doc for ... Needs to be straight forward ...
More to come ...
Marvin
(16 items)
Intel Core i5-4690K [email protected] GHz
ASUS Maximus VII Impact mini-itx
Asus GeForce GTX 970 DirectCU Mini
Trident X, 2 X 8 Go, 2400 MHz, CAS 10
Samsung 850 EVO SSD, 512GB
Seagate Desktop SSHD, 2TB
Corsair HX850i
Corsair H90
Thermaltake Core V1
Operating System
W7
Operating System
SteamOS
Big Samsung TV screen, sofa operated
Keyboard
Logitech K810
Mouse
Logitech G602
Audio
Bose Soundtouch 1300
Other
Steam Controler
termathor is offline
post #692 of 699 (permalink) Old 11-01-2017, 07:26 AM
Linux Lobbyist
silvrr's Avatar
Rep: 97 (Unique: 71)
Originally Posted by termathor View Post
Hi there,
So, the project:
- RP3
I run a home automation system off my Pi, I use a Pi3 also and run home assistant (https://home-assistant.io/) the aeotec zwave usb stick is well regarded and a bit cheaper than the daughter card you mentioned. One thing to check though is international compatibility. Different countries use different frequencies for zwave I think.
Home Assistant is rather powerful though and has a pretty active user base and forum if you run into issues. Its biggest strength IMO is it can act like a hub of hubs. It can be your zwave hub, it can integrate a hue system, nest, etc.
silvrr is offline
post #693 of 699 (permalink) Old 11-01-2017, 01:57 PM
in da freezing hell
termathor's Avatar
Rep: 4 (Unique: 4)
Hi there,
Well, yes, I'll consider home assistant as a solution as well. Actually, it didn't ring a bell as being a home automation solution, as per the name smile.gif
As for USB stick, I simply don't like it. USB is to be plugged/unplugged, right ? Such is not the case for a
Z Wave module ...
As for frequencies, I am well aware of this. https://en.wikipedia.org/wiki/Z-Wave states France (where I'm located)
operates in the same freq as Switzerland, where I plan to buy the gear, so I think I am covered.
Thanks for the inputs !
Marvin
(16 items)
Corsair HX850i
Corsair H90
Thermaltake Core V1
Operating System
W7
Operating System
SteamOS
Keyboard
Logitech K810
Mouse
Logitech G602
Audio
Other
Steam Controler
post #694 of 699 (permalink) Old 01-15-2018, 10:59 AM
Cake
TwirlyWhirly555's Avatar
Rep: 20 (Unique: 16)
Could anyone recommend a good place to start learning python for the Pi ?
I don't know what you had in mind
But here we stand on opposing sides
TwirlyWhirly555 is offline
post #695 of 699 (permalink) Old 01-15-2018, 11:12 AM
Otherworlder
epic1337's Avatar
Rep: 217 (Unique: 125)
at home? or in a coffee cafe if thats more comfortable with you.
trolling an adult is very dangerous, don't try it at home nor at work. you don't want to play tag with a rabid man.
epic1337 is offline
post #696 of 699 (permalink) Old 01-16-2018, 08:07 AM
5291Crash's Avatar
Rep: 26 (Unique: 26)
Just found this thread.
Have a couple i use
3B with a TNC board, for packet coms, and a 7" Pi LCD. Powered with a LM2596 step down allowing me to use 6v-40V DC input.
3B with and a DV4mini dongle for DMR comms
Zero W, to tinker with, mostly ordered it because it was cheap and you can only get one at a time generally so stuck it on a 3B order.
Been a while since i had any of them powered on, dang winter.
Ryzen
(12 items)
Ryzen 5 2600X
MSI x470 Gaming Plus
MSI Armour RX 570 8GB OC
Team Group TDGED416G3000HC16CDC01 2x8GB 3000Mhz C16
WD Black 500 GB NVMe
Rosewill Capstone 750
Cheap 240 AIO
Rosewill Rise
Operating System
Win 10 Pro
Keyboard
Microsoft Sidewinder x4
Mouse
Logitech G300s
Audio
Audio Technica M50xBT
5291Crash is offline
post #697 of 699 (permalink) Old 09-12-2018, 05:19 PM
To The Game
Chargeit's Avatar
Rep: 290 (Unique: 197)
Hey guys.
I received a Raspberry pi 3 B+ today. I opened it and it looked like something was splattered on it. I checked the rear of the pi and one of the solder's looks bad. Any idea what this could be? I'm guessing flux or a cold solder.
Chargeit is offline
post #698 of 699 (permalink) Old 09-12-2018, 10:53 PM
To The Game
Chargeit's Avatar
Well it's working. Pretty happy with the B+ so far. It feels more responsive then the old B model and uploading files to it over my network is noticeably quicker. Happy with the case also. Was worried that the fan was going to be loud but connecting it for its low speed setting it's inaudible.
Chargeit is offline
post #699 of 699 (permalink) Old 09-21-2018, 04:48 AM
battlenut's Avatar
Rep: 58 (Unique: 52)
Had it for a couple months now, Pi 3B+. interesting enough I just found out about SBC's in like may. Pretty interesting what you can do with them.
battlenut is offline
