[Build log] Lori Lemaris Returns, featuring Compact Splash #023 - Overclock.net - An Overclocking Community
post #1 of 291 (permalink) Old 12-05-2013, 10:44 AM - Thread Starter
8.2 liters
WiSK's Avatar
Rep: 553 (Unique: 361)
At the start of the 2013 I made a watercooled build in an FT03-mini. It's internally only 11 litres, so was a nice challenge to fit everything. Unfortunately it only has space for a single 120mm rad. Cooling CPU and GPU was possible, but I couldn't overclock very much. So I went looking for a new case that would be better at watercooling. Unfortunately, in the size I was looking for, there are no commercially available cases that have more than 240mm rad space. Then I discovered that She Loved E was teaming up with Dwood to fabricate the Mod of the Month winning case, Compact Splash. So I ordered one, and to cut a long story short, it arrived yesterday!
WiSK is offline
post #2 of 291 (permalink) Old 12-05-2013, 10:44 AM - Thread Starter
8.2 liters
WiSK's Avatar
WiSK is offline
post #3 of 291 (permalink) Old 12-05-2013, 10:44 AM - Thread Starter
8.2 liters
WiSK's Avatar
WiSK is offline
post #4 of 291 (permalink) Old 12-05-2013, 10:57 AM
Lutfij's Avatar
Location: Chittagong/Dhaka , Bangladesh + born in Dubai , U.A.E
Rep: 48 (Unique: 30)
Lutfij is offline
post #5 of 291 (permalink) Old 12-05-2013, 11:12 AM
ArbyWan's Avatar
Rep: 7 (Unique: 7)
Still sad I couldn't go through with ordering one of the Splash's sad-smiley-002.gif
ArbyWan is offline
post #6 of 291 (permalink) Old 12-05-2013, 11:58 AM
d0pp3lg4ng3r's Avatar
Rep: 3 (Unique: 3)
d0pp3lg4ng3r is offline
post #7 of 291 (permalink) Old 12-05-2013, 12:02 PM
I Am Gooble Gobble
PCSarge's Avatar
Rep: 252 (Unique: 229)
i wanted one of these cases...........so badly
Quote:Originally Posted by PCSarge https://www.overclock.net/img/forum/go_quote.gif
Like Some Dirty Pleb http://files.overclock.net/images/smilies/yessir.gif
Orange Angel
(23 items)
i5 7600K @ 5.0Ghz
ASUS Strix Z270I Gaming
Visiontek RX 480 [EK FC nickel/Acetal]
16GB G.Skill Trident Z RGB
Samsung 840 EVO 120GB
Crucial M300 1TB
Seagate Firecuda 2TB
Intel 525S 256GB M.2
Corsair RM850i
EK Supreme LTX CSQ [Canadian Special Edition]
MCP 35X 10W W/ EK CSQ X-TOP
EK Coolstream PE 240
Bitspower Multi Tank 80
Bitspower Matte Black Rotary Fittings/ Feser Matte Black Barbs
Corsair Air 240
Operating System
Windows 10 Professional 64-Bit
Samsung 32 Inch 4K TV
Acer S231H
Keyboard
NKPC V60 65% custom
Mouse
Razer Deathadder 2013
Mouse
Stelseries QCK+
Audio
Astro A40 TR+ Mixamp Pro
Other
AKRacing Arctica Gaming Chair
PCSarge is offline
post #8 of 291 (permalink) Old 12-05-2013, 02:33 PM
RggdLord's Avatar
Rep: 9 (Unique: 5)
RggdLord is offline
post #9 of 291 (permalink) Old 12-05-2013, 02:45 PM
Hefner's Avatar
Rep: 26 (Unique: 16)
Subbed! Cant wait to see some results thumb.gif . I received a tracking code for mine today biggrin.gif
Hefner is offline
post #10 of 291 (permalink) Old 12-05-2013, 06:00 PM - Thread Starter
8.2 liters
WiSK's Avatar
I was intending to use one AX240 rad and one EX120 rad. I had painted those already, but then EK released the new Coolstream PE rads. The advantage is that I could put the 90 rotaries directly into the ports, and that the PE120 fits on the front where the AX120 wouldn't.
With a torx screwdriver you can disassemble them for ease of painting. I've got some white Kobra graffiti paint which when sanded down carefully can give a nice shiny durable finish.
They come standard with little 16mm diameter extenders, but I don't want any shiny fittings in this build. The hole in the shroud is almost right for Monsoon rotaries which are 17mm diameter. I'd have to drill or file the hole a bit wider, I already scraped off some paint of the rotary trying to force it in tongue.gif
Although I've had 9 months to think about how I want this build, seeing things mounted is when I can finally make decisions. As you can see, although the rotaries do fit when using the extenders, it's going to look a lot better without.
Spot the FT03-mini...
I've put GTs in for the moment, so it looks a bit like Kyle's original build...
But I also have some eLoops that I can swap out of my folding rig. I will compare them later on.
I'll do some painting of the radiator shrouds in the weekend, but it's getting quite cold and my painting space is in the attic which is not very well insulated. (edit: I meant the paint will dry slowly in the cold, not that it's too cold for me)
WiSK is offline
