Silverstone Sugo SG13 Mini-ITX Owners Club - Page 298 - Overclock.net - An Overclocking Community
View Poll Results: Are you interested in this new Sugo SG13?
Yes 262 93.24%
No 19 6.76%
Voters: 281. You may not vote on this poll
post #2971 of 3061 (permalink) Old 09-10-2019, 09:27 PM
Rep: 12 (Unique: 10)
Quote: Originally Posted by azdesign View Post
there are no intake fan.
the exhaust will suck air from ventilation holes. I drilled more holes on the cover and attached magnetic dust filters.
Still not working out well with the cover on. I need to figure out what cause the temp spike. my guess is:
1. there a small <1cm gap between exhaust and holes on the cover (top-side), which means, hot air might not be exiting properly and some got circulated back into the case
2. there might not enough holes for the intake
1. Buy some of that adhesive backed foam strip used to seal doors and windows and seal the gap. A bit like in the image below.
2. You probably need more ventilation on the side of the lid opposite the graphics card. There is only a small ventilated area at the rear of that side. This is intentional as if you are using a front intake fan most of the intake air would escape again out that side without cooling anything. In your configuration as much inlet area as possible on that side would be beneficial.
Interesting build by the way.
clannagh is offline
post #2972 of 3061 (permalink) Old 09-11-2019, 06:11 AM
azdesign's Avatar
Rep: 9 (Unique: 6)
thanks for the advice
for now i'm going to put some stacked foam double tape until it isolates well.
i will go look for door/windows sealer on weekend
here is some temp result after doing an hour of gaming with ambient temp of 30 degree C
1. cover off
cpu: 74 degree C
gpu: 84 degree C
2. cover on
cpu: 81 degree C
gpu: 86 degree C
3. cover on with isolation
cpu: 79 degree C
gpu: 85 degree C
Thanks again, it really is an improvement with the isolation.
azdesign is offline
post #2973 of 3061 (permalink) Old 09-12-2019, 08:19 AM
qhash's Avatar
Rep: 2 (Unique: 2)
I sold my SG13 build with a strider 500w SFX-L couple of months ago, but as far as I can rememer, my build was extremly quiet (people complained a lot about some rattling issues with this particular silverstone psu). I am building a new mini PC and I need to choose PSU, a quiet PSU ... I have read a lot about SF450 Platinuim having ~22 Decibels on average. Have anyone used this PSU in SUGO? I am asking as I wonder if that build is going to end again with SG13
qhash is offline
post #2974 of 3061 (permalink) Old 09-12-2019, 07:42 PM
I have the gold and it is fairly quiet.
Toms reviewed the Platinum and liked it:
https://www.tomshardware.com/reviews...u,5917-11.html
clannagh is offline
post #2975 of 3061 (permalink) Old 09-12-2019, 11:41 PM
qhash's Avatar
Rep: 2 (Unique: 2)
yeah, the average noise number I took from there. The problem is I somewhat can't believe/accept the fact that a 92mm FAN can be more quiet than any good 120mm fan. I might be wrong as my experience isn't great. I always went for as big fans as possible. Also "feeling" of how loud something works is often subjective. There is lots of information on the forums people stating that these Corsairs are all but not quiet.
qhash is offline
post #2976 of 3061 (permalink) Old 10-10-2019, 06:36 AM
Rep: 0
AHTOH
Hello to all! I want to build my first SFF system. Decide on the body and the question arose. According to the specifications on the Silverstone SG13 website, it will only support the installation of a dual-slot video card. However, if you check compatibility on the pcpartpicker website (https://pcpartpicker.com/products/vi...h=dM8H99#c=447), you can see that SG13 supports the installation of ASUS 2070 super dual, which has a 2.7-slot video card. The question to you, owners, is it possible to install a similar video card in this case without its modifications?
PS. Sorry for my English )
AHTOH is offline
post #2977 of 3061 (permalink) Old 10-13-2019, 03:29 PM
Generally the quoted absolute hard "maximums" for oversized cards in these cases are 53mm wide (3 slots would be 61 mm) by 280mm long (requires trimming away plastic from the case front) by 129mm high.
That said you can never be sure until you actually try it. Among other things the position of the PCIe power connectors can be an issue even if a particular card fits physically.
clannagh is offline
post #2978 of 3061 (permalink) Old 12-20-2019, 09:36 PM
Rep: 0
Airflow and thermals in sg13 with reference 5700 XT
Howdy,
I just picked up a reference xt for way cheap for my build but had been planning on using the SG13 from start.
https://pcpartpicker.com/list/vTX8Qq
I was planning on placing the AIO in the front mesh and as an intake, flipping the PSU above the CPU as a 135mm exhaust so I get that nice airflow over the mobo (I suppose this would make the vent on the right side an inactive intake?)
I think that'll be solid for the cpu and vram temp, but I have concerns for the 5700 xt reference. Heard it runs HOT and blowers aren't the best, but I couldn't pass up the $297 price.
Any suggestions?
Griffball is offline
post #2979 of 3061 (permalink) Old 01-06-2020, 09:10 PM
Quote: Originally Posted by Griffball View Post
Howdy,
Any suggestions?
A blower GPU will be isolated from the rest of the sg13 airflow so the 5700 xt should pretty much run the way it would in any other case. The card is long with power connectors on top so double check it fits.
I am unclear what you mean by "placing the AIO in the front mesh" .
clannagh is offline
post #2980 of 3061 (permalink) Old 01-16-2020, 01:53 PM
Rep: 0
Ok, so I can officially confirm that overclocking with this case is possible and it does not require any liquid cooling whatsoever. My setup:
Gigabyte Z270-Gaming5
GTX1080 with blower type cooler (blows air out)
Arctic cooling PWM fan in front 12x25 (sucks air in)
Corsair SFX 600W gold PSU (blows air out)
i5 7600k with big shuriken 3 heatsink along with noctua a12x25 PWM fan (blows air out)
2x8 GB DDR4 RAM with OEM corsair heatsinks
Samsung 960 evo m2 nvme
Performed stress tests, none of the components went up more than 65 degrees celsius with a maximum overlock that mobo allows (1 profile for RAM and 4.6ghz for CPU).
Took me 2 years to finalize the build and find the best solution for airflow. If anyone knows any better options, please share.
Btw case is with the mesh in front and yes it is quite noisy, but since I always use headphones I don't really care. It is also worth to mention that the case sits in a small compartment within my desk, so the airflow around it is not perfect, but I am impressed with the temps. Also, there are no clearance issues or requirements to cut and so on.
gatovas is offline
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
