Corsair Carbide Air 240 Owner's Club - Page 390 - Overclock.net - An Overclocking Community
post #3891 of 3897 (permalink) Old 05-09-2019, 07:31 PM
Rep: 0
New Here! New to Custom CPU Building! New to Air 240
Hi Everyone,
Sorry to wake this thread up.
I am new to custom CPU building and am looking at building a Air 240.
And would like to seek advise from everyone here
My potential hardware are:
Corsair Vengeance RGB PRO LED 2666MHZ 16gbx2
MSI Z390M Gaming Edge AC
MSI RTX 2060 6gb Gaming Z
Seasonic FP FX-750W Full Gold
Seagate 2TB 7200RPM
1 TB Samsung 860 QVO
1 TB Samsung 860 EVO
Planning to keep to stock fans first, but might get some noctua to replace them.
  • I do not plan to do any overclocking. - Will I still need to liquid cool my mobo?
  • Can someone advise me whether the GPU will fit in the case? No plans for any liquid cooling yet unless someone recommend it in 1st point.
  • I would like to put fans at the bottom, below the GPU. Will that be possible? Read somewhere that the space left is too little for 120mm fans.
Thanks in advance!
kyle326 is offline
post #3892 of 3897 (permalink) Old 05-10-2019, 07:51 AM
Rep: 37 (Unique: 35)
Hi
The MSI RTX 2060 6gb Gaming Z most probably doesnt fit this case. The card is way too high. Or if it barely fits, you cant connect the power.
And what do you call bottom?
LocutusH is offline
post #3893 of 3897 (permalink) Old 05-10-2019, 10:18 AM
Rep: 0
Quote: Originally Posted by LocutusH View Post
Hi
Thanks for the heads-up. I totally didn't consider that factor.. I will maybe consider the GeForce RTX 2060 Gaming OC 6G then, since its way lower.
In terms of "bottom", i was referring to the space that is below the GPU where it seems to be able to put 2 120mm fans too.
kyle326 is offline
post #3894 of 3897 (permalink) Old 05-10-2019, 11:49 AM
davidm71's Avatar
Rep: 22 (Unique: 18)
Quote: Originally Posted by kyle326 View Post
Hi Everyone,
And would like to seek advise from everyone here [IMG class=inlineimg]/forum/images/smilies/smile.gif[/IMG]
Seagate 2TB 7200RPM
Thanks in advance!
You can do what I did and use a riser cable and mount the Card vertically. I bought the 120mm fan gpu mount from MNCPTECH and mount the MSI Gaming X 1060 vertically in the anterior of the case. Looks cool and original. Try it maybe.
Save with EVGA. Associate code: K8XL098LGS5O4WZ
Z390 Master
(8 items)
9900K
Gigabyte Z390 Master
EVGA 1080 FTW2 SLI
Gskill F4-3600C15D-16GTZ
Samsung 970 PRO
Corsair HX1200i
Custom water loop
Operating System
Windows 10 64
davidm71 is offline
post #3895 of 3897 (permalink) Old 05-10-2019, 11:52 AM
davidm71's Avatar
Heres a photo
Z390 Master
(8 items)
9900K
EVGA 1080 FTW2 SLI
Samsung 970 PRO
Corsair HX1200i
Custom water loop
Operating System
Windows 10 64
davidm71 is offline
post #3896 of 3897 (permalink) Old 06-06-2019, 10:16 AM
Neomuffins's Avatar
Rep: 2 (Unique: 2)
Heres a mod I haven't seen anyone else do. I recessed the front fan mounts to put more room between my radiator and gpu. I plan on adding an acrylic fan grill to the radiator fans, I want as much room to view it as possible, but I also didn't want to buy a stealth profile radiator when I already have this perfectly good one right here. *shrug*
I cut the fan grill out, bent a scrap piece of sheet steel that came from a fan mod I did on the hdd cage, and made brackets for the radiator. The brackets were cleaned up, then riveted to the front of the case (no pics of that yet, sorry).
The result is more than a centimeter of extra space between fans and gpu, and the front panel still clips on/off exactly like a stock case.
This wasn't an easy mod, and I certainly don't recommend it to others. But for my specific build and situation the results were fantastic. This was the last major case mod I had to do, now I get to start making my vanity plates and grills out of acrylic. I need to get that done pronto, because I want to get everything painted while the weather is warm.
Neomuffins is offline
post #3897 of 3897 (permalink) Old 06-19-2019, 04:13 PM
deraco96's Avatar
Rep: 4 (Unique: 4)
Hi y'all, don't know if this thread is alive much anymore, but here we go.
I'm thinking of building a mostly new system, with the new Ryzens coming up in a couple of weeks. I'm already pretty sure about the motherboard, CPU and RAM, but I want to re-use my current Sapphire RX 580 Nitro 8G.
I found two Air 240s second hand, and was intrigued with the air flow it seems to able to provide with enough fans, and I like how it's not that big, really. A bit wider than my TJ08-E but lower as well.
Has anybody tried to fit the Sapphire RX 580 Nitro? It seems to be exactly 135mm high which is the maximum heigth for a CPU cooler in this case. The power connector is on top, but recessed. The cables would only stick out a couple millimeters at most.
(image: https://content.hwigroup.net/images/...-nitro-8gb.jpg)
I read that the side panels are flimsy, so would that give me a bent side panel?
Edit: I see that I actually have the Sapphire RX 580 Pulse, but I believe the cooler has the same dimensions (only colours are different), so it should be comparable.
Second, despite the fans on the front, the GPU seems to still get not particularly good airflow, while a mATX board is too close to the bottom to fit 120 mm fans properly (this seems like a really stupid oversight imo). Does anybody have confirmation if slimline fans fit? And if yes, how thick (15mm)? It would certainly seem so, but I can get no real confirmation, and OC.net reminded me that these threads are really hard to properly search though.
Edit 2: Despite the Google indexing of OC.net still being crap (it previews the correct page and then sends me to the last page, always. > I managed to dig up an image that pretty much confirms this is gonna be way too tight.
https://www.overclock.net/photopost/...03_170041.jpeg that probably isn't going to play well with the "flimsy" side panels.
deraco96 is offline
