LIAN LI PC TU100 / 200 owners club - Page 160 - Overclock.net - An Overclocking Community
post #1591 of 1612 (permalink) Old 12-23-2019, 09:39 AM
Rep: 1 (Unique: 1)
Picked up the Nano on a recommendation of a friend. Seller had a bunch for $99 each. I like this one so much I ordered another one. *sold out now*
Name:	Screen Shot 2019-12-23 at 9.37.19 AM.png
greengoose is offline
post #1592 of 1612 (permalink) Old 12-26-2019, 06:27 AM
Typo Elemental
Simmons572's Avatar
Gotta be careful with those. My nano was used for coin mining at some point, which lead to its inevitable demise. If it is a mining GPU, just be aware that you are using a GPU with a shorter lifespan.
AMD Threadripper 1900x
Asus Prime X399-A
EVGA 1080 Classified
Samsung 960 Evo
Intel 750 Series 400GB U.2
Samsung 850 Pro 512 GB
Seasonic 1050w 80+ Gold
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Asus Z170i Pro Gaming
Sapphire R9 Nano
Kingston FURY 16GB (2 x 8GB) DDR4-2400
Samsung 950 Pro 512 GB
Athena AP-MFATX40 400W Flex-ATX
be quiet! ​PURE ROCK ​SLIM
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
MK Disco RGB TKL (KBT Brown)
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Beyerdynam​ic DT 770 ​Pro 80 ohm
Audio
Antlion Audio ModMic 4 w/ Mute
Audio
Schiit Fulla 2
Other
Noctua NF-A9x14 (x2)
Other
Fractal Design FD-FAN-SSR2-92
Other
Fractal Design FD-FAN-SSR2-60 (x2)
Other
Fractal Design GP12-WT
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Kingston - FURY 8GB (2 x 4GB) DDR4-2400
ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2400
SanDisk - SSD PLUS 240GB
Kingston - SSDNow V200
Corsair HX850i
be quiet! - PURE ROCK
Thermaltake Core V21
Operating System
Windows 10 Pro
Simmons572 is offline
post #1593 of 1612 (permalink) Old 12-29-2019, 03:59 AM
Rep: 1 (Unique: 1)
I assumed it IS a mining card, however it does work quite well, and perfect for a kids LAN PC.
post #1594 of 1612 (permalink) Old 12-30-2019, 09:27 AM
Rep: 0
First post here. I was recently tasked with building two small, portable, and powerful PCs for work. These computers will be used for stitching together UAV drone footage into large orthomosaic maps. This workload is very multi-thread friendly, with very little graphics card involvement. When I found the TU100, I knew that was the case we wanted to haul around in the field. The first build I completed in 3 days with help from Amazon Prime and some parts I already had lying around. It uses a Ryzen 7 3700X on an Asus ROG Strix B450-i, cooled by a Noctua NH-L9a, running 32 GB of RAM. The video card is an old Radeon HD 7750, all powered by a Silverstone 500W SFX power supply.
After I got that in the field (with no time for taking pictures), they asked me to spend some more time and build a real hot rod. I got a lot of inspiration from builds I found on PCPartPicker, especially Simmons572's build. (Thanks!) This is the first modding project I've ever attempted, and I'm trying to keep a Ryzen 9 3900X (12 cores, 105 watts) cool under a heavy load in this lunchbox. I removed the stock 120mm fan, dremeled out that mounting plate, drilled more vent holes, and stuffed in a Noctua NF-A14. Then I drilled vent holes in the bottom and mounted an NF-A12x15. To lift the case a little for improved ventilation, I designed and 3d-printed 4 new feet, 1/2" cylinders that are 1/2" high. (Feel free to download them here: https://www.thingiverse.com/thing:4070466).
I'm going to be using a 400 watt Flex ATX power supply, Noctua NH-U9S cooler, and RX 560 video card on a ROG Strix X570-i motherboard. I've got to get back to work, but I'll post more later.
CodeNaked is offline
post #1595 of 1612 (permalink) Old 12-30-2019, 12:05 PM
Typo Elemental
Simmons572's Avatar
Looking good mate! I like that pattern you used for the vent mod.
Asus Prime X399-A
Samsung 960 Evo
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Sapphire R9 Nano
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Audio
Audio
Schiit Fulla 2
Other
Other
Other
Other
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Corsair HX850i
Operating System
Windows 10 Pro
post #1596 of 1612 (permalink) Old 12-31-2019, 12:58 PM
Rep: 0
It looks like my first message got lost in the ether, so I'll try again with a shorter one, without pictures.
I put together a pretty simple little TU100b build about a month ago with a Ryzen 7 3700X, 32 GB RAM, a 512 GB NVMe drive, and an old Radeon HD 7750 video card. This was a project for my work, where we needed a field computer to run software that stitches together UAV (drone) footage into an orthomosaic map.
After I delivered that box, they asked if I could make another one, but even more powerful. So right now I'm working on one with a Ryzen 9 3900X. I was very much inspired by Simmons572's build. I should take delivery of my final part, a custom Enhance 400 watt Flex ATX power supply from Geeek Store, later this week. Pictures will follow.
post #1597 of 1612 (permalink) Old 12-31-2019, 02:37 PM
Rep: 0
Here are my airflow modifications. I used an old cheap PC case panel lying around for the template to drill out the bottom ventilation holes. There I mounted a Noctua A12x15 PWM, configured as intake. I designed and 3D printed some simple feet that lift the case 1/2".
I cut out the front mounting panel inside the case, drilled out a few more ventilation holes, and mounted a Noctua A14 PWM for a little more intake than the stock configuration.
Lastly, I copied the case's hole pattern to a piece of 1/8" aluminum and transferred it to the top, between the handle mounts, for a Noctua A8 PWM exhaust fan.
post #1598 of 1612 (permalink) Old 01-01-2020, 11:35 AM
Rep: 0
thank you everyone
I have been lurking here for a while for ideas, now that my build is done I thought i would share my build with pics.
Mike_Honcho is offline
post #1599 of 1612 (permalink) Old 01-05-2020, 05:37 AM
Rep: 1 (Unique: 1)
Love that top fan.
post #1600 of 1612 (permalink) Old 01-08-2020, 07:38 AM
Typo Elemental
Simmons572's Avatar
Love what you did with the custom grilles. Great work
Asus Prime X399-A
Samsung 960 Evo
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Sapphire R9 Nano
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Audio
Audio
Schiit Fulla 2
Other
Other
Other
Other
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Corsair HX850i
Operating System
Windows 10 Pro
