Silverstone Raven RVZ01 / RVZ02 / ML07 / ML08 / FTZ01 Owners Club - Page 724 - Overclock.net - An Overclocking Community
post #7231 of 7235 (permalink) Old 11-06-2019, 08:01 AM
mardon's Avatar
Rep: 44 (Unique: 40)
Hello all. Returning to this thread after a while! It's time for my trusty 3770k rig to receive a rather large upgrade. I'm going 8700k and a 2070 Super (16GB 3200RAM).
The i7 is already de-lidded and lapped and will be sitting under a H55 cooler, liquid metal TIM and i'm going to swap the fan out with a Noctua NF-A12x15 PWM, Premium Quiet Slim Fan. My question is.. it this combo of cooling still the best choice or are there better options out there? Has anyone hit 5ghz @ 1.3v without overheating?
Failing the above i'm tempted to build in a Phanteks evolv shift and a much beefier single fan AIO.
mardon is offline
post #7232 of 7235 (permalink) Old 11-08-2019, 04:02 AM
hobx's Avatar
Rep: 0
Hmm I was going to go with the Big Shruiken 3 for my 9700k. But you're tempting me with the H55 now. Looks like its difficult to fit in though?
hobx is offline
post #7233 of 7235 (permalink) Old 11-08-2019, 11:54 AM
mardon's Avatar
I've had one in my build since 2014. Once you get the orientation right it's fine.
Got a new addition a 120mm external USB powered fan for some push pull. I'll post pics one I put it all together tonight.
Sent from my SM-N9600 using Tapatalk
mardon is offline
post #7234 of 7235 (permalink) Old 11-11-2019, 03:57 AM
mardon's Avatar
Here's some updated pics of the build.
Not the neatest thing you'll ever see at the back but with how my PC fits on the floor it's hidden and sucks in lots of cold air.
8700k runs at 5ghz around 60C in games. high 80's in intel Burn test. That is delidded and lapped. Just swapped it out for a 9700k (for £30) so will report back how that does. Hopefully it needs less that 1.345v to high 5ghz like the 8700k did.
mardon is offline
post #7235 of 7235 (permalink) Old 12-03-2019, 03:32 AM
hobx's Avatar
Rep: 0
Went for the big Shuriken 3 in the end.
My question is about the case fan placement above the Shuriken. I didn't think I would have room but it turns out there is, albeit 1 or so MM. So should I put the case fan above it?
Venting or intake? If its intakeing its going to be blowing straight down on a fan that's venting? So seems to make more sense to vent?
Edit: Settled on having the 15mm in the case with an intake layout. Have to set the fan curve a little more aggressive that I would like as its noisy, but going up to 80% keeps the temperature at 70c maximum.
hobx is offline
