Cooler Master Elite M-ITX Case Owners Club - Page 2 - Overclock.net - An Overclocking Community
View Poll Results: Which Cooler Master Elite ITX Case do you own?
Elite 100 3 1.28%
Elite 110 58 24.79%
Elite 120 Advanced 34 14.53%
Elite 120 Advanced White 4 1.71%
Elite 130 135 57.69%
Multiple Choice Poll. Voters: 234. You may not vote on this poll
post #11 of 1023 (permalink) Old 12-20-2013, 10:28 AM - Thread Starter
HuwSharpe's Avatar
Rep: 28 (Unique: 23)
Originally Posted by rizmo (Click to show)
Originally Posted by rizmo View Post
You can buy the filters here:
http://www.demcifilter.com/c211/ELITE-130-MINI-ITX.aspx
Thanks for the link, i wasn't aware that accessory existed. From the thumbnail i actually thought you had given your case the distressed look =)
I notice you have all the fans as intakes, creating positive pressure, while this does mean maximum fresh air and dust are drawn into the case it also means there is no where for the hot air to go. Just a thought and personal opinion. I haven't tested the difference between positive and negative pressure with this case yet, though i have tried a 140mm fan on the hard drive tray as a side intake and found it only reduced the motherboard temperature by 1 degree while under load.
HuwSharpe is offline
post #12 of 1023 (permalink) Old 12-20-2013, 11:51 AM
Slade Surfer's Avatar
Rep: 1 (Unique: 1)
Here's a teaser pic of my Modified Cooler Master Elite 120. Still work in progress. will be water cooled.
Parts:
Elite 120
Swiftech Helix 140mm fan
Ek Coolstream Rad xtc-140
Asus Z77 deluxe itx motherboard
2 x Samsung SSD Drives
Silverstone 650w PSU
Will Post more pics once I get all my parts. My goal is to have the cleanest elite 120 build since I have windows all over.biggrin.gif
Shortening the Psu Cables and Sleeving it.
Image Hosted by ImageShack.us
Slade Surfer is offline
post #13 of 1023 (permalink) Old 12-20-2013, 10:20 PM - Thread Starter
HuwSharpe's Avatar
Originally Posted by Slade Surfer (Click to show)
I look forward to seeing that. I do wonder if Cooler Master will follow Bitfienix sales model for spares and after market products, such as replacement front panels and lids, or lids with windows. I also wonder if there are any plans for an Elite 130 in white.
post #14 of 1023 (permalink) Old 12-21-2013, 12:41 AM
808Murasame's Avatar
Rep: 0
Thanks for the invite! I too have a Cooler Master Elite 130 set up for HTPC and portable gaming!
Great tip for the replacement of the feet. I need to get that done. I also use Demciflex filters as well because we have a cat. I hated the front mesh filter so I took apart the front grill and replaced the mesh with the DemciFlex mesh and it's much nicer.
Next year I want to revamp my mobo, CPU and GPU to better stuff.
808Murasame is offline
post #15 of 1023 (permalink) Old 12-21-2013, 09:00 AM
rizmo's Avatar
Rep: 4 (Unique: 4)
Warning: Spoiler! (Click to show)
Parts:
Elite 120
That's lookin' pretty good man. Great job! But question: Where did you find instructions to shorten the PSU cables? I've been thinking about doing this to my own Corsair RM 650 instead of shelling out money for a short cable PSU kit.
01001000 01100101 01101100 01101100 01101111 00100000 01010111 01101111 01110010 01101100 01100100 00100001 00001101 00001010
rizmo is offline
post #16 of 1023 (permalink) Old 12-21-2013, 09:03 AM
rizmo's Avatar
Rep: 4 (Unique: 4)
That is an excellent question, I never thought about that. I just figured the only real place at this point, where the hot air can be exhausted is through the side of the case, not the video card side but the other side beside the CPU. Did you take internal case temperatures or component temperatures?
rizmo is offline
post #17 of 1023 (permalink) Old 12-21-2013, 01:40 PM - Thread Starter
HuwSharpe's Avatar
The only temperature experiments i have done with this case is with a 140mm fan, side mounted on the removable hard drive tray, which with my set up proved having a fan there was pointless, in either orientation. However, over the years i have had many cases from full ATX towers to the Shuttle XPC's and in my experience it has always been better to focus on extracting the internal hot air, rather than simply pumping more air in. With there been vests down either side there is an amply supply of air if needed to be drawn in, for both the graphics and the radiator at the front if installed.
Under full load, i have not seen my CPU exceed 39 degrees, which currently at stock speeds isn't bad, but i will be pushing for the 5 GHz again soon and may need to remove the SSD from the floor of the frame so as to install another fan to the radiator in addition to the one that is already there. This will likely be a 38mm deep super fan, which will need connecting to its own kill switch so that it is only turned on when the other fan is at full speed, because if it isn't then the power from the 38mm deep fan will in fact spin the other 25mm deep fan up and potentially send a current back down the 25mm deep fan cable, seen it happen. However, do not fan stack unless you know what you are doing!
And just a reminder;
Originally Posted by HuwSharpe View Post
NOTICE: Please refrain from posting large photos and use thumbnails instead and if quoting a post please use the spoiler feature. Thank you.
post #18 of 1023 (permalink) Old 12-24-2013, 03:31 AM - Thread Starter
HuwSharpe's Avatar
Originally Posted by max789 (Click to show)
Originally Posted by max789 View Post
Hi
Does anyone know whether a Silverstone FF123 fan can be attached to the front of the Elite 130's stock 120mm fan?
http://www.silverstonetek.com/product.php?pid=393
Thanks.
If i am correct in saying you mean the Silverstone fan filter, then yes i believe that will fit without issue.
post #19 of 1023 (permalink) Old 12-26-2013, 12:50 AM
max789's Avatar
Rep: 0
Thanks for your feedback. :DYes, I did mean the fan filter (not fan).
max789 is offline
post #20 of 1023 (permalink) Old 12-26-2013, 05:37 AM - Thread Starter
HuwSharpe's Avatar
Just an update on my fan stacking tests; i have just tried placing a SanAce 38mm deep, 120mm diameter fan in front of the existing Phanteks fan on the Corsair H80 as shown in the image below.
Now bare in mind the CPU is currently overclocked at 4.2GHz and under load the temperature drops from 38°C to 29°C (in under 6minutes!) when the SanAce fan is switched on. I suspect this will be improved upon if the SanAce fan was placed behind the Phanteks 120, in direct contact with the radiator and will test this at some point.
You might be thinking why use the Phanteks fan at all, well the SanAce fans i am using are industrial and have two speeds, stop and full power and at full power are far from quiet. For 24/7 use i want the system to be relativity quiet, but on the odd occasion when pushing the overclock and when leaving the system on doing mass video encoding i want the system to be kept as cool as possible. Having the fans stacked means i have the option for both and can simply turn on the SanAce fan when required. There is one draw back to using fan stacking for this purpose, as when the SanAce fan is not switched on, it in fact reduces airflow and causes temperatures to increase, however, only tests will show by how much.
Note fan stacking is typically not used for this reason and there is a lot of science behind fan stacking, if you are thinking of doing it read up on it first, you should not fan stack unless you are sure what you are doing. If i switch on the SanAce fan when the Phanteks is off or on a low speed the speed of the air from the SanAce will cause the Phanteks to spin, which could send a current back down the cable and for that reason never connect fan to the motherboard when fan stacking.
