Silverstone Raven RVZ01 / RVZ02 / ML07 / ML08 / FTZ01 Owners Club - Page 723 - Overclock.net - An Overclocking Community
post #7221 of 7228 (permalink) Old 07-11-2019, 06:54 AM
hobx's Avatar
Rep: 0
Turing and RVZ01
Hey folks, I recently upgraded my graphics card to a 2070 Super. I’ve later discovered that Turing has issues with riser cards. Anyone using an RTX model? How has it been? I have the original RVZ01
hobx is offline
post #7222 of 7228 (permalink) Old 07-18-2019, 09:56 AM
lowmotion's Avatar
Rep: 0
Issues with riser cards?
lowmotion is offline
post #7223 of 7228 (permalink) Old 07-27-2019, 06:24 PM
d g
Holden34772
d g's Avatar
Rep: 0
Hey guys,
firstly great forum, it was extremely helpful when building my ML-08B build and the creativity here is amazing.
have any of you had any luck replacing the GPU Riser cards? mine had a mishap during the last cleaning and silverstones response to how can i buy a replacement was we have no office in australia.
most of the cards i can find online are right angle connectors or cables.
while the gpu (rX480) still works , its very precise on its placement otherwise it wont initialize past the windows login.
any tips to the right direction would be very helpful.
d g is offline
post #7224 of 7228 (permalink) Old 07-27-2019, 06:45 PM
bidomo's Avatar
Rep: 0
I wanted to ask this to x570 owners, I have a Fatal1ty AB350 itx/ac, everything works perfectly with both riser cards
Quote: Originally Posted by d g View Post
Hey guys,
Sounds like you're gonna have to order from the US
bidomo is offline
post #7225 of 7228 (permalink) Old 08-29-2019, 11:41 PM
jeff1101's Avatar
Rep: 3 (Unique: 3)
Re:
You can order directly from Silverstone Taiwan. At least that's what I did when I melted the pins on my riser card. You can contact Laney Huang. Her email is [email protected].
I'm from the Philippines and Taiwan was a heck of a lot closer to my country than the US. Seeing as your from Australia, I think you would agree. It still took a month for it to arrive though as they had to wait for the item to get back in stock.
jeff1101 is offline
post #7226 of 7228 (permalink) Old 09-04-2019, 06:58 AM
orbitalwalsh's Avatar
Rep: 19 (Unique: 14)
Right , will post up some pictures and thread to messy build log but here's what happens when your wife changes the living room and your ATX case no longer fits in/inside the ikea hemnes desk cupboard..... You fit the ATX board in an ITX CASE!
Silverstone Tek thankfully heard my cries and mad plans and sent myself their RVZ03 case ( unfortunately black but was meant to be white), SX700-G as i had a huge 850w Bequiet Pro 11 coming in at 150x 190mm .
Aorus X470 Gaming 7 and RTX 2080 was sponsored a while ago from Gigabyte but might get a refresh .
^^^not a lot of space for either Silverstones slim 240mm CLC or XSPC 20mm XT range
Side panel will go plexi but will cut out a mesh grill for the GPU
orbitalwalsh is offline
post #7227 of 7228 (permalink) Old 09-04-2019, 07:00 AM
3x 92mm fans will sit at the bottom .
build log here
to solve the gap issue quickly. Modders mesh will fill the gap between front fascia and side panel with getting ahold of another top/bottom panel and trimming down and attaching to current to extend its length
will have to get onto 3d printing new ones
post #7228 of 7228 (permalink) Old 09-08-2019, 06:13 PM
Avid Memer
chessmyantidrug's Avatar
Rep: 229 (Unique: 171)
I ordered an FTZ01-E the other day. I'm finally moving on from my X58 system. Newegg had the i9-9900KF on sale for $419.99 and I decided to take the bait. I know rumors say prices may drop when the i9-9900KS comes out, but I won't be missing much performance wise. I should have all of the following Tuesday:
  • i9-9900KF
  • Scythe Big Shuriken 3
  • ASRock Z390 Phantom Gaming ITX
  • 2x8 GB Crucial Ballistix DDR4 3200
  • Samsung 970 EVO 500 GB
  • SilverStone FTZ01-E
  • SeaSonic FOCUS SGX 650W
I'm salvaging the GPU and SSDs from my current build and using a 2TB FireCuda to replace the 3TB P300. I'll eventually replace those SSDs with larger ones, maybe around Black Friday. I won the FireCuda from a streamer on Twitch a little over a year ago and finally have a reason to use it.
Are the stock fans included with the FTZ01-E adequate for my components? I've been looking to buy some NF-A12x25 PWM fans but they're out of stock everywhere in the US. I plan on running my CPU at the lowest voltage possible to minimize heat. It's going to take some tweaking, but that's half the fun of a new build. I might even look to fit water cooling into this build at some point.
El Diablo
(19 items)
Intel Xeon X5670
Asus Sabertooth x58
EVGA GTX 1070
Mushkin 6x2GB XP3-12800
Samsung 850 PRO
Samsung Spinpoint F1
Samsung 850 EVO
Toshiba P300
Optical Drive
Samsung SH-S203B
Corsair AX750
Thermalright Ultra 120 Extreme
Fractal Design Define R4
Operating System
Windows 10 Home 64-bit
BenQ RL2455HM
BenQ XL2420Z
Keyboard
Deck Legend - Fire
Mouse
Razer Lachesis
Mousepad
SteelSeries QcK Gaming Mouse Pad
Audio
Astro A50
chessmyantidrug is offline
