Alienware Alpha Owners Club! - Page 217 - Overclock.net - An Overclocking Community
post #2161 of 2168 (permalink) Old 03-29-2018, 01:20 PM
spoonablehippo's Avatar
Rep: 3 (Unique: 3)
Quote: Originally Posted by THEROTHERHAMKID View Post
Yes probably I did ask a couple on eBay
Not getting one now I’ve had a r1 before
It was just for the bedroom I have 1080 ti build in the room
Also, I recognise your username!
Didn't I buy an R1 off you? The one with no CPU!
spoonablehippo is offline
post #2162 of 2168 (permalink) Old 04-02-2018, 12:27 PM
THEROTHERHAMKID's Avatar
Rep: 3 (Unique: 3)
I did sell a r1 with cpu
So yes that will be me mate
THEROTHERHAMKID is offline
post #2163 of 2168 (permalink) Old 04-28-2018, 08:09 AM
CelticGamer's Avatar
Rep: 2 (Unique: 2)
Hi guys, I need some advice. I have the 1st Alienware Alpha with an i7 4785T. I have upgraded the RAM to 16gb of G.Skill Ripjaws , and also have a 7200RPM hard drive installed. I have been running an OC of 135 on the core and 550 on the memory for a long time and it's been completely stable. Temps never go above 82 degrees.
I am considering buying a decent laptop cooler to see if I can bring the temps down a little. What is everyone's opinion on using a laptop cooler for the Alpha?
Other than that, Is there anything at all that I can do to get anymore performance out of this thing? Any tweaks I can do to the processor or RAM? Anything?
Main Gaming Rig
(9 items)
Alienware Alpha R1
(5 items)
Ryzen 2700X
MSI X470 Gaming Pro Carbon
ROG STRIX RTX 2080
16GB ADATA XPG Z1 DDR4 3000mhz @ 3466mhz
WD BLUE 1TB
Thermaltake Grand Toughpower RGB 750W GOLD
Corsair H60
Corsair 570X RGB
Operating System
Windows 10
Intel i7 4785T
Nvidia 860M 2GB+BlindRageVbios+335Core+650Memory
16GB G.Skill Ripjaws
1TB 7200RPM
Operating System
Windows 10
CelticGamer is offline
post #2164 of 2168 (permalink) Old 05-26-2018, 11:33 PM
Linux Lobbyist
Rep: 0
Alienware Alpha streaming PC?
i recently picked up an Alienware Alpha R1 with the i5-4590t and these boogers decent powerful pcs but im wondering how i would use the Elgato hd 60 pro with it im aware of the cables and stuff but let me hear some ideas guys . Im stoked to make this happen
DanTheMAnrockz is offline
post #2165 of 2168 (permalink) Old 06-14-2018, 08:38 AM
Rep: 0
Alienware Alpha R1 i7. Great machine.
Any solution for 2 blinking yellow lights followed by 3, pattern repeat?
MeetTheFokkers is offline
post #2166 of 2168 (permalink) Old 11-24-2018, 05:52 AM
loosegroove's Avatar
Rep: 0
I’m hoping for some guidance. I have had an a i7 r2 alpha for about a year now and I have decided to water cool it. I modified the original case to get better airflow (pics attached) which worked out very well but after recently doing another loop I would like to do something with the alpha. I am gonna but it in a new case, a cooler master q300l. I am also adding a full sized gpu which will also be in the loop. I have planned out most of the mods and fabrication to get everything to fit. What I am in sure about are the cpu and integrated gpu blocks. Has any one else attempted water cooling an alpha? If so, what blocks should fit the mb? Also, will the integrated gpu be on or produce any heat while using an external gpu? I appreciate any help.
loosegroove is offline
post #2167 of 2168 (permalink) Old 04-02-2019, 02:40 PM
Rep: 0
What do you think, rather than buy a egpu kit (GPU, adapter, psu), I migrate the CPU, SSD, ram from Alpha R1 to a New Motherboard, plus a GPU And cooler? In long term, wouldn't It more cost effective than buying an egpu kit? As long as you could buy a lga 1150 Motherboard 32 GB ram instead 16 gb And put a stronger 4gen CPU with more tdp, for example?
juniorpaz87 is offline
post #2168 of 2168 (permalink) Old 08-27-2019, 07:30 PM
nexxusty's Avatar
Rep: 23 (Unique: 22)
Definitely late to the party. However as HTPC's, these are still amazing.
Getting one tomorrow, have an SSD, 16GB RAM and an i7-4770 for it.
Questions, I don't see anyone else running i7-4770's or 4770k's. Granted the K series SKU would be useless but the 4770 should be ok no?
It will be delidded and liquid metal pasted before I put it in. Thermals will not be an issue.
Are these CPU's even supported because of their TDP? I hope so, I'll be doing some microcode modding if that happens to be the case.
Other question is RAM. These older DDR3 systems heavily benefit from much more stable frametimes in games wjth 2133mhz RAM.
If I splurged for some quality sticks, will the BIOS/UEFI allow this? Would XTU allow it if not?
Appreciate anyone reading and responding to this.
Cheers!
nexxusty is offline
