[Official] Thermaltake Core V1 Owners' Club - Page 202 - Overclock.net - An Overclocking Community
post #2011 of 2021 (permalink) Old 07-10-2019, 06:51 PM
Rep: 0
Any way to fit the window on top or was it just scratching the panel?
OVOBravo is offline
post #2012 of 2021 (permalink) Old 07-11-2019, 05:30 AM
nisc's Avatar
Rep: 0
I found an old picture.
https://ibb.co/n61kQLV
Its fits. Probably touches the panel, but doent push it.
nisc is offline
post #2013 of 2021 (permalink) Old 07-21-2019, 07:09 PM
Rep: 0
I'm back baby! Time for another Thermaltake V1 build!
At one point I moved onto an ATX build and honestly I just can't stand the size. I always missed my Thermaltake V1 PC. Now I'm building my Ryzen build. It's not finished because UPS decided to ship my Ryzen CPU from Newegg to a different town so now I have to wait another week. Until then I wanted to show you guys something unique and as far as the internet goes I think I'm the first.
I'm putting a Morpheus II into my Thermaltake V1 ITX case. I searched deep but could not find anyone attempting such a crazy thing. As you can see in the photos attached it's almost a flush fit. I had to cut a piece of the beam to put it in but once the covers are on you won't even see it. The plan is to cut out the side panel too to make room for the heatsinks, then mount 2x 120x15mm fans as exhaust right to the cover itself. On the inside it will have anti-vibration material to stop any noise. I decided on this design because I'm not a fan of dust and having the fans exhaust should do the trick. Inside the 200mm fan will keep it all cool. If anyone has noticed I also have large thin heatsinks on the back panel of my Vega card. Under the backplate of my Vega I have thermal pads on the hotspots. It works great, the heatsinks actually get quite hot so you know the heat disputation works. The best part is when it's time to upgrade I will most likely pick up a 5700XT card or newer and the Morpheus II is compatible.
I hope you guys enjoy, I will post my final result once it's all done.
vulcan4d is offline
post #2014 of 2021 (permalink) Old 07-26-2019, 11:38 AM
French loving Japan!
nolive721's Avatar
Rep: 6 (Unique: 6)
did somebody here go crazy enough to install an Hybrid GPU with a 120mm Rad AIO and keep the front 200mm. how did you do that if so? I have seen pics of people fitting such Hybrid GPU but they removed the front stock fan and I dont want to do so.
thanks
PC GAMING AEROCOOL P7 C1 WHITE VERSION CPU RYZEN 5 [email protected] 4Ghz/1.45V CPU cooler ID COOLING FROSTFLOW+ SNOW EDITION MB ASROCK B350 PRO4 GPU EVGA 1080TI FTW3 HYBRID 2088Mhz core RAM CORSAIR LPX 16Gb @ 3066Mhz WINDOWS 10 PRO NVME PATRIOT BOOT DRIVE
nolive721 is offline
post #2015 of 2021 (permalink) Old 07-26-2019, 11:50 AM
nisc's Avatar
Rep: 0
thanks
-> 200mm | radiator | 120mm ->
nisc is offline
post #2016 of 2021 (permalink) Old 07-26-2019, 12:01 PM
nolive721's Avatar
Rep: 6 (Unique: 6)
you mean keeping the 200mm fan and attach the 120mm Rad ahead? gonna blow some very hot air to my CPU tower cooler, not sure its a good idea?
post #2017 of 2021 (permalink) Old 07-29-2019, 12:58 PM
nisc's Avatar
Rep: 0
What are the max gpu width and height?
nisc is offline
post #2018 of 2021 (permalink) Old 08-04-2019, 05:33 PM
Abides
ricercar's Avatar
Rep: 9 (Unique: 9)
Hi Vulcan. What about structural integrity? Is there any collapsing at that corner of the case?
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.”
― Robert M. Pirsig, Zen And The Art Of Motorcycle Maintenance
ricercar is offline
post #2019 of 2021 (permalink) Old 08-07-2019, 10:03 AM
Rep: 0
thanks
I think it would be tough to manage CPU cooling. I have a 120mm aio cooling my CPU and kept the 200 mm fan. My air cooled GPU does fine with its onboard fans pulling air in and 2 80mm exhaust fans at the rear pulling hot air out, but I think if you tried to sandwich some kind of air CPU cooler in there behind the radiator it wouldn't do well. The GPU gets cool air from the side vented panel, but a CPU cooler couldn't do that.
Angela Sessions is offline
post #2020 of 2021 (permalink) Old 08-21-2019, 10:18 AM
nolive721's Avatar
Rep: 6 (Unique: 6)
decided to go for it crazy me lol)
my 1080Ti combined with a 4670k I got yesterday for $60 will serve me as 4k gaming in the living room
my FTW3 Hybrid will be tough to fit in so I might make use of my dremel to make some room in the front frame of the case being for squeezing the card in or plug in the 2 8pin connectors but I think I have a good Plan. the radiator will be fixed on the side panel where HDD normally sits as an Exhaust.
the Rad will be ahead of the CPU tower cooler so it should get some fresh air from the 200mm fan that I will leave in its stock position so the overall temps of the CPU and GPU should be fine, hopefully
will share some pics over the week-end to further clarify my intentions but might be seeking final advice before cutting in the steel
