Alienware Alpha Owners Club! - Page 150 - Overclock.net - An Overclocking Community
post #1491 of 2169 (permalink) Old 03-03-2016, 08:23 PM
Prince of all Saiyans
Blindrage606's Avatar
Rep: 318 (Unique: 281)
Edit: Shout out to sargentsmite as I reached out to him for a bit of collaboration. Credit for the modifications of each BIOS is given independently. Thanks.
Blindrage vBIOS does:
Locks default core clock 1300 Mhz from the stock 1097Mhz value.
Adjust power for 48w.
Adjust boost tables to match 1300 - 1400Mhz core clock.
Boost State MAX values matches the 1300 -1400Mhz core clock.
Locks memory clock at default 2800Mhz from the stock 1505Mhz value.
**New default core clock values are equivalent to a +200Mhz in MSI Afterburner (which means with the additional 135Mhz+ available via MSI Afterburner this BIOS pushes the new optional potential core clock to an equivalent of +335Mhz or 1435Mhz)
**New default memory values are equivalent to a +300Mhz via MSI Afterburner
After modding the vBIOS via:
Kepler Tweaker
nVflash x64
Verified clocks via:
MSI Afterburner
GPUz -- Used this to make a stock copy of the vBIOS.
vBIOS Tabs:
Common:
TDP Base clock: 1400Mhz
Boost Clock: 1400Mhz
Memory Clock: 2800
Power Table (48w) :
Def (mW): 48000
Boost Table: adjusted (right click table to change values)
1400 Mhz
Boost States (P00, P05, P08):
P00 Profile:
GPC: 1400Mhz MAX
XBAR: 1400Mhz MAX
L2C: 1400Mhz MAX
P05 Profile:
GPC: 1400Mhz MAX
XBAR: 1400Mhz MAX
L2C: 1400Mhz MAX
P08 Profile: N/A
Clock States: N/A
Current Alpha Specs:
i7 4785T 35w (3.2Ghz, HT)
16GB Kingston HyperX Impact 1.35v
nVidia 860m
512GB EVO SSD
IC7Diamond Thermal on both CPU/GPU
Coolermaster laptop cooling pad (forces cooler air into bottom induction vents)
MSI Afterburner: +135Mhz
Load GPU Temp: 82C
Min GPU Temp: 52C
FIRESTRIKE SCORE: 4637
AlphaR1BlindRage.zip 259k .zip file
NVFlash_Certs_Bypassed_v5.265_x64.zip 1091k .zip file
NVflash Guide that will work with the Alpha
Blindrage606 is offline
post #1492 of 2169 (permalink) Old 03-03-2016, 08:40 PM
sargentsmite's Avatar
Rep: 3 (Unique: 3)
Awesome! The i7 does gain some points over the i3, I cant wait to swap CPUs.
Best Firestrike on the stock i3 is 4382
http://www.3dmark.com/fs/7771347
I will further tweak the vbios and repost once the E3 Xeon and dual 40mm liquid cooler are installed.
sargentsmite is offline
post #1493 of 2169 (permalink) Old 03-03-2016, 09:23 PM
Originally Posted by sargentsmite View Post
Glad the vbios worked. The i7 does gain some points over the i3, I cant wait to swap CPUs.
Oh, just to confirm the i7 4785T gave a PhysX score of: 7926
New FIREMARK after blindrage vBIOS: +135 core/+200 mem = 4753
post #1494 of 2169 (permalink) Old 03-04-2016, 08:03 AM
beingben's Avatar
Rep: 0
The higher wattage power bricks do make a difference.
I am using the Dell GA240PE1-00
My alpha is apart for the xeon e3 cpu upgrade and getting an ssd.
Also I have purchased a corsair mini itx cooler intended for the bulldog, to mod for the Alpha.
I have not seen anyone with a firestrike score ahead of my Alpha so far. I expect even better once the xeon cpu and mini cooler are installed.
http://www.3dmark.com/fs/7313650
The i3 is limiting the score with weak physics, the E3 xeon pulls 11k physics.
Here is my revision 4 vbios - use at your own risk. I was unstable until using a 240 watt power adaptter.
860m_mod4.zip 130k .zip file
Mind uploading pictures, I'm intrigued on how it looks with the mini itx cooler. I'm debating on trying to mod a eGPU setup into this system...any suggestions?
beingben is offline
post #1495 of 2169 (permalink) Old 03-04-2016, 08:30 AM
Mikestate1's Avatar
Rep: 0
Ok, so if it (larger power brick) makes a difference for you and not for me then there are obviously variances in the alphas. My point is that people shouldn't go into it thinking for sure that a power brick is the solution.
I've added a different blower fan and thermal pastes with the case cover off also with no change.
Obviously if you change the vbios your going to get different results. Is this something most people know how to do though? No.
Mikestate1 is offline
post #1496 of 2169 (permalink) Old 03-04-2016, 09:37 AM
The TDP/voltage reg is done by the machine internally despite the external power adapter. Similar to alienware's laptops, where many of them have limited cutoffs for the PSU ... on exception of those with faulty the AW15/17 laptop BIOS where it would be throttled without the 240w PSU.
SO, this means that the performance of the alienware alpha is not limited by the external power brick wattage, but rather the TDP constraints put in place by the internal system BIOS (not vBIOS). A larger/more powerful external brick will not make a difference since we're limited by the small power delta of ~40-50w.
TL;DR: A higher wattage power brick DOES NOT increase performance! The alpha must remain in a small TDP envelope, this is done by the system BIOS lock and purchasing a $100 powerbrick does nothing.
post #1497 of 2169 (permalink) Old 03-04-2016, 10:56 AM
Rektifying's Avatar
Rep: 4 (Unique: 4)
Nice! I always wondered if the Alpha would take more power if it was available to it.
If it's not broke, fix it until it is!
Rektifying is offline
post #1498 of 2169 (permalink) Old 03-04-2016, 01:51 PM
Mikestate1's Avatar
Rep: 0
Very well said! Like I said before, to many people in this thread don't know what their talking about when it comes to performance enhancements. I bought several different power bricks only to be disappointed.
I emplore people that take the advice of the "experts" on this tread to think twice. The alpha is what it is.
post #1499 of 2169 (permalink) Old 03-04-2016, 06:22 PM
iRUSH's Avatar
Rep: 214 (Unique: 154)
Such a great looking tiny machine! Imagine what performance is packaged in this size in 3-5 years from now.
I was on the fence about the Alpha ever since Dell had their $100 off. I ended up with a ROG G20 instead. Someday I'll have one of these too. I just need to wait a few more years smile.gif
How's every liking theirs?
I have used nearly every CPU from Sandy Bridge on and Phenom II on. I have also used most GPU's from 2011 on, from low, mid and high. I've built 100's of rigs over the years. Most for fun and some for side work. If you have any questions and want an unbiased opinion, please feel free to PM me.
iRUSH is offline
post #1500 of 2169 (permalink) Old 03-05-2016, 01:12 AM
Rep: 3 (Unique: 3)
I have a M6600 with the 2920xm/2gb firepro - I used the 240watt power brick from it.
After more poking and prodding the same results are indeed stable with the stock adapter. Blindrage606 is correct.
I will revisit this once the different TDP processor is installed, possibly an 80 watt CPU may cause more current to be drawn, if not then at least I tried, hehe.
I will include images once the cooling mod is in place as well. The stock fans dont really ramp up until 80c.
